Prusa i3 problemi retraction filo con MarlinKimbra June 14, 2015 07:56PM |
Re: Prusa i3 problemi retraction filo con MarlinKimbra June 15, 2015 02:41AM |
#define DEFAULT_MAX_FEEDRATE {300,300,2,15,100,100,100} // X, Y, Z, E0, E1, E2, E3 (mm/sec)
#define DEFAULT_RETRACTION_MAX_FEEDRATE {110,110,110,110} // E0, E1, E2, E3 (mm/sec)
Re: Prusa i3 problemi retraction filo con MarlinKimbra June 15, 2015 03:37AM |
// MOVEMENT SETTINGS
#define HOMING_FEEDRATE {100*60,100*60,2*60,0} // set the homing speeds (mm/min)
// default settings
#define DEFAULT_AXIS_STEPS_PER_UNIT {100,100,4000,909,625,625,625} // X, Y, Z, E0, E1, E2, E3 default steps per unit
#define DEFAULT_MAX_ACCELERATION {3000,3000,100,5000,3000,3000,3000} // X, Y, Z, E0, E1, E2, E3 maximum start speed for accelerated moves.
#define DEFAULT_ACCELERATION 2000 // X, Y, Z and E max acceleration in mm/s^2 for printing moves
#define DEFAULT_RETRACT_ACCELERATION 2000 // E max acceleration in mm/s^2 for retracts
#define DEFAULT_TRAVEL_ACCELERATION 3000 // X, Y, Z acceleration in mm/s^2 for travel (non printing) moves
// Offset of the extruders (uncomment if using more than one and relying on firmware to position when changing).
// The offset has to be X=0, Y=0 for the extruder 0 hotend (default extruder).
// For the other hotends it is their distance from the extruder 0 hotend.
//#define HOTEND_OFFSET_X {0.0, 5.00, 0.0, 0.0} // (in mm) for each extruder, offset of the hotend on the X axis
//#define HOTEND_OFFSET_Y {0.0, 5.00, 0.0, 0.0} // (in mm) for each extruder, offset of the hotend on the Y axis
// The speed change that does not require acceleration (i.e. the software might assume it can be done instantaneously)
#define DEFAULT_XYJERK 20 // (mm/sec)
#define DEFAULT_ZJERK 0.4 // (mm/sec)
#define DEFAULT_EJERK 5 // (mm/sec)
Re: Prusa i3 problemi retraction filo con MarlinKimbra June 15, 2015 03:43AM |
Re: Prusa i3 problemi retraction filo con MarlinKimbra June 15, 2015 04:01AM |
#define DEFAULT_RETRACTION_MAX_FEEDRATE {15,15,15,15} // E0, E1, E2, E3 (mm/sec)
Re: Prusa i3 problemi retraction filo con MarlinKimbra June 15, 2015 04:03AM |
Re: Prusa i3 problemi retraction filo con MarlinKimbra June 15, 2015 06:47PM |
Re: Prusa i3 problemi retraction filo con MarlinKimbra June 17, 2015 10:40AM |
Re: Prusa i3 problemi retraction filo con MarlinKimbra June 17, 2015 10:52AM |
lamerhouse
ottimo era il mio stesso problema piu volte segnalato .... faccio anch'io prove
Re: Prusa i3 problemi retraction filo con MarlinKimbra June 18, 2015 06:05PM |
/ default settings
#define DEFAULT_AXIS_STEPS_PER_UNIT {80,80,4000,1168,625,625,625} // X, Y, Z, E0...(per extruder). Default steps per unit
#define DEFAULT_MAX_FEEDRATE {200,200,2,45,100,100,100} // X, Y, Z, E0...(per extruder). (mm/sec)
#define DEFAULT_RETRACTION_MAX_FEEDRATE {30,30,30,30} // E0, E1, E2, E3 (mm/sec)
#define DEFAULT_MAX_ACCELERATION {1500,1500,50,2000,3000,3000,3000} // X, Y, Z, E0...(per extruder). Maximum start speed for accelerated moves.
#define DEFAULT_RETRACT_ACCELERATION {2000,10000,10000,10000} // E0... (per extruder) max acceleration in mm/s^2 for retracts
#define DEFAULT_ACCELERATION 2000 // X, Y, Z and E* max acceleration in mm/s^2 for printing moves
Re: Prusa i3 problemi retraction filo con MarlinKimbra June 18, 2015 06:35PM |
lamerhouse
confermo ora la ritrazione del filo funziona perfettamente come tutto il resto ora per me e la versione definitiva
/ default settings #define DEFAULT_AXIS_STEPS_PER_UNIT {80,80,4000,1168,625,625,625} // X, Y, Z, E0...(per extruder). Default steps per unit
Re: Prusa i3 problemi retraction filo con MarlinKimbra June 18, 2015 07:45PM |
lamerhouse
/ default settings #define DEFAULT_AXIS_STEPS_PER_UNIT {80,80,4000,1168,625,625,625} // X, Y, Z, E0...(per extruder). Default steps per unit #define DEFAULT_MAX_FEEDRATE {200,200,2,45,100,100,100} // X, Y, Z, E0...(per extruder). (mm/sec) #define DEFAULT_RETRACTION_MAX_FEEDRATE {30,30,30,30} // E0, E1, E2, E3 (mm/sec) #define DEFAULT_MAX_ACCELERATION {1500,1500,50,2000,3000,3000,3000} // X, Y, Z, E0...(per extruder). Maximum start speed for accelerated moves. #define DEFAULT_RETRACT_ACCELERATION {2000,10000,10000,10000} // E0... (per extruder) max acceleration in mm/s^2 for retracts #define DEFAULT_ACCELERATION 2000 // X, Y, Z and E* max acceleration in mm/s^2 for printing moves #define DEFAULT_TRAVEL_ACCELERATION 3000 // X, Y, Z acceleration in mm/s^2 for travel (non printing) moves
Re: Prusa i3 problemi retraction filo con MarlinKimbra June 18, 2015 08:23PM |
Re: Prusa i3 problemi retraction filo con MarlinKimbra June 23, 2015 05:09PM |
Re: Prusa i3 problemi retraction filo con MarlinKimbra June 23, 2015 05:10PM |
MagoKimbra
Di solito la ritrazione dovrebbe essere più veloce dell'estrusione, ecco perché avevo messo il doppio valore. Questo perché non ha bisogno di spingere il filo nell'hotend.
Come mai un valore più basso??? Se metti 45 di estrusione al massimo metti 45 di ritrazione, ma secondo me a 50/60 ci puoi arrivare..
lamerhouse
