MarlinKimbra 4.2.x
Posted by MagoKimbra
Re: MarlinKimbra 4.2.x
September 06, 2015 10:13AM
Ok Mandato x Mail
Intanto stavo provando la ver per DUE
Sulla scheda Ramps FD 1 da questo errore
In file included from conditionals.h:217:0,
                 from base.h:51,
                 from blinkm.cpp:6:
pins.h:2660: error: #error Oops! Make sure you have 'Sanguino' selected from the 'Tools -> Boards' menu.
pins.h:2676: error: #error Oops! Make sure you have 'Sanguino' selected from the 'Tools -> Boards' menu.
Exception in thread "AWT-EventQueue-0" java.lang.NullPointerException
	at org.fife.ui.rsyntaxtextarea.DefaultTokenPainter.paintImpl(DefaultTokenPainter.java:106)
	at org.fife.ui.rsyntaxtextarea.DefaultTokenPainter.paint(DefaultTokenPainter.java:58)
	at org.fife.ui.rsyntaxtextarea.SyntaxView.drawLine(SyntaxView.java:178)
	at org.fife.ui.rsyntaxtextarea.SyntaxView.paint(SyntaxView.java:722)
	at javax.swing.plaf.basic.BasicTextUI$RootView.paint(BasicTextUI.java:1434)
	at javax.swing.plaf.basic.BasicTextUI.paintSafely(BasicTextUI.java:737)
	at javax.swing.plaf.basic.BasicTextUI.paint(BasicTextUI.java:881)
	at javax.swing.plaf.basic.BasicTextUI.update(BasicTextUI.java:860)
	at org.fife.ui.rtextarea.RTextAreaBase.paintComponent(RTextAreaBase.java:719)
	at org.fife.ui.rsyntaxtextarea.RSyntaxTextArea.paintComponent(RSyntaxTextArea.java:1993)
	at javax.swing.JComponent.paint(JComponent.java:1056)
	at javax.swing.JComponent.paintChildren(JComponent.java:889)
	at javax.swing.JComponent.paint(JComponent.java:1065)
	at javax.swing.JViewport.paint(JViewport.java:728)
	at javax.swing.JComponent.paintToOffscreen(JComponent.java:5219)
	at javax.swing.RepaintManager$PaintManager.paintDoubleBuffered(RepaintManager.java:1572)
	at javax.swing.RepaintManager$PaintManager.paint(RepaintManager.java:1495)
	at javax.swing.RepaintManager.paint(RepaintManager.java:1265)
	at javax.swing.JComponent._paintImmediately(JComponent.java:5167)
	at javax.swing.JComponent.paintImmediately(JComponent.java:4978)
	at javax.swing.RepaintManager$4.run(RepaintManager.java:824)
	at javax.swing.RepaintManager$4.run(RepaintManager.java:807)
	at java.security.AccessController.doPrivileged(Native Method)
	at java.security.ProtectionDomain$1.doIntersectionPrivilege(ProtectionDomain.java:75)
	at javax.swing.RepaintManager.paintDirtyRegions(RepaintManager.java:807)
	at javax.swing.RepaintManager.paintDirtyRegions(RepaintManager.java:782)
	at javax.swing.RepaintManager.prePaintDirtyRegions(RepaintManager.java:731)
	at javax.swing.RepaintManager.access$1300(RepaintManager.java:64)
	at javax.swing.RepaintManager$ProcessingRunnable.run(RepaintManager.java:1720)
	at java.awt.event.InvocationEvent.dispatch(InvocationEvent.java:311)
	at java.awt.EventQueue.dispatchEventImpl(EventQueue.java:756)
	at java.awt.EventQueue.access$500(EventQueue.java:97)
	at java.awt.EventQueue$3.run(EventQueue.java:709)
	at java.awt.EventQueue$3.run(EventQueue.java:703)
	at java.awt.EventQueue.dispatchEvent(EventQueue.java:726)
	at java.awt.EventDispatchThread.pumpOneEventForFilters(EventDispatchThread.java:201)
	at java.awt.EventDispatchThread.pumpEventsForFilter(EventDispatchThread.java:116)
	at java.awt.EventDispatchThread.pumpEventsForHierarchy(EventDispatchThread.java:105)
	at java.awt.EventDispatchThread.pumpEvents(EventDispatchThread.java:101)
	at java.awt.EventDispatchThread.pumpEvents(EventDispatchThread.java:93)
	at java.awt.EventDispatchThread.run(EventDispatchThread.java:82)
Exception in thread "Thread-38" java.lang.IndexOutOfBoundsException: len=-85368
	at sun.font.FontDesignMetrics.charsWidth(FontDesignMetrics.java:501)
	at org.fife.ui.rsyntaxtextarea.TokenImpl.getWidthUpTo(TokenImpl.java:528)
	at org.fife.ui.rsyntaxtextarea.TokenImpl.getWidth(TokenImpl.java:499)
	at org.fife.ui.rsyntaxtextarea.RSyntaxUtilities.getTokenListWidth(RSyntaxUtilities.java:1142)
	at org.fife.ui.rsyntaxtextarea.RSyntaxUtilities.getTokenListWidth(RSyntaxUtilities.java:1121)
	at org.fife.ui.rsyntaxtextarea.SyntaxView.getLineWidth(SyntaxView.java:304)
	at org.fife.ui.rsyntaxtextarea.SyntaxView.calculateLongestLine(SyntaxView.java:110)
	at org.fife.ui.rsyntaxtextarea.SyntaxView.updateMetrics(SyntaxView.java:892)
	at org.fife.ui.rsyntaxtextarea.SyntaxView.setSize(SyntaxView.java:802)
	at javax.swing.plaf.basic.BasicTextUI$RootView.setSize(BasicTextUI.java:1722)
	at javax.swing.plaf.basic.BasicTextUI.getPreferredSize(BasicTextUI.java:912)
	at javax.swing.plaf.basic.BasicTextAreaUI.getPreferredSize(BasicTextAreaUI.java:120)
	at javax.swing.JComponent.getPreferredSize(JComponent.java:1662)
	at javax.swing.JTextArea.getPreferredSize(JTextArea.java:619)
	at javax.swing.JViewport.getViewSize(JViewport.java:999)
	at javax.swing.plaf.basic.BasicScrollPaneUI.syncScrollPaneWithViewport(BasicScrollPaneUI.java:278)
	at javax.swing.plaf.basic.BasicScrollPaneUI$Handler.stateChanged(BasicScrollPaneUI.java:1033)
	at javax.swing.JViewport.fireStateChanged(JViewport.java:1369)
	at javax.swing.JViewport.setView(JViewport.java:969)
	at javax.swing.JScrollPane.setViewportView(JScrollPane.java:1007)
	at org.fife.ui.rtextarea.RTextScrollPane.setViewportView(RTextScrollPane.java:253)
	at processing.app.Editor.setCode(Editor.java:1766)
	at processing.app.Sketch.setCurrentCode(Sketch.java:1000)
	at processing.app.Sketch.setCurrentCode(Sketch.java:980)
	at processing.app.Editor.statusError(Editor.java:2670)
	at processing.app.Editor$BuildHandler.run(Editor.java:1963)
	at java.lang.Thread.run(Thread.java:745)
Nella Smart Ramps da questo
In file included from SdVolume.h:27:0,
                 from SdBaseFile.h:27,
                 from SdFile.h:24,
                 from cardreader.h:6,
                 from cardreader.cpp:14:
Sd2Card.h:130: error: 'SS_PIN' was not declared in this scope
 uint8_t const  SD_CHIP_SELECT_PIN = SS_PIN;
	at org.fife.ui.rsyntaxtextarea.TokenMakerBase.addNullToken(TokenMakerBase.java:79)
	at org.fife.ui.rsyntaxtextarea.modes.CPlusPlusTokenMaker.yylex(CPlusPlusTokenMaker.java:2299)
	at org.fife.ui.rsyntaxtextarea.modes.CPlusPlusTokenMaker.getTokenList(CPlusPlusTokenMaker.java:1901)
	at org.fife.ui.rsyntaxtextarea.RSyntaxDocument.getTokenListForLine(RSyntaxDocument.java:416)
	at org.fife.ui.rsyntaxtextarea.SyntaxView.paint(SyntaxView.java:719)
P.S nella ver due crea la dir sd_card_menu da copiare nel SD mentre nella ver Mega NO
Anche il Configuration_Overall.h è presente solo nella ver DUE nella Mega il Configuration.h e corretto ?
www.saviot.com Stampante Prusa I3 R2.2 By Nicola P.
Ramps 1.4 Con FW MarlinKimba Fusore HE IeC 1.75mm Con Flusso Canalizzatore Estrusori BullDog XL
Piano maggiorato 240*311mm pilotato da SSR 24V con letto scaldante autocostruito
Lavori in Corso Prossimetro Autolivellamento Z Gestione Remota Raspberry PI 2 con OctoPrint
Rilevamento ottico Fine Filo Illuminazione e Visione AreaStampa Remotata In costruzione Trafilatore TL-Plastic
September 06, 2015 10:17AM
Disabilita la SD card innanzitutto... Non ci sono i pin per la gestione della SD, se li hai allora inseriscili...
My Blog - My Thingiverse
September 06, 2015 11:24AM
Allego il configuration_overall.h per il problema con la disabilitazione del bed che da poi errore in compilazione, puntualizzo che ho scelto come board "BOARD_RAMPS_13_HFF", come avevo fatto nella versione precedente e non aveva dato errori.
Grazie Mago.
Edited 1 time(s). Last edit at 09/06/2015 11:30AM by amario57.
Prusa I3 R2 di Nicola P. Hotend IeC 1.75
Delta Kossel V250 in costruzione
open | download - Configuration_Overall.h (11.5 KB)
September 06, 2015 12:38PM
Grazie Amario...
Si in effetti il problema che in configuration_basic.h è a uno quindi se non lo metto a 0 rimane attivo... Ho corretto... Ma senza che scarichi metti questo file..
open | download - Configuration_Basic.h (14.3 KB)
September 06, 2015 02:02PM
Ho riscaricato il firmware e ora compila a dovere, peccato che per un po' non potrò provarlo...
Ho alcuni dubbi sul file Configuration_Overall.h, immagino vengano lette le define per ultime durante la compilazione e quindi sovrascritto il valore precente...
Se così fosse mi è possibile rimuovere una define già dichiarata in un altro file? Ad esempio, se faccio un upgrade dell'ABL e non mi serve più il servo non posso evitare che venga compilato se in Configuration_Feature.h ho decommentato #define ENABLE_SERVOS, giusto?
Edited 1 time(s). Last edit at 09/06/2015 02:14PM by Paso.
September 06, 2015 02:53PM
Adesso è OK anche con la DEV
E anche OK lo stato invertito del pin dei Relè
Non ci ho pensato bastava mettere Mintemp a 0 per tenerlo abilitatoto e farlo andare anche senza sensore collegato senza andare in errore grinning smiley
Unico problema rimasto ancora con i Relè scambio estrusori
Ovvero quando parte si attivano entrambi
Devo cambiare estrusore e poi ripassare al 1 per disattivarli entrambi
Andrebbe messa qualcosa che all' avvio di default è su estrusore 1 e verifica lo status dei pin tipo un off on o vicevera
a secodna dello stato logico impostato
Quando inserisco usb ok ma appena alimento si attivano i due pin
Quando apro RH e connetto si disattivano per un secondo e poi si riattivano entrambi
Per ripristinare la cosa devo cambiare estrusore e riselezionare 1 cosi restano entrambi e due disattivi
e ovviamente il cambio estrusore viene fatto come da regola spero d'essermi spiegato bene grinning smiley
Grazie
September 06, 2015 04:53PM
@Paso tendenzialmente il file overall serve proprio per avere in un unico file tutte le modifiche inerenti alla nostra stampante. Se devono essere fatte modifiche è meglio farlo sempre nell'overall in questo modo se si aggiorna il fw, basta copiare il file e non cercare le varie funzioni per i diversi configuration.
Il configuratore è fatto in modo che se una funzione di default è attiva, tipo PID_TEMP che è una funzione normalmente attiva in tutti i FW, e si disattiva in fase di configurazione metterà #undef PID_TEMP che quindi la disattiva. Ma nel caso che tu hai citato se nel configuration_feature hai decommentato a mano #define ENABLE_SERVOS in overall non c'è un undef e quindi sarà attivata...
Ma sarebbe meglio se volessimo attivare quella funzione a mano copiarci la linea e copiarla in overall in qualsiasi punto volete e decommentarla. in questo modo non si toccano i file principali e facilmente si può disattivare commentandola...
@Savio il fatto è che all'accensione i pin vengono portati al livello basso e quindi si attivano i relé, solo quando arriva il comando Tx di cambio estrusore vado a scrivere nei relè... Ora ci provo a farlo nel setup dei pin....
September 06, 2015 05:03PM
Capito, meglio disabilitare tutto e riabilitare solo quel che serve nel Configuration_Overall.h!
Però un dubbio resta, per la meccanica comunque è da modificare nel file configuration_basic.h?
September 06, 2015 05:04PM
MagoKimbra
Immaginavo Domanda si puo Bypassare la cosa nel Gcode dello Slider mandando qualche comando all' avvio?
Intanto adesso nel frattempo lo so e all' avvio cambio estrusore e poi risetto quello che uso
September 06, 2015 05:27PM
La modifica è già su!!!
September 06, 2015 06:11PM
Perfetto funziona adesso sulla Ramps 1.4 va tutto ho il mot estrusore 2 che Raglia ma credo sia qualche prob mio di falso contatto nel cablagigo domani ci controllo meglio
Nella compilazione Ramps FD 1 da questo errore
In file included from blinkm.cpp:6:0:
base.h:22:22: fatal error: fastio.h: No such file or directory
   #include "fastio.h"
compilation terminated.
Errore durante la compilazione
Se lascio SD e levo LCD lo compila senza errori quindi credo il problema sia li
Stesso per la Smart Ramps
Provato se gli do come LCD Nextion Hmi LCD compila senza errori
September 07, 2015 12:16AM
Complimenti Mago, funziona perfettamente ed un punto in più per l'Auto Home più "controllato" winking smiley
Manuel
Prusa i3 - disassemblata
Ultimaker 2**HC (Marlin+ e3d 1.75 +estrusore made by Andrea Lillia)
SIENCI cnc
September 07, 2015 02:08AM
Quell'errore lo da se hai settato un processore tipo il mega quando compili per il due...
Ho provato e riprovato con la tua configurazione e mettendo le varie schede e non ho problemi in compilazione...
September 07, 2015 02:16AM
MagoKimbra
Umm grazie del suggerimento stasera verifico meglio ricordo d'aver settato arduino Due Program Port
e il reletivo processore ma avendo velocemente programmato prima mega e poi provato sul DUE non vorrei aver tralasciato qualcosa P.S uso la IDE 1.6.5
Se a te va bene stasera verifico meglio la cosa forse con la nuova IDE mi sono confuso a selezionare qualcosa dato che hanno cambiato qualche disposizione
September 07, 2015 12:09PM
Complimenti mago...
PS: provando a scaricarlo dal configuratore:
se hai l'autofan setta i pin ma manca il #define EXTRUDER_AUTO_FAN
e la Z safe mode manca completamente
September 07, 2015 12:38PM
Ok per l'autofan, ma lo z safe c'è all'inizio della configurazione meccanica....
September 07, 2015 01:43PM
Questo è come ho settato IDE credo sia OK per il DUE
Questo è errore che mi da con la Smart Ramps qualcosa sul PIN 4 non dichiarato ?
In file included from base.h:18:0,
                 from ultralcd.cpp:2:
ultralcd_st7920_u8glib_rrd.h: In function 'void ST7920_SWSPI_SND_8BIT(uint8_t)':
ultralcd_st7920_u8glib_rrd.h:9: error: 'LCD_PINS_D4' was not declared in this scope
 #define ST7920_CLK_PIN  LCD_PINS_D4
HAL.h:81:42: note: in definition of macro 'WRITE_VAR'
 #define WRITE_VAR(pin, v)   digitalWrite(pin, v)
ultralcd_st7920_u8glib_rrd.h:26:15: note: in expansion of macro 'ST7920_CLK_PIN'
     WRITE_VAR(ST7920_CLK_PIN,0);
ultralcd_st7920_u8glib_rrd.h:10: error: 'LCD_PINS_ENABLE' was not declared in this scope
 #define ST7920_DAT_PIN  LCD_PINS_ENABLE
ultralcd_st7920_u8glib_rrd.h:27:15: note: in expansion of macro 'ST7920_DAT_PIN'
     WRITE_VAR(ST7920_DAT_PIN,val&0x80);
ultralcd_st7920_u8glib_rrd.h: In function 'uint8_t u8g_dev_rrd_st7920_128x64_fn(u8g_t*, u8g_dev_t*, uint8_t, void*)':
ultralcd_st7920_u8glib_rrd.h:11: error: 'LCD_PINS_RS' was not declared in this scope
 #define ST7920_CS_PIN   LCD_PINS_RS
HAL.h:88:59: note: in definition of macro 'SET_OUTPUT'
 #define   SET_OUTPUT(pin) PIO_Configure(g_APinDescription[pin].pPort, PIO_OUTPUT_1, \
ultralcd_st7920_u8glib_rrd.h:47:9: note: in expansion of macro 'OUT_WRITE'
         OUT_WRITE(ST7920_CS_PIN,LOW);
ultralcd_st7920_u8glib_rrd.h:47:19: note: in expansion of macro 'ST7920_CS_PIN'
ultralcd_st7920_u8glib_rrd.h:48:9: note: in expansion of macro 'OUT_WRITE'
         OUT_WRITE(ST7920_DAT_PIN,LOW);
ultralcd_st7920_u8glib_rrd.h:48:19: note: in expansion of macro 'ST7920_DAT_PIN'
ultralcd_st7920_u8glib_rrd.h:49:9: note: in expansion of macro 'OUT_WRITE'
         OUT_WRITE(ST7920_CLK_PIN,HIGH);
ultralcd_st7920_u8glib_rrd.h:49:19: note: in expansion of macro 'ST7920_CLK_PIN'
ultralcd_st7920_u8glib_rrd.h:33:45: note: in expansion of macro 'ST7920_CS_PIN'
 #define ST7920_CS()              {WRITE_VAR(ST7920_CS_PIN,1);u8g_10MicroDelay();}
ultralcd_st7920_u8glib_rrd.h:51:9: note: in expansion of macro 'ST7920_CS'
         ST7920_CS();
ultralcd_st7920_u8glib_rrd.h:34:45: note: in expansion of macro 'ST7920_CS_PIN'
 #define ST7920_NCS()             {WRITE_VAR(ST7920_CS_PIN,0);}
ultralcd_st7920_u8glib_rrd.h:68:9: note: in expansion of macro 'ST7920_NCS'
         ST7920_NCS();
ultralcd_st7920_u8glib_rrd.h:81:9: note: in expansion of macro 'ST7920_CS'
         ST7920_CS();
ultralcd_st7920_u8glib_rrd.h:100:9: note: in expansion of macro 'ST7920_NCS'
         ST7920_NCS();
ultralcd.cpp: In function 'void lcd_init()':
ultralcd.cpp:1656: error: 'BTN_EN1' was not declared in this scope
     SET_INPUT(BTN_EN1);
HAL.h:85:67: note: in definition of macro 'SET_INPUT'
 #define   SET_INPUT(pin)  pmc_enable_periph_clk(g_APinDescription[pin].ulPeripheralId); \
ultralcd.cpp:1657: error: 'BTN_EN2' was not declared in this scope
     SET_INPUT(BTN_EN2);
HAL.h:72: error: 'DIOBTN_EN1_WPORT' was not declared in this scope
 #define _FASTWRITE(IO, v) do {  if (v) {DIO ## IO ## _WPORT -> PIO_SODR |= MASK(DIO ## IO ##_PIN); } \
HAL.h:82:29: note: in expansion of macro '_FASTWRITE'
 #define WRITE(pin, v)       _FASTWRITE(pin, v)
ultralcd.cpp:1658:5: note: in expansion of macro 'WRITE'
     WRITE(BTN_EN1,HIGH);
HAL.h:72: error: 'DIOBTN_EN1_PIN' was not declared in this scope
HAL.h:62:28: note: in definition of macro 'MASK'
   #define MASK(PIN)  (1 << PIN)
HAL.h:73: error: 'DIOBTN_EN1_WPORT' was not declared in this scope
                                 else {DIO ##  IO ## _WPORT -> PIO_CODR = MASK(DIO ## IO ## _PIN); }; \
HAL.h:73: error: 'DIOBTN_EN1_PIN' was not declared in this scope
HAL.h:72: error: 'DIOBTN_EN2_WPORT' was not declared in this scope
ultralcd.cpp:1659:5: note: in expansion of macro 'WRITE'
     WRITE(BTN_EN2,HIGH);
HAL.h:72: error: 'DIOBTN_EN2_PIN' was not declared in this scope
HAL.h:73: error: 'DIOBTN_EN2_WPORT' was not declared in this scope
HAL.h:73: error: 'DIOBTN_EN2_PIN' was not declared in this scope
ultralcd.cpp: In function 'void lcd_buttons_update()':
HAL.h:70: error: 'DIOBTN_EN1_WPORT' was not declared in this scope
 #define _FASTREAD(IO) ((bool)(DIO ## IO ## _WPORT -> PIO_PDSR & (MASK(DIO ## IO ## _PIN))))
HAL.h:78:29: note: in expansion of macro '_FASTREAD'
 #define READ(pin)           _FASTREAD(pin)
ultralcd.cpp:1961:13: note: in expansion of macro 'READ'
         if (READ(BTN_EN1) == 0) newbutton |= EN_B;
HAL.h:70: error: 'DIOBTN_EN1_PIN' was not declared in this scope
HAL.h:70: error: 'DIOBTN_EN2_WPORT' was not declared in this scope
ultralcd.cpp:1962:13: note: in expansion of macro 'READ'
         if (READ(BTN_EN2) == 0) newbutton |= EN_A;
HAL.h:70: error: 'DIOBTN_EN2_PIN' was not declared in this scope
September 07, 2015 02:02PM
Savio te lo detto non ci sono i pin del lcd... bisogna trovarli e metterli...
Per ora non settare lcd e prova solo la scheda.... Poi dovrebbe essere la nativa non la programming...
September 07, 2015 05:56PM
Ha io ho sempre usato la programing dal nome credevo che era appunto la porta designata a caricare FW allora le prox provero la nativa grinning smiley
Si me avevi detto ma non ci ho fatto caso hai ragione allora :
Questi sono i connettori del FULL GRAPHIC SMART CONTROLER
Che vanno collegati a AUX 3 la parte SD e Aux 2 la parte LCD
Quindi leggendo gli schemi desumo:
A4 LCD6 D40 LCD4 D42 LCDE A12 Beeper A3 LCD7 A5 LCD5 D44 LCDrs a13 btn enc
La parte SD credo che non posso reindirizzare da FW devo fare un convettitore di cavo ma questo me lo verifico dopo
:Edit altre info trovate
Questo è come sara collegato fisicamente i due cavi
Edited 1 time(s). Last edit at 09/08/2015 04:26AM by saviothecnic.
September 08, 2015 03:47PM
Comunqeu ci sta qualcosa che non va nel Homing
Noto che è cambiata la sequezna rispetto a prima
Il problema piu grave e se che si rifa homing TOTALE per la seconda volta non va continua a scendere anche quando impegna Z Min
E non mette in sicurezza Prima Y e poi X prima di scendere in Z
September 08, 2015 03:54PM
saviothecnic
Ho notato anche io stasera la stessa cosa.
Se interrompo una stampa da sd (per esempio) e mando in home x e y si azzerano ma z continua a scendere fino a quando non "trova il petrolio" ignorando l endstop z.
Manuel
SIENCI cnc
September 08, 2015 04:01PM
Bene anzi male.. Domani controllo subito... Quindi la doppia home da problemi....
September 08, 2015 04:21PM
Si esatto va bene solo la prima Home
Adesso carico la 4.1.2 semrpe dal configuratore on-line ansiche la 4.2 DEV per vedere se il probema e anche sulla 4.1.2
:Edit che fregatura se importo la config della DEV e selezione solo il firmware versione Stabile non si puo fare sad smiley
Da questo errore ?
Arduino:1.6.5 (Windows 7), Scheda:"Arduino Mega or Mega 2560, ATmega2560 (Mega 2560)"
In file included from conditionals.h:248:0,
                 from Configuration_adv.h:529,
                 from Configuration.h:609,
                 from Marlin.h:25,
                 from Marlin_main.cpp:22:
Marlin_main.cpp: In function 'void gcode_M145()':
C:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino/Arduino.h:87:44: error: expected primary-expression before ')' token
 #define constrain(amt,low,high) ((amt)<(low)?(low)sad smiley(amt)>(high)?(high)sad smileyamt)))
Marlin_main.cpp:4445:35: note: in expansion of macro 'constrain'
               plaPreheatHPBTemp = constrain(v, BED_MINTEMP, BED_MAXTEMP - 15);
C:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino/Arduino.h:87:50: error: expected primary-expression before ')' token
Marlin_main.cpp:4461:35: note: in expansion of macro 'constrain'
               absPreheatHPBTemp = constrain(v, BED_MINTEMP, BED_MAXTEMP - 15);
Marlin_main.cpp:4477:35: note: in expansion of macro 'constrain'
               gumPreheatHPBTemp = constrain(v, BED_MINTEMP, BED_MAXTEMP - 15);
  Questo report potrebbe essere più ricco
di informazioni con
  "Mostra un output dettagliato durante la compilazione"
  abilitato in "File > Impostazioni"
Edited 1 time(s). Last edit at 09/08/2015 05:14PM by saviothecnic.
September 09, 2015 12:30AM
saviothecnic
Da questo errore ?
di informazioni con
Savio hai buttato dentro il configuration.h e cambiato solo la riga/tendina del fw v?
Manuel
SIENCI cnc
September 09, 2015 01:52AM
ManuHC
No dal configuratore on-line ho importato Configuration_Overall.h e cambiato la versione di FW da DEV a 4.1.2 stable e poi scaricato
Nel FW 4.1.2 non è presente Configuration_Overall.h ma solo Configuration.h nella DEV opposto
Questa pero è una fregatura significa che passando da dev a stabile non posso recuperare le config sad smiley
September 09, 2015 01:57AM
saviothecnic
ManuHC
Esatto era quello che intendevo…e quello che temevo smiling smiley
….io ho già ricaricato il precedente 4.1.2 che mi ero salvato pre 4.2.x attendiamo che ci illumini il Mago
Manuel
SIENCI cnc
September 09, 2015 02:10AM
Si ho capito che avevi inteso e temuto bene grinning smiley
Ma l'ho specificato per puntualizzare che tra le due versioni i files config da importare non sono entrambi presenti/generati
e quindi passare da dev a stabile non è una cosa indolore dato che le config non sono compatibili sad smiley
Quindi non ho capito con la 4.1.2 il secondo Home ti va bene ?
Comunque speriamo risolva che si possa passare da Stabile a Dev generando per entrambi le versioni i due files di config eventualmente da importare
P.S nella stabile non vengono generate le dir per SD e il Nuovo Display I2C che invece vengono generate per la DEV
Quindi tanto per capire quali sono le differenze tra la DEV e la Stabile tutte quelle citate ad inizio Topic esatto ?
Grazie
September 09, 2015 02:37AM
La versione 4.1.2 onestamente l'ho utilizzata con mac collegato alla stampante e non da SD direttamente…però se la memoria non mi inganna non ha fatto alcuno scherzo come sul 4.2.x
Si si hai fatto bene a specificare la cosa.
Manuel
SIENCI cnc
September 11, 2015 04:03AM
Mago & Simone Primarosa ma allora è grave questo problema del doppio Home da risolvere sono due gg che non abbiamo più notizie eye popping smiley
Allora mi stampo le schermate e rimetto su la 4.1.2 che con questo prob ho già rischiato due tre volte di rompere qualcosa
HE che schiacciava sul pianto al secondo Home fortuna che la R2 e HE IeC sono dei muli da fatica smiling smiley
September 11, 2015 05:23AM
Savio mi mandi l'overall tuo... Io ho provato e riprovato nessun problema ho fatto un gcode con 10 g28 e li ha fatti tutti senza problemi....
Magari è qualche configurazione strana che non comprendo...
