Re: MarlinKimbra 4.2 (e precedenti) mi stampa sempre inclinato ! November 02, 2015 08:25AM |
Re: MarlinKimbra 4.2 (e precedenti) mi stampa sempre inclinato ! November 02, 2015 12:35PM |
< 18:39:48: : N108 G29 V4 *121 < 18:39:48: : G29 Auto Bed Leveling < 18:40:14: : Eqn coefficients: a: -0.00319375 b: -0.00121875 d: 3.04012393 < 18:40:14: : Mean of sampled points: 2.51062488 < 18:40:14: : Bed Height Topography: < 18:40:14: : +-----------+ < 18:40:14: : |...Back....| < 18:40:14: : |Left..Right| < 18:40:14: : |...Front...| < 18:40:14: : +-----------+ < 18:40:14: : +0.07938 -0.32312 < 18:40:14: : +0.55938 -0.31562 < 18:40:14: : planeNormal x: 0.003194 y: 0.001219 z: 1.000000 < 18:40:14: : Bed Level Correction Matrix: < 18:40:14: : +0.999995 +0.000000 -0.003194 < 18:40:14: : -0.000004 +0.999999 -0.001219 < 18:40:14: : +0.003194 +0.001219 +0.999994Questo il mio M49
< 18:45:26: : M49 Z-Probe Repeatability test < 18:46:29: Mean: 2.611000 < 18:46:29: Standard Deviation: 0.004500Mago cosa mi suggerisci? inoltre cosa è successo alla ramps?
Re: MarlinKimbra 4.2 (e precedenti) mi stampa sempre inclinato ! November 02, 2015 03:31PM |
Re: MarlinKimbra 4.2 (e precedenti) mi stampa sempre inclinato ! November 03, 2015 02:19AM |
si ma mi aiuti ad usarlo sto file?Quote
MagoKimbra
Puoi provare con questo file... E salva tutto il log di G29 v4 e attaccalo come file....
Re: MarlinKimbra 4.2 (e precedenti) mi stampa sempre inclinato ! November 03, 2015 02:29AM |
Re: MarlinKimbra 4.2 (e precedenti) mi stampa sempre inclinato ! November 03, 2015 02:47AM |
Re: MarlinKimbra 4.2 (e precedenti) mi stampa sempre inclinato ! November 03, 2015 04:08AM |
Arduino:1.5.8 (Mac OS X), Scheda:"Arduino Mega or Mega 2560, ATmega2560 (Mega 2560)"Quote
MagoKimbra
lo devi mettere nel fw al posto dell'altro....
Re: MarlinKimbra 4.2 (e precedenti) mi stampa sempre inclinato ! November 03, 2015 05:00PM |
Re: MarlinKimbra 4.2 (e precedenti) mi stampa sempre inclinato ! November 03, 2015 05:30PM |
Re: MarlinKimbra 4.2 (e precedenti) mi stampa sempre inclinato ! November 04, 2015 04:30AM |
Ma il G29 V4 l'ho fatto! Vedi sopra!Quote
MagoKimbra
Ma hai la versione 4.1.2 allora nulla...
Mi devi fare un g29 v4 completo...
< 17:14:42: : N61 G28 *4 < 17:15:08: : N62 M105 *51 < 17:15:08: : N63 G29 V4 *69 < 17:15:08: : G29 Auto Bed Leveling < 17:15:34: : Eqn coefficients: a: -0.00259375 b: -0.00200625 d: 3.11012339 < 17:15:34: : Mean of sampled points: 2.55812501 < 17:15:34: : Bed Height Topography: < 17:15:34: : +-----------+ < 17:15:34: : |...Back....| < 17:15:34: : |Left..Right| < 17:15:34: : |...Front...| < 17:15:34: : +-----------+ < 17:15:34: : -0.11313 -0.28813 < 17:15:34: : +0.63188 -0.23062 < 17:15:34: : planeNormal x: 0.002594 y: 0.002006 z: 1.000000 < 17:15:34: : Bed Level Correction Matrix: < 17:15:34: : +0.999997 +0.000000 -0.002594 < 17:15:34: : -0.000005 +0.999998 -0.002006 < 17:15:34: : +0.002594 +0.002006 +0.999995
Re: MarlinKimbra 4.2 (e precedenti) mi stampa sempre inclinato ! November 06, 2015 04:16PM |
Re: MarlinKimbra 4.2 (e precedenti) mi stampa sempre inclinato ! November 07, 2015 03:33AM |
Quindi innanzitutto vorrei conferma del fatto che rimango con la 4.1.2. invece di installare la 4.2(cosa che ho provato a fare ma mi fa cose strane con gli step per mm di Z)Quote
MagoKimbra
Scusami ma sono stato un po incasinato per lavoro..
Ti dico fai la version G29 completa perché sono abituato alla nuova versione del fw... La versione 4.1.2 non ha problemi di bed leveling quindi vediamo se riusciamo a uscirne..
Da qui vedi subito che il bed è iclinato verso il basso proprio nell'angolo in alto a destra..
Vedi che nell'angolo in basso a sinistra è più alto rispetto all'angolo in alto a destra...
Per verificare meglio prova ad alzare il piano di molto e vedere i valori come cambiano e poi vedere come reagisce a tali valori...
< 09:30:07: : N332 G29 V4 *114 < 09:30:07: : G29 Auto Bed Leveling < 09:30:33: : Eqn coefficients: a: -0.00388749 b: -0.00256250 d: 2.88774871 < 09:30:33: : Mean of sampled points: 2.11374998 < 09:30:33: : Bed Height Topography: < 09:30:33: : +-----------+ < 09:30:33: : |...Back....| < 09:30:33: : |Left..Right| < 09:30:33: : |...Front...| < 09:30:33: : +-----------+ < 09:30:33: : +0.14375 -0.65625 < 09:30:33: : +0.63375 -0.12125 < 09:30:33: : planeNormal x: 0.003887 y: 0.002562 z: 1.000000 < 09:30:33: : Bed Level Correction Matrix: < 09:30:33: : +0.999992 +0.000000 -0.003887 < 09:30:33: : -0.000010 +0.999997 -0.002562 < 09:30:33: : +0.003887 +0.002562 +0.999989
Re: MarlinKimbra 4.2 (e precedenti) mi stampa sempre inclinato ! November 07, 2015 03:49AM |
Re: MarlinKimbra 4.2 (e precedenti) mi stampa sempre inclinato ! November 07, 2015 04:11AM |
il piatto lo avevo alzato su tutti e quattro gli angoli!!Quote
MagoKimbra
Hai alzato il piano a sinistra o a destra?
Fai questa prova dopo aver fatto g29 lascia il nozzle a 2/3 mm dal piatto e spostati a destra e a sinistra e vedi se segue l'inclinazione che hai messo del piano..
Re: MarlinKimbra 4.2 (e precedenti) mi stampa sempre inclinato ! November 07, 2015 04:40AM |
Re: MarlinKimbra 4.2 (e precedenti) mi stampa sempre inclinato ! November 07, 2015 04:48AM |
scusa non ho capito!Quote
MagoKimbra
No non mi sono spiegato bene vorrei che tu simulassi con il piano una forte inclinazione destra sinistra tipo a sinistra basso e a destra altissimo...
In modo da verificare che quando il nozzle si sposta da sinistra a destra si alzi di conseguenza... Poi la stessa prova con Y...
Re: MarlinKimbra 4.2 (e precedenti) mi stampa sempre inclinato ! November 07, 2015 05:22AM |
Re: MarlinKimbra 4.2 (e precedenti) mi stampa sempre inclinato ! November 07, 2015 05:25AM |
Re: MarlinKimbra 4.2 (e precedenti) mi stampa sempre inclinato ! November 07, 2015 05:48AM |
ok, si ho provato sia inclinando a dx che a sx e funziona tutto regolarmente, dopo aver fatto il G29 quando muovo il nozzle lungo x la z compensa seguendone l'andamento!Quote
MagoKimbra
No so dove sto sbagliando a farmi capire....
- Allora inclina il piano tipo a sinistra basso e a destra alto bastano 2/3 mm di differenza...
- Fai il g29
- Dopo di che metti il nozzle a 2 mm dal piano e ti sposti da sinistra vestro destra per vedere se segue l'inclinazione
- fatto cio se la segue, fai la stessa cosa su Y
- Metti il piano basso davanti e alto dietro
- fai il G29
- Sposti il nozzle avanti verso dietro e vedi se segue l'inclinazione
Senza stampare il tutto solo con i movimenti... Quando fai il G29 il nozzle dovrebbe muoversi di Z per compensare il dislivello del piano se non lo fa o lo fa all'incontrario allora c'è un problema...
Re: MarlinKimbra 4.2 (e precedenti) mi stampa sempre inclinato ! November 07, 2015 06:11AM |
si ma visto che ora lo zero ora l'ho posizionato correttamente avanti a sinistra della stampante e il problema me lo da lo stesso volevo intendere che il problema che ho non è un caso di stampa specchiata ma è un'altra cosa!!Quote
MagoKimbra
Ma stiamo parlando della stessa cosa o mi sono perso qualcosa???
Mi sembra di capire che a te dopo il G29 ti schiaccia da una parte il pezzo, invece di salire scende... Questo accade quando i punti vengono presi su una matrice ma specchiata su un'asse... Ecco cosa centra...
Re: MarlinKimbra 4.2 (e precedenti) mi stampa sempre inclinato ! November 08, 2015 09:55AM |
Re: MarlinKimbra 4.2 (e precedenti) mi stampa sempre inclinato ! November 08, 2015 10:21AM |
Re: MarlinKimbra 4.2 (e precedenti) mi stampa sempre inclinato ! November 08, 2015 11:05AM |
;move Z to min endstops G1 Z15.0 F7800 ;move the platform down 15mm
Re: MarlinKimbra 4.2 (e precedenti) mi stampa sempre inclinato ! November 08, 2015 01:35PM |
si in effetti questa non l'avevo vista ma facendo una prova sembra che la situazione non cambi!Quote
MagoKimbra
eccolo la:
Togli questa riga!!!!
Re: MarlinKimbra 4.2 (e precedenti) mi stampa sempre inclinato ! November 08, 2015 01:55PM |
Re: MarlinKimbra 4.2 (e precedenti) mi stampa sempre inclinato ! November 08, 2015 02:10PM |
mi stampa staccato solo per i perimetri esterni (quelli non relativi alla stampa vera e propria) E' questa cosa l'anomalia che ti dicevo (che non capisco a cosa sia dovuta ne quantomeno se sia proprio questo il problema!!)Quote
MagoKimbra
Può essere che la lacca dia fastidio... Un'altra cosa che da fastidio al pibot è la temperatura del piano...
Se ti stampa staccato è sicuramente un offset sbagliato.. Prima di ogni altra cosa fai sempre la verifica a mano, fai il g29, dopo che ha finito ti sposti al centro con G1 X100 Y100 Z0 e verifichi con il solito sistema se il nozzle è sul piano o meno.. Altrimenti regoli l'offset con M666 P...
Re: MarlinKimbra 4.2 (e precedenti) mi stampa sempre inclinato ! November 08, 2015 02:39PM |
Re: MarlinKimbra 4.2 (e precedenti) mi stampa sempre inclinato ! November 08, 2015 03:45PM |
....e lo so che è strano!!Quote
MagoKimbra
Ma guarda che è strana sta cosa...
Per ora secondo me ti conviene cercare di livellare il più possibile il piano e usare il pibot solo per fare la home...
Re: MarlinKimbra 4.2 (e precedenti) mi stampa sempre inclinato ! November 08, 2015 04:22PM |
Re: MarlinKimbra 4.2 (e precedenti) mi stampa sempre inclinato ! November 08, 2015 04:33PM |
