THERMAL RUNAWAY PROTECTION May 19, 2015 12:18PM |
Re: THERMAL RUNAWAY PROTECTION May 19, 2015 01:53PM |
//#define THERMAL_PROTECTION_HOTENDS // Enable thermal protection for all extruders //#define THERMAL_PROTECTION_BED // Enable thermal protection for the heated bed
Re: THERMAL RUNAWAY PROTECTION May 20, 2015 03:36AM |
#ifdef THERMAL_RUNAWAY_PROTECTION_PERIOD && THERMAL_RUNAWAY_PROTECTION_PERIOD > 0
void thermal_runaway_protection(int *state, unsigned long *timer, float temperature, float target_temperature, int heater_id, int period_seconds, int hysteresis_degc)
SERIAL_ECHO_START;
SERIAL_ECHO("Thermal Thermal Runaway Running. Heater ID:");
SERIAL_ECHO(heater_id);
SERIAL_ECHO(" ; State:");
SERIAL_ECHO(*state);
SERIAL_ECHO(" ; Timer:");
SERIAL_ECHO(*timer);
SERIAL_ECHO(" ; Temperature:");
SERIAL_ECHO(temperature);
SERIAL_ECHO(" ; Target Temp:");
SERIAL_ECHO(target_temperature);
SERIAL_ECHOLN("");
if ((target_temperature == 0) || thermal_runaway)
*state = 0;
*timer = 0;
return;
switch (*state)
case 0: // "Heater Inactive" state
if (target_temperature > 0) *state = 1;
break;
case 1: // "First Heating" state
if (temperature >= target_temperature) *state = 2;
break;
case 2: // "Temperature Stable" state
if (temperature >= (target_temperature - hysteresis_degc))
*timer = millis();
else if ( (millis() - *timer) > period_seconds*1000)
SERIAL_ERROR_START;
SERIAL_ERRORLNPGM("Thermal Runaway, system stopped! Heater_ID: ");
SERIAL_ERRORLN((int)heater_id);
LCD_ALERTMESSAGEPGM("THERMAL RUNAWAY");
thermal_runaway = true;
while(1)
disable_heater();
disable_x();
disable_y();
disable_z();
disable_e0();
disable_e1();
disable_e2();
manage_heater();
lcd_update();
break;
#endif
void thermal_runaway_protection(int *state, unsigned long *timer, float temperature, float target_temperature, int heater_id, int period_seconds, int hysteresis_degc);
static int thermal_runaway_state_machine[3]; // = {0,0,0};
static unsigned long thermal_runaway_timer[3]; // = {0,0,0};
static bool thermal_runaway = false;
#if TEMP_SENSOR_BED != 0
static int thermal_runaway_bed_state_machine;
static unsigned long thermal_runaway_bed_timer;
#endif
#endif
FORCE_INLINE void autotempShutdown(){
#ifdef AUTOTEMP
if(autotemp_enabled)
autotemp_enabled=false;
if(degTargetHotend(active_extruder)>autotemp_min)
setTargetHotend(0,active_extruder);
#endif
void PID_autotune(float temp, int extruder, int ncycles);
#endif
Re: THERMAL RUNAWAY PROTECTION May 20, 2015 12:27PM |
Re: THERMAL RUNAWAY PROTECTION May 20, 2015 03:40PM |
Re: THERMAL RUNAWAY PROTECTION January 26, 2016 03:15PM |
