Quando la Cura non salva..... October 03, 2015 06:22AM |
[profile] layer_height = 0.2 wall_thickness = 1.2 retraction_enable = True solid_layer_thickness = 1 fill_density = 20 nozzle_size = 0.4 print_speed = 50 print_temperature = 210 print_temperature2 = 0 print_temperature3 = 0 print_temperature4 = 0 print_temperature5 = 0 print_bed_temperature = 70 support = None platform_adhesion = Brim support_dual_extrusion = Both wipe_tower = False wipe_tower_volume = 15 ooze_shield = False filament_diameter = 1.75 filament_diameter2 = 0 filament_diameter3 = 0 filament_diameter4 = 0 filament_diameter5 = 0 filament_flow = 100.0 retraction_speed = 40.0 retraction_amount = 4.5 retraction_dual_amount = 16.5 retraction_min_travel = 1.5 retraction_combing = All retraction_minimal_extrusion = 0.02 retraction_hop = 0.0 bottom_thickness = 0.3 layer0_width_factor = 100 object_sink = 0.0 overlap_dual = 0.15 travel_speed = 50.0 bottom_layer_speed = 20 infill_speed = 30.0 solidarea_speed = 30.0 inset0_speed = 30.0 insetx_speed = 20.0 cool_min_layer_time = 5 fan_enabled = True skirt_line_count = 1 skirt_gap = 3.0 skirt_minimal_length = 150.0 fan_full_height = 0.5 fan_speed = 100 fan_speed_max = 100 cool_min_feedrate = 10 cool_head_lift = False solid_top = True solid_bottom = True fill_overlap = 15 perimeter_before_infill = False support_type = Lines support_angle = 60 support_fill_rate = 15 support_xy_distance = 0.7 support_z_distance = 0.15 spiralize = False simple_mode = False brim_line_count = 20 raft_margin = 5.0 raft_line_spacing = 3.0 raft_base_thickness = 0.3 raft_base_linewidth = 1.0 raft_interface_thickness = 0.27 raft_interface_linewidth = 0.4 raft_airgap_all = 0.0 raft_airgap = 0.22 raft_surface_layers = 2 raft_surface_thickness = 0.27 raft_surface_linewidth = 0.4 fix_horrible_union_all_type_a = False fix_horrible_union_all_type_b = False fix_horrible_use_open_bits = False fix_horrible_extensive_stitching = False plugin_config = object_center_x = -1 object_center_y = -1 [alterations] start.gcode = ;Sliced at: {day} {date} {time} ;Basic settings: Layer height: {layer_height} Walls: {wall_thickness} Fill: {fill_density} ;Print time: {print_time} ;Filament used: {filament_amount}m {filament_weight}g ;Filament cost: {filament_cost} ;M190 S{print_bed_temperature} ;Uncomment to add your own bed temperature line ;M109 S{print_temperature} ;Uncomment to add your own temperature line G21 ;metric values G90 ;absolute positioning M82 ;set extruder to absolute mode M107 ;start with the fan off G28 end.gcode = ;End GCode G1 M05 M02 start2.gcode = ;Sliced at: {day} {date} {time} ;Basic settings: Layer height: {layer_height} Walls: {wall_thickness} Fill: {fill_density} ;Print time: {print_time} ;Filament used: {filament_amount}m {filament_weight}g ;Filament cost: {filament_cost} ;M190 S{print_bed_temperature} ;Uncomment to add your own bed temperature line ;M104 S{print_temperature} ;Uncomment to add your own temperature line ;M109 T1 S{print_temperature2} ;Uncomment to add your own temperature line ;M109 T0 S{print_temperature} ;Uncomment to add your own temperature line G21 ;metric values G90 ;absolute positioning M107 ;start with the fan off G28 X0 Y0 ;move X/Y to min endstops G28 Z0 ;move Z to min endstops G1 Z15.0 F{travel_speed} ;move the platform down 15mm T1 ;Switch to the 2nd extruder G92 E0 ;zero the extruded length G1 F200 E10 ;extrude 10mm of feed stock G92 E0 ;zero the extruded length again G1 F200 E-{retraction_dual_amount} T0 ;Switch to the first extruder G92 E0 ;zero the extruded length G1 F200 E10 ;extrude 10mm of feed stock G92 E0 ;zero the extruded length again G1 F{travel_speed} ;Put printing message on LCD screen M117 Printing... end2.gcode = ;End GCode M104 T0 S0 ;extruder heater off M104 T1 S0 ;extruder heater off M140 S0 ;heated bed heater off (if you have it) G91 ;relative positioning G1 E-1 F300 ;retract the filament a bit before lifting the nozzle, to release some of the pressure G1 Z+0.5 E-5 X-20 Y-20 F{travel_speed} ;move Z up a bit and retract filament even more G28 X0 Y0 ;move X/Y to min endstops, so the head is out of the way M84 ;steppers off G90 ;absolute positioning ;{profile_string} start3.gcode = ;Sliced at: {day} {date} {time} ;Basic settings: Layer height: {layer_height} Walls: {wall_thickness} Fill: {fill_density} ;Print time: {print_time} ;Filament used: {filament_amount}m {filament_weight}g ;Filament cost: {filament_cost} ;M190 S{print_bed_temperature} ;Uncomment to add your own bed temperature line ;M104 S{print_temperature} ;Uncomment to add your own temperature line ;M109 T1 S{print_temperature2} ;Uncomment to add your own temperature line ;M109 T0 S{print_temperature} ;Uncomment to add your own temperature line G21 ;metric values G90 ;absolute positioning M107 ;start with the fan off G28 X0 Y0 ;move X/Y to min endstops G28 Z0 ;move Z to min endstops G1 Z15.0 F{travel_speed} ;move the platform down 15mm T2 ;Switch to the 3rd extruder G92 E0 ;zero the extruded length G1 F200 E10 ;extrude 10mm of feed stock G92 E0 ;zero the extruded length again G1 F200 E-{retraction_dual_amount} T1 ;Switch to the 2nd extruder G92 E0 ;zero the extruded length G1 F200 E10 ;extrude 10mm of feed stock G92 E0 ;zero the extruded length again G1 F200 E-{retraction_dual_amount} T0 ;Switch to the first extruder G92 E0 ;zero the extruded length G1 F200 E10 ;extrude 10mm of feed stock G92 E0 ;zero the extruded length again G1 F{travel_speed} ;Put printing message on LCD screen M117 Printing... end3.gcode = ;End GCode M104 T0 S0 ;extruder heater off M104 T1 S0 ;extruder heater off M104 T2 S0 ;extruder heater off M140 S0 ;heated bed heater off (if you have it) G91 ;relative positioning G1 E-1 F300 ;retract the filament a bit before lifting the nozzle, to release some of the pressure G1 Z+0.5 E-5 X-20 Y-20 F{travel_speed} ;move Z up a bit and retract filament even more G28 X0 Y0 ;move X/Y to min endstops, so the head is out of the way M84 ;steppers off G90 ;absolute positioning ;{profile_string} start4.gcode = ;Sliced at: {day} {date} {time} ;Basic settings: Layer height: {layer_height} Walls: {wall_thickness} Fill: {fill_density} ;Print time: {print_time} ;Filament used: {filament_amount}m {filament_weight}g ;Filament cost: {filament_cost} ;M190 S{print_bed_temperature} ;Uncomment to add your own bed temperature line ;M104 S{print_temperature} ;Uncomment to add your own temperature line ;M109 T2 S{print_temperature2} ;Uncomment to add your own temperature line ;M109 T1 S{print_temperature2} ;Uncomment to add your own temperature line ;M109 T0 S{print_temperature} ;Uncomment to add your own temperature line G21 ;metric values G90 ;absolute positioning M107 ;start with the fan off G28 X0 Y0 ;move X/Y to min endstops G28 Z0 ;move Z to min endstops G1 Z15.0 F{travel_speed} ;move the platform down 15mm T3 ;Switch to the 4th extruder G92 E0 ;zero the extruded length G1 F200 E10 ;extrude 10mm of feed stock G92 E0 ;zero the extruded length again G1 F200 E-{retraction_dual_amount} T2 ;Switch to the 3rd extruder G92 E0 ;zero the extruded length G1 F200 E10 ;extrude 10mm of feed stock G92 E0 ;zero the extruded length again G1 F200 E-{retraction_dual_amount} T1 ;Switch to the 2nd extruder G92 E0 ;zero the extruded length G1 F200 E10 ;extrude 10mm of feed stock G92 E0 ;zero the extruded length again G1 F200 E-{retraction_dual_amount} T0 ;Switch to the first extruder G92 E0 ;zero the extruded length G1 F200 E10 ;extrude 10mm of feed stock G92 E0 ;zero the extruded length again G1 F{travel_speed} ;Put printing message on LCD screen M117 Printing... end4.gcode = ;End GCode M104 T0 S0 ;extruder heater off M104 T1 S0 ;extruder heater off M104 T2 S0 ;extruder heater off M104 T3 S0 ;extruder heater off M140 S0 ;heated bed heater off (if you have it) G91 ;relative positioning G1 E-1 F300 ;retract the filament a bit before lifting the nozzle, to release some of the pressure G1 Z+0.5 E-5 X-20 Y-20 F{travel_speed} ;move Z up a bit and retract filament even more G28 X0 Y0 ;move X/Y to min endstops, so the head is out of the way M84 ;steppers off G90 ;absolute positioning ;{profile_string} support_start.gcode = support_end.gcode = cool_start.gcode = cool_end.gcode = replace.csv = preswitchextruder.gcode = ;Switch between the current extruder and the next extruder, when printing with multiple extruders. ;This code is added before the T(n) postswitchextruder.gcode = ;Switch between the current extruder and the next extruder, when printing with multiple extruders. ;This code is added after the T(n)
Running: /usr/share/cura/CuraEngine -v -p -s initialSpeedupLayers=4 -s minimalFeedrate=10 -s preSwitchExtruderCode=;Switch between the current extruder and the next extruder, when printing with multiple extruders. ;This code is added before the T(n) -s supportXYDistance=700 -s insetXSpeed=20 -s retractionZHop=0 -s extruderOffset[3].X=0 -s extruderOffset[3].Y=0 -s postSwitchExtruderCode=;Switch between the current extruder and the next extruder, when printing with multiple extruders. ;This code is added after the T(n) -s retractionSpeed=40 -s filamentFlow=100 -s infillOverlap=15 -s inset0Speed=30 -s coolHeadLift=0 -s extrusionWidth=399 -s upSkinCount=5 -s initialLayerSpeed=20 -s minimalLayerTime=5 -s infillSpeed=30 -s supportExtruder=-1 -s fanSpeedMax=100 -s supportType=1 -s enableCombing=1 -s fanSpeedMin=100 -s supportZDistance=150 -s supportEverywhere=0 -s filamentDiameter=1750 -s initialLayerThickness=300 -s supportAngle=-1 -s fanFullOnLayerNr=1 -s extruderOffset[1].X=-30000 -s extruderOffset[1].Y=0 -s layerThickness=200 -s endCode=;End GCode M104 S0 ;extruder heater off M140 S0 ;heated bed heater off (if you have it) G91 ;relative positioning G1 E-1 F300 ;retract the filament a bit before lifting the nozzle, to release some of the pressure G1 Z+0.5 E-5 X-20 Y-20 F3000 ;move Z up a bit and retract filament even more G28 X0 Y0 ;move X/Y to min endstops, so the head is out of the way M84 ;steppers off G90 ;absolute positioning ;CURA_PROFILE_STRING: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 -s minimalExtrusionBeforeRetraction=20 -s retractionMinimalDistance=1500 -s objectSink=0 -s retractionAmount=4500 -s skinSpeed=30 -s skirtLineCount=20 -s startCode=M92 E120.000000 M190 S70.000000 M109 S210.000000 ;Sliced at: Sat 03-10-2015 12:12:44 ;Basic settings: Layer height: 0.2 Walls: 1.2 Fill: 20 ;Print time: #P_TIME# ;Filament used: #F_AMNT#m #F_WGHT#g ;Filament cost: #F_COST# ;M190 S70 ;Uncomment to add your own bed temperature line ;M109 S210 ;Uncomment to add your own temperature line G21 ;metric values G90 ;absolute positioning M82 ;set extruder to absolute mode M107 ;start with the fan off G28 X0 Y0 ;move X/Y to min endstops G28 Z0 ;move Z to min endstops G1 Z15.0 F3000 ;move the platform down 15mm G92 E0 ;zero the extruded length G1 F200 E3 ;extrude 3mm of feed stock G92 E0 ;zero the extruded length again G1 F3000 ;Put printing message on LCD screen M117 Printing... -s skirtDistance=0 -s extruderOffset[2].Y=0 -s extruderOffset[2].X=0 -s perimeterBeforeInfill=0 -s printSpeed=50 -s fixHorrible=1 -s layer0extrusionWidth=400 -s moveSpeed=50 -s supportLineDistance=2666 -s retractionAmountExtruderSwitch=16500 -s sparseInfillLineDistance=2000 -s insetCount=3 -s downSkinCount=5 -s multiVolumeOverlap=150 -g 49674 -s posx=22584 -s posy=24974 $ Cura_SteamEngine version 15.04.2 Copyright (C) 2014 David Braam This program is free software: you can redistribute it and/or modify it under the terms of the GNU Affero General Public License as published by the Free Software Foundation, either version 3 of the License, or (at your option) any later version. This program is distributed in the hope that it will be useful, but WITHOUT ANY WARRANTY; without even the implied warranty of MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the GNU Affero General Public License for more details. You should have received a copy of the GNU Affero General Public License along with this program. If not, see [www.gnu.org]. Default config 'default.cfg' not used Reading mesh from socket with 146580 vertexes
Re: Quando la Cura non salva..... October 04, 2015 04:10AM |
Re: Quando la Cura non salva..... October 04, 2015 10:48AM |
