Parametri MarlinKimbra ritrazione April 15, 2015 03:46AM |
#define DEFAULT_AXIS_STEPS_PER_UNIT {80,80,3200/1.25,764,625,625,625} #define DEFAULT_MAX_FEEDRATE {400,400,2,590,100,100,100} #define DEFAULT_RETRACTION_MAX_FEEDRATE {610,110,110,110} #define DEFAULT_MAX_ACCELERATION {3000,3000,50,3000,1000,1000,1000} #define DEFAULT_ACCELERATION 2000 #define DEFAULT_RETRACT_ACCELERATION 18000 #define DEFAULT_TRAVEL_ACCELERATION 2000
Re: Parametri MarlinKimbra ritrazione April 15, 2015 03:57AM |
Re: Parametri MarlinKimbra ritrazione April 15, 2015 04:01AM |
Re: Parametri MarlinKimbra ritrazione April 15, 2015 04:04AM |
Re: Parametri MarlinKimbra ritrazione April 15, 2015 04:24AM |
Re: Parametri MarlinKimbra ritrazione April 15, 2015 04:30AM |
//=================================== EEPROM ================================ // The microcontroller can store settings in the EEPROM, e.g. max velocity... // M500 - stores parameters in EEPROM // M501 - reads parameters from EEPROM (if you need reset them after you changed them temporarily). // M502 - reverts to the default "factory settings". You still need to store them in EEPROM afterwards if you want to. //define this to enable EEPROM support //#define EEPROM_SETTINGS #define EEPROM_CHITCHAT // to disable EEPROM Serial responses and decrease program space by ~1700 byte: comment this out: // please keep turned on if you can. //#define DISABLE_M503
Re: Parametri MarlinKimbra ritrazione April 15, 2015 05:06AM |
#define EEPROM_SETTINGS #define EEPROM_CHITCHATdopo di chè ho inviato tramite repetier M500 per salvare i valori attuali di fw modificati da me.
Re: Parametri MarlinKimbra ritrazione April 15, 2015 08:14AM |
Re: Parametri MarlinKimbra ritrazione April 15, 2015 08:34AM |
Re: Parametri MarlinKimbra ritrazione April 15, 2015 08:42AM |
Re: Parametri MarlinKimbra ritrazione April 15, 2015 08:48AM |
#define DEFAULT_MAX_FEEDRATE {400,400,2,590,100,100,100} // X, Y, Z, E0, E1, E2, E3 (mm/sec) #define DEFAULT_RETRACTION_MAX_FEEDRATE {610,110,110,110}Io utilizzo pronterface cmq.
Re: Parametri MarlinKimbra ritrazione April 15, 2015 09:17AM |
Re: Parametri MarlinKimbra ritrazione April 15, 2015 10:32AM |
// Custom M code points //#define CUSTOM_M_CODES #ifdef CUSTOM_M_CODES #define CUSTOM_M_CODE_SET_Z_PROBE_OFFSET 851 #define Z_PROBE_OFFSET_RANGE_MIN -20 #define Z_PROBE_OFFSET_RANGE_MAX 20 #endifmentre sul Marlin normale è questa:
// Custom M code points #define CUSTOM_M_CODES #ifdef CUSTOM_M_CODES #ifdef ENABLE_AUTO_BED_LEVELING #define CUSTOM_M_CODE_SET_Z_PROBE_OFFSET 851 #define Z_PROBE_OFFSET_RANGE_MIN -20 #define Z_PROBE_OFFSET_RANGE_MAX 20 #endif #endifpraticamente il
#define CUSTOM_M_CODESè decommentato su marlin mentre su MK no. Potrebbe essere?
Re: Parametri MarlinKimbra ritrazione April 15, 2015 02:38PM |
Re: Parametri MarlinKimbra ritrazione April 15, 2015 04:01PM |
Re: Parametri MarlinKimbra ritrazione April 15, 2015 04:15PM |
Re: Parametri MarlinKimbra ritrazione April 15, 2015 04:29PM |
Re: Parametri MarlinKimbra ritrazione April 15, 2015 05:04PM |
Re: Parametri MarlinKimbra ritrazione April 16, 2015 03:18PM |
