MarlinKimbra 4.2 (e precedenti) mi stampa sempre inclinato ! October 15, 2015 01:39PM |
Eqn coefficients: a: -0.00172222 b: 0.00127777 d: 8.26950263 21:25:23.312 : echo: planeNormal x: 0.001722 y: -0.001278 z: 1.000000 21:25:23.312 : echo: set_bed_level_equation_lsq > current_position: (259.99, 260.01, 8.09) 21:25:23.312 : echo: Bed Level Correction Matrix: 21:25:23.327 : echo: +0.999999 +0.000000 -0.001722 21:25:23.327 : echo: +0.000002 +0.999999 +0.001278 21:25:23.327 : echo: +0.001722 -0.001278 +0.999998mentra M48 mi da questo risultato:
22:08:20.024 : Mean: 7.807250 22:08:20.024 : Standard Deviation: 0.011803
#define LEFT_PROBE_BED_POSITION 71
#define RIGHT_PROBE_BED_POSITION 311
#define FRONT_PROBE_BED_POSITION 20
#define BACK_PROBE_BED_POSITION 260
#define XY_TRAVEL_SPEED 10000
#define AUTO_BED_LEVELING_FEATURE
#define Z_PROBE_REPEATABILITY_TEST
#define AUTO_BED_LEVELING_GRID
#define MIN_PROBE_EDGE 10 // The probe square sides can be no smaller than this
#define AUTO_BED_LEVELING_GRID_POINTS 3
#define ABL_PROBE_PT_1_X 15
#define ABL_PROBE_PT_1_Y 180
#define ABL_PROBE_PT_2_X 15
#define ABL_PROBE_PT_2_Y 20
#define ABL_PROBE_PT_3_X 170
#define ABL_PROBE_PT_3_Y 20
#define X_PROBE_OFFSET_FROM_EXTRUDER 51 // Probe on: -left +right
#define Y_PROBE_OFFSET_FROM_EXTRUDER 0 // Probe on: -front +behind
#define Z_PROBE_OFFSET_FROM_EXTRUDER -7.77 // -below (always!)
#define Z_RAISE_BEFORE_HOMING 1 // (in mm) Raise Z before homing (G28) for Probe Clearance.
#define Z_RAISE_BEFORE_PROBING 6 //How much the extruder will be raised before travelling to the first probing point.
#define Z_RAISE_BETWEEN_PROBINGS 5 //How much the extruder will be raised when travelling from between next probing points
#define Z_RAISE_AFTER_PROBING 5 //How much the extruder will be raised after the last probing point.
Re: MarlinKimbra 4.2 mi stampa sempre inclinato ! October 15, 2015 03:50PM |
Re: MarlinKimbra 4.2 mi stampa sempre inclinato ! October 15, 2015 04:06PM |
Re: MarlinKimbra 4.2 (e precedenti) mi stampa sempre inclinato ! October 15, 2015 05:53PM |
Re: MarlinKimbra 4.2 (e precedenti) mi stampa sempre inclinato ! October 16, 2015 02:39AM |
Re: MarlinKimbra 4.2 (e precedenti) mi stampa sempre inclinato ! October 16, 2015 02:51AM |
08:48:04.172 : echo: setup_for_endstop_move > enable_endstops(false) 08:48:04.557 : echo: setup_for_endstop_move > enable_endstops(true) 08:48:05.006 : echo: > TRIGGER ENDSTOP > current_position: (20.00, 13.00, 0.00) 08:48:05.006 : echo: set_axis_is_at_home 2 > (home_offset[axis]==0.00) > current_position: (20.00, 13.00, 8.21) 08:48:05.006 : echo: > AFTER set_axis_is_at_home > current_position: (20.00, 13.00, 8.21) 08:48:05.006 : echo: <<< homeaxis(2) 08:48:05.006 : echo: <<< Z_SAFE_HOMING 08:48:05.021 : echo: setup_for_endstop_move > enable_endstops(false) 08:48:05.021 : echo: <<< gcode_G28 08:48:05.021 : N32 M105 *54 08:48:05.488 : N33 M105 *55 08:48:08.547 : N34 M105 *48 08:48:11.615 : N35 M105 *49 08:48:14.678 : N36 M105 *50 08:48:14.975 : N37 G29 V4 *68 08:48:14.975 : echo: gcode_G29 >>> 08:48:14.975 : echo: G29 Auto Bed Leveling 08:48:14.990 : echo: setup_for_endstop_move > enable_endstops(true) 08:48:14.990 : echo: z_before = (before) 6.00 08:48:14.990 : echo: probe_pt >>> 08:48:14.990 : echo: > ProbeAction:1 > current_position: (20.00, 13.00, 8.21) 08:48:14.990 : echo: Z Raise to z_before 6.00 > do_blocking_move_to_z 6.00 08:48:15.006 : echo: do_blocking_move_to: (20.00, 13.00, 6.00) 08:48:15.006 : echo: > do_blocking_move_to_xy 20.00, 20.00 08:48:15.006 : echo: do_blocking_move_to: (20.00, 20.00, 6.00) 08:48:15.115 : echo: > ProbeDeploy 08:48:15.131 : echo: deploy_z_probe > current_position: (20.00, 20.00, 6.00) 08:48:15.959 : echo: run_z_probe > current_position: (20.00, 20.00, 8.18) 08:48:15.975 : echo: Bed X: 71.000 Y: 20.000 Z: 8.180 08:48:15.975 : echo: <<< probe_pt 08:48:15.975 : echo: z_before = (between) 13.18 08:48:15.975 : echo: probe_pt >>> 08:48:15.990 : echo: > ProbeAction:0 > current_position: (20.00, 20.00, 8.18) 08:48:15.990 : echo: Z Raise to z_before 13.18 > do_blocking_move_to_z 13.18 08:48:15.990 : echo: do_blocking_move_to: (20.00, 20.00, 13.18) 08:48:16.756 : echo: > do_blocking_move_to_xy 80.00, 20.00 08:48:16.756 : echo: do_blocking_move_to: (80.00, 20.00, 13.18) 08:48:18.834 : echo: run_z_probe > current_position: (80.00, 20.00, 7.25) 08:48:18.834 : echo: Bed X: 131.000 Y: 20.000 Z: 7.250 08:48:18.834 : echo: <<< probe_pt 08:48:18.850 : echo: z_before = (between) 12.25 08:48:18.850 : echo: probe_pt >>> 08:48:18.850 : echo: > ProbeAction:0 > current_position: (80.00, 20.00, 7.25) 08:48:18.865 : echo: Z Raise to z_before 12.25 > do_blocking_move_to_z 12.25 08:48:18.865 : echo: do_blocking_move_to: (80.00, 20.00, 12.25) 08:48:19.631 : echo: > do_blocking_move_to_xy 140.00, 20.00 08:48:19.631 : echo: do_blocking_move_to: (140.00, 20.00, 12.25) 08:48:21.548 : echo: run_z_probe > current_position: (140.00, 20.00, 7.53) 08:48:21.564 : echo: Bed X: 191.000 Y: 20.000 Z: 7.535 08:48:21.564 : echo: <<< probe_pt 08:48:21.564 : echo: z_before = (between) 12.53 08:48:21.564 : echo: probe_pt >>> 08:48:21.564 : echo: > ProbeAction:0 > current_position: (140.00, 20.00, 7.53) 08:48:21.579 : echo: Z Raise to z_before 12.53 > do_blocking_move_to_z 12.53 08:48:21.579 : echo: do_blocking_move_to: (140.00, 20.00, 12.53) 08:48:22.351 : echo: > do_blocking_move_to_xy 200.00, 20.00 08:48:22.355 : echo: do_blocking_move_to: (200.00, 20.00, 12.53) 08:48:24.290 : echo: run_z_probe > current_position: (200.00, 20.00, 7.71) 08:48:24.293 : echo: Bed X: 251.000 Y: 20.000 Z: 7.710 08:48:24.293 : echo: <<< probe_pt 08:48:24.297 : echo: z_before = (between) 12.71 08:48:24.301 : echo: probe_pt >>> 08:48:24.305 : echo: > ProbeAction:0 > current_position: (200.00, 20.00, 7.71) 08:48:24.309 : echo: Z Raise to z_before 12.71 > do_blocking_move_to_z 12.71 08:48:24.313 : echo: do_blocking_move_to: (200.00, 20.00, 12.71) 08:48:25.076 : echo: > do_blocking_move_to_xy 260.00, 20.00 08:48:25.076 : echo: do_blocking_move_to: (260.00, 20.00, 12.71) 08:48:27.109 : echo: run_z_probe > current_position: (260.00, 20.00, 8.10) 08:48:27.109 : echo: Bed X: 311.000 Y: 20.000 Z: 8.105 08:48:27.109 : echo: <<< probe_pt 08:48:27.125 : echo: z_before = (between) 13.10 08:48:27.125 : echo: probe_pt >>> 08:48:27.125 : echo: > ProbeAction:0 > current_position: (260.00, 20.00, 8.10) 08:48:27.125 : echo: Z Raise to z_before 13.10 > do_blocking_move_to_z 13.10 08:48:27.140 : echo: do_blocking_move_to: (260.00, 20.00, 13.10) 08:48:27.895 : echo: > do_blocking_move_to_xy 260.00, 80.00 08:48:27.910 : echo: do_blocking_move_to: (260.00, 80.00, 13.10) 08:48:29.854 : echo: run_z_probe > current_position: (260.00, 80.00, 8.21) 08:48:29.854 : echo: Bed X: 311.000 Y: 80.000 Z: 8.210 08:48:29.854 : echo: <<< probe_pt 08:48:29.854 : echo: z_before = (between) 13.21 08:48:29.854 : echo: probe_pt >>> 08:48:29.854 : echo: > ProbeAction:0 > current_position: (260.00, 80.00, 8.21) 08:48:29.869 : echo: Z Raise to z_before 13.21 > do_blocking_move_to_z 13.21 08:48:29.869 : echo: do_blocking_move_to: (260.00, 80.00, 13.21) 08:48:30.640 : echo: > do_blocking_move_to_xy 200.00, 80.00 08:48:30.640 : echo: do_blocking_move_to: (200.00, 80.00, 13.21) 08:48:32.680 : echo: run_z_probe > current_position: (200.00, 80.00, 7.98) 08:48:32.680 : echo: Bed X: 251.000 Y: 80.000 Z: 7.980 08:48:32.680 : echo: <<< probe_pt 08:48:32.680 : echo: z_before = (between) 12.98 08:48:32.680 : echo: probe_pt >>> 08:48:32.696 : echo: > ProbeAction:0 > current_position: (200.00, 80.00, 7.98) 08:48:32.696 : echo: Z Raise to z_before 12.98 > do_blocking_move_to_z 12.98 08:48:32.696 : echo: do_blocking_move_to: (200.00, 80.00, 12.98) 08:48:33.463 : echo: > do_blocking_move_to_xy 140.00, 80.00 08:48:33.463 : echo: do_blocking_move_to: (140.00, 80.00, 12.98) 08:48:35.408 : echo: run_z_probe > current_position: (140.00, 80.00, 8.10) 08:48:35.423 : echo: Bed X: 191.000 Y: 80.000 Z: 8.100 08:48:35.423 : echo: <<< probe_pt 08:48:35.423 : echo: z_before = (between) 13.10 08:48:35.423 : echo: probe_pt >>> 08:48:35.423 : echo: > ProbeAction:0 > current_position: (140.00, 80.00, 8.10) 08:48:35.439 : echo: Z Raise to z_before 13.10 > do_blocking_move_to_z 13.10 08:48:35.439 : echo: do_blocking_move_to: (140.00, 80.00, 13.10) 08:48:36.206 : echo: > do_blocking_move_to_xy 80.00, 80.00 08:48:36.206 : echo: do_blocking_move_to: (80.00, 80.00, 13.10) 08:48:38.316 : echo: run_z_probe > current_position: (80.00, 80.00, 7.32) 08:48:38.320 : echo: Bed X: 131.000 Y: 80.000 Z: 7.325 08:48:38.320 : echo: <<< probe_pt 08:48:38.324 : echo: z_before = (between) 12.32 08:48:38.324 : echo: probe_pt >>> 08:48:38.332 : echo: > ProbeAction:0 > current_position: (80.00, 80.00, 7.32) 08:48:38.337 : echo: Z Raise to z_before 12.32 > do_blocking_move_to_z 12.32 08:48:38.343 : echo: do_blocking_move_to: (80.00, 80.00, 12.32) 08:48:39.102 : echo: > do_blocking_move_to_xy 20.00, 80.00 08:48:39.106 : echo: do_blocking_move_to: (20.00, 80.00, 12.32) 08:48:40.896 : echo: run_z_probe > current_position: (20.00, 80.00, 8.67) 08:48:40.896 : echo: Bed X: 71.000 Y: 80.000 Z: 8.665 08:48:40.896 : echo: <<< probe_pt 08:48:40.896 : echo: z_before = (between) 13.67 08:48:40.896 : echo: probe_pt >>> 08:48:40.911 : echo: > ProbeAction:0 > current_position: (20.00, 80.00, 8.67) 08:48:40.911 : echo: Z Raise to z_before 13.67 > do_blocking_move_to_z 13.67 08:48:40.911 : echo: do_blocking_move_to: (20.00, 80.00, 13.67) 08:48:41.687 : echo: > do_blocking_move_to_xy 20.00, 140.00 08:48:41.691 : echo: do_blocking_move_to: (20.00, 140.00, 13.67) 08:48:43.640 : echo: run_z_probe > current_position: (20.00, 140.00, 8.74) 08:48:43.640 : echo: Bed X: 71.000 Y: 140.000 Z: 8.743 08:48:43.640 : echo: <<< probe_pt 08:48:43.640 : echo: z_before = (between) 13.74 08:48:43.640 : echo: probe_pt >>> 08:48:43.640 : echo: > ProbeAction:0 > current_position: (20.00, 140.00, 8.74) 08:48:43.655 : echo: Z Raise to z_before 13.74 > do_blocking_move_to_z 13.74 08:48:43.655 : echo: do_blocking_move_to: (20.00, 140.00, 13.74) 08:48:44.468 : echo: > do_blocking_move_to_xy 80.00, 140.00 08:48:44.468 : echo: do_blocking_move_to: (80.00, 140.00, 13.74) 08:48:46.593 : echo: run_z_probe > current_position: (80.00, 140.00, 7.51) 08:48:46.598 : echo: Bed X: 131.000 Y: 140.000 Z: 7.515 08:48:46.598 : echo: <<< probe_pt 08:48:46.602 : echo: z_before = (between) 12.51 08:48:46.602 : echo: probe_pt >>> 08:48:46.610 : echo: > ProbeAction:0 > current_position: (80.00, 140.00, 7.51) 08:48:46.614 : echo: Z Raise to z_before 12.51 > do_blocking_move_to_z 12.51 08:48:46.618 : echo: do_blocking_move_to: (80.00, 140.00, 12.51) 08:48:47.380 : echo: > do_blocking_move_to_xy 140.00, 140.00 08:48:47.380 : echo: do_blocking_move_to: (140.00, 140.00, 12.51) 08:48:49.278 : echo: run_z_probe > current_position: (140.00, 140.00, 8.21) 08:48:49.281 : echo: Bed X: 191.000 Y: 140.000 Z: 8.208 08:48:49.285 : echo: <<< probe_pt 08:48:49.285 : echo: z_before = (between) 13.21 08:48:49.289 : echo: probe_pt >>> 08:48:49.293 : echo: > ProbeAction:0 > current_position: (140.00, 140.00, 8.21) 08:48:49.297 : echo: Z Raise to z_before 13.21 > do_blocking_move_to_z 13.21 08:48:49.305 : echo: do_blocking_move_to: (140.00, 140.00, 13.21) 08:48:50.063 : echo: > do_blocking_move_to_xy 200.00, 140.00 08:48:50.063 : echo: do_blocking_move_to: (200.00, 140.00, 13.21) 08:48:51.988 : echo: run_z_probe > current_position: (200.00, 140.00, 8.75) 08:48:51.992 : echo: Bed X: 251.000 Y: 140.000 Z: 8.748 08:48:51.997 : echo: <<< probe_pt 08:48:51.997 : echo: z_before = (between) 13.75 08:48:52.001 : echo: probe_pt >>> 08:48:52.005 : echo: > ProbeAction:0 > current_position: (200.00, 140.00, 8.75) 08:48:52.013 : echo: Z Raise to z_before 13.75 > do_blocking_move_to_z 13.75 08:48:52.015 : echo: do_blocking_move_to: (200.00, 140.00, 13.75) 08:48:52.767 : echo: > do_blocking_move_to_xy 260.00, 140.00 08:48:52.783 : echo: do_blocking_move_to: (260.00, 140.00, 13.75) 08:48:54.727 : echo: run_z_probe > current_position: (260.00, 140.00, 8.73) 08:48:54.743 : echo: Bed X: 311.000 Y: 140.000 Z: 8.732 08:48:54.743 : echo: <<< probe_pt 08:48:54.743 : echo: z_before = (between) 13.73 08:48:54.743 : echo: probe_pt >>> 08:48:54.759 : echo: > ProbeAction:0 > current_position: (260.00, 140.00, 8.73) 08:48:54.759 : echo: Z Raise to z_before 13.73 > do_blocking_move_to_z 13.73 08:48:54.759 : echo: do_blocking_move_to: (260.00, 140.00, 13.73) 08:48:55.523 : echo: > do_blocking_move_to_xy 260.00, 200.00 08:48:55.523 : echo: do_blocking_move_to: (260.00, 200.00, 13.73) 08:48:57.584 : echo: run_z_probe > current_position: (260.00, 200.00, 8.27) 08:48:57.588 : echo: Bed X: 311.000 Y: 200.000 Z: 8.270 08:48:57.589 : echo: <<< probe_pt 08:48:57.592 : echo: z_before = (between) 13.27 08:48:57.593 : echo: probe_pt >>> 08:48:57.598 : echo: > ProbeAction:0 > current_position: (260.00, 200.00, 8.27) 08:48:57.598 : echo: Z Raise to z_before 13.27 > do_blocking_move_to_z 13.27 08:48:57.598 : echo: do_blocking_move_to: (260.00, 200.00, 13.27) 08:48:58.366 : echo: > do_blocking_move_to_xy 200.00, 200.00 08:48:58.366 : echo: do_blocking_move_to: (200.00, 200.00, 13.27) 08:49:00.285 : echo: run_z_probe > current_position: (200.00, 200.00, 8.58) 08:49:00.301 : echo: Bed X: 251.000 Y: 200.000 Z: 8.583 08:49:00.301 : echo: <<< probe_pt 08:49:00.301 : echo: z_before = (between) 13.58 08:49:00.301 : echo: probe_pt >>> 08:49:00.301 : echo: > ProbeAction:0 > current_position: (200.00, 200.00, 8.58) 08:49:00.317 : echo: Z Raise to z_before 13.58 > do_blocking_move_to_z 13.58 08:49:00.317 : echo: do_blocking_move_to: (200.00, 200.00, 13.58) 08:49:01.089 : echo: > do_blocking_move_to_xy 140.00, 200.00 08:49:01.089 : echo: do_blocking_move_to: (140.00, 200.00, 13.58) 08:49:03.184 : echo: run_z_probe > current_position: (140.00, 200.00, 7.84) 08:49:03.189 : echo: Bed X: 191.000 Y: 200.000 Z: 7.843 08:49:03.193 : echo: <<< probe_pt 08:49:03.193 : echo: z_before = (between) 12.84 08:49:03.196 : echo: probe_pt >>> 08:49:03.196 : echo: > ProbeAction:0 > current_position: (140.00, 200.00, 7.84) 08:49:03.196 : echo: Z Raise to z_before 12.84 > do_blocking_move_to_z 12.84 08:49:03.196 : echo: do_blocking_move_to: (140.00, 200.00, 12.84) 08:49:03.971 : echo: > do_blocking_move_to_xy 80.00, 200.00 08:49:03.971 : echo: do_blocking_move_to: (80.00, 200.00, 12.84) 08:49:05.961 : echo: run_z_probe > current_position: (80.00, 200.00, 7.65) 08:49:05.965 : echo: Bed X: 131.000 Y: 200.000 Z: 7.650 08:49:05.965 : echo: <<< probe_pt 08:49:05.969 : echo: z_before = (between) 12.65 08:49:05.973 : echo: probe_pt >>> 08:49:05.977 : echo: > ProbeAction:0 > current_position: (80.00, 200.00, 7.65) 08:49:05.981 : echo: Z Raise to z_before 12.65 > do_blocking_move_to_z 12.65 08:49:05.985 : echo: do_blocking_move_to: (80.00, 200.00, 12.65) 08:49:06.812 : echo: > do_blocking_move_to_xy 20.00, 200.00 08:49:06.812 : echo: do_blocking_move_to: (20.00, 200.00, 12.65) 08:49:08.627 : echo: run_z_probe > current_position: (20.00, 200.00, 8.88) 08:49:08.627 : echo: Bed X: 71.000 Y: 200.000 Z: 8.880 08:49:08.627 : echo: <<< probe_pt 08:49:08.627 : echo: z_before = (between) 13.88 08:49:08.627 : echo: probe_pt >>> 08:49:08.627 : echo: > ProbeAction:0 > current_position: (20.00, 200.00, 8.88) 08:49:08.642 : echo: Z Raise to z_before 13.88 > do_blocking_move_to_z 13.88 08:49:08.642 : echo: do_blocking_move_to: (20.00, 200.00, 13.88) 08:49:09.414 : echo: > do_blocking_move_to_xy 20.00, 260.00 08:49:09.414 : echo: do_blocking_move_to: (20.00, 260.00, 13.88) 08:49:11.335 : echo: run_z_probe > current_position: (20.00, 260.00, 9.20) 08:49:11.335 : echo: Bed X: 71.000 Y: 260.000 Z: 9.200 08:49:11.335 : echo: <<< probe_pt 08:49:11.335 : echo: z_before = (between) 14.20 08:49:11.335 : echo: probe_pt >>> 08:49:11.350 : echo: > ProbeAction:0 > current_position: (20.00, 260.00, 9.20) 08:49:11.350 : echo: Z Raise to z_before 14.20 > do_blocking_move_to_z 14.20 08:49:11.350 : echo: do_blocking_move_to: (20.00, 260.00, 14.20) 08:49:12.118 : echo: > do_blocking_move_to_xy 80.00, 260.00 08:49:12.118 : echo: do_blocking_move_to: (80.00, 260.00, 14.20) 08:49:14.344 : echo: run_z_probe > current_position: (80.00, 260.00, 7.75) 08:49:14.346 : echo: Bed X: 131.000 Y: 260.000 Z: 7.745 08:49:14.349 : echo: <<< probe_pt 08:49:14.349 : echo: z_before = (between) 12.75 08:49:14.349 : echo: probe_pt >>> 08:49:14.349 : echo: > ProbeAction:0 > current_position: (80.00, 260.00, 7.75) 08:49:14.349 : echo: Z Raise to z_before 12.75 > do_blocking_move_to_z 12.75 08:49:14.365 : echo: do_blocking_move_to: (80.00, 260.00, 12.75) 08:49:15.131 : echo: > do_blocking_move_to_xy 140.00, 260.00 08:49:15.131 : echo: do_blocking_move_to: (140.00, 260.00, 12.75) 08:49:17.097 : echo: run_z_probe > current_position: (140.00, 260.00, 7.69) 08:49:17.097 : echo: Bed X: 191.000 Y: 260.000 Z: 7.685 08:49:17.097 : echo: <<< probe_pt 08:49:17.097 : echo: z_before = (between) 12.68 08:49:17.097 : echo: probe_pt >>> 08:49:17.113 : echo: > ProbeAction:0 > current_position: (140.00, 260.00, 7.69) 08:49:17.113 : echo: Z Raise to z_before 12.68 > do_blocking_move_to_z 12.68 08:49:17.113 : echo: do_blocking_move_to: (140.00, 260.00, 12.68) 08:49:17.958 : echo: > do_blocking_move_to_xy 200.00, 260.00 08:49:17.973 : echo: do_blocking_move_to: (200.00, 260.00, 12.68) 08:49:19.912 : echo: run_z_probe > current_position: (200.00, 260.00, 7.89) 08:49:19.912 : echo: Bed X: 251.000 Y: 260.000 Z: 7.888 08:49:19.921 : echo: <<< probe_pt 08:49:19.926 : echo: z_before = (between) 12.89 08:49:19.926 : echo: probe_pt >>> 08:49:19.930 : echo: > ProbeAction:2 > current_position: (200.00, 260.00, 7.89) 08:49:19.938 : echo: Z Raise to z_before 12.89 > do_blocking_move_to_z 12.89 08:49:19.942 : echo: do_blocking_move_to: (200.00, 260.00, 12.89) 08:49:20.704 : echo: > do_blocking_move_to_xy 260.00, 260.00 08:49:20.704 : echo: do_blocking_move_to: (260.00, 260.00, 12.89) 08:49:22.648 : echo: run_z_probe > current_position: (260.00, 260.00, 7.94) 08:49:22.664 : echo: > ProbeStow (stow_z_probe will do Z Raise) 08:49:22.664 : echo: stow_z_probe > current_position: (260.00, 260.00, 7.94) 08:49:22.664 : echo: Bed X: 311.000 Y: 260.000 Z: 7.943 08:49:22.664 : echo: <<< probe_pt 08:49:22.679 : echo: > probing complete > current_position: (260.00, 260.00, 7.94) 08:49:22.679 : echo: setup_for_endstop_move > enable_endstops(false) 08:49:22.711 : echo: Eqn coefficients: a: -0.00046416 b: 0.00143501 d: 7.99535417 08:49:22.711 : echo: planeNormal x: 0.000464 y: -0.001435 z: 1.000000 08:49:22.726 : echo: set_bed_level_equation_lsq > current_position: (260.00, 260.01, 7.69) 08:49:22.726 : echo: +-----------+ 08:49:22.726 : echo: |...Back....| 08:49:22.726 : echo: |Left..Right| 08:49:22.726 : echo: |...Front...| 08:49:22.726 : echo: +-----------+ 08:49:22.742 : echo: Measured Bed Topography: 08:49:22.742 : echo: +9.20000 +7.74500 +7.68500 +7.88750 +7.94250 08:49:22.742 : echo: +8.88000 +7.65000 +7.84250 +8.58250 +8.27000 08:49:22.757 : echo: +8.74250 +7.51500 +8.20750 +8.74750 +8.73250 08:49:22.757 : echo: +8.66500 +7.32500 +8.10000 +7.98000 +8.21000 08:49:22.757 : echo: +8.18000 +7.25000 +7.53500 +7.71000 +8.10500 08:49:22.772 : echo: Corrected Bed Topography: 08:49:22.776 : echo: +1.95000 +0.49500 +0.43500 +0.63750 +0.69250 08:49:22.781 : echo: +1.63000 +0.40000 +0.59250 +1.33250 +1.02000 08:49:22.785 : echo: +1.49250 +0.26500 +0.95750 +1.49750 +1.48250 08:49:22.789 : echo: +1.41500 +0.07500 +0.85000 +0.73000 +0.96000 08:49:22.797 : echo: +0.93000 +0.00000 +0.28500 +0.46000 +0.85500 08:49:22.801 : echo: Corrected Bed Topography in new coordinates: 08:49:22.805 : echo: +1.58885 +0.16170 +0.12955 +0.35990 +0.44275 08:49:22.809 : echo: +1.35495 +0.15280 +0.37315 +1.14100 +0.85635 08:49:22.813 : echo: +1.30355 +0.10390 +0.82425 +1.39210 +1.40495 08:49:22.815 : echo: +1.31215 +0.00000 +0.80285 +0.71070 +0.96855 08:49:22.827 : echo: +0.91325 +0.01110 +0.32395 +0.52680 +0.94965 08:49:22.827 : echo: Height from Bed to Nozzle 08:49:22.831 : echo: (+) above, or (-) below surface : 08:49:22.835 : echo: +0.00000 +1.42715 +1.45930 +1.22895 +1.14610 08:49:22.843 : echo: +0.23390 +1.43605 +1.21570 +0.44785 +0.73250 08:49:22.847 : echo: +0.28530 +1.48495 +0.76460 +0.19675 +0.18390 08:49:22.851 : echo: +0.27670 +1.58885 +0.78600 +0.87815 +0.62030 08:49:22.855 : echo: +0.67560 +1.57775 +1.26490 +1.06205 +0.63920 08:49:22.859 : echo: Bed Level Correction Matrix: 08:49:22.863 : echo: +1.000000 +0.000000 -0.000464 08:49:22.868 : echo: +0.000001 +0.999999 +0.001435 08:49:22.868 : echo: +0.000464 -0.001435 +0.999999 08:49:22.875 : echo: > AFTER apply_rotation_xyz > current_position[Z_AXIS]= 7.06390 08:49:22.876 : echo: <<< gcode_G29 08:49:22.879 : N38 M105 *60 08:49:22.879 : echo: X:260.00 Y:260.01 Z:7.06 E:0.00 Count X: 260.00 Y:260.00 Z:7.32 08:49:25.254 : N39 M105 *61
Re: MarlinKimbra 4.2 (e precedenti) mi stampa sempre inclinato ! October 16, 2015 03:30AM |
Re: MarlinKimbra 4.2 (e precedenti) mi stampa sempre inclinato ! October 16, 2015 12:57PM |
Re: MarlinKimbra 4.2 (e precedenti) mi stampa sempre inclinato ! October 16, 2015 05:41PM |
09:25:30.907 : echo: Corrected Bed Topography: 09:25:30.911 : echo: +2.16500 +0.47500 +0.38250 +0.27750 +0.33500 09:25:30.915 : echo: +2.03250 +0.45000 +0.52250 +1.24750 +0.57250 09:25:30.919 : echo: +1.86000 +0.28000 +0.57500 +1.50500 +1.09500 09:25:30.927 : echo: +1.87250 +0.23250 +0.77250 +0.50250 +0.48000 09:25:30.931 : echo: +1.10500 +0.09750 +0.00000 +0.09500 +0.35250Cmq il problema che hai te normalmente accade quando si ha uno degli assi rovesciato e quindi la matrice viene specchiata come i pezzi...
Re: MarlinKimbra 4.2 (e precedenti) mi stampa sempre inclinato ! October 16, 2015 05:49PM |
Re: MarlinKimbra 4.2 (e precedenti) mi stampa sempre inclinato ! October 16, 2015 06:09PM |
Re: MarlinKimbra 4.2 (e precedenti) mi stampa sempre inclinato ! October 16, 2015 06:14PM |
Re: MarlinKimbra 4.2 (e precedenti) mi stampa sempre inclinato ! October 17, 2015 03:40AM |
Re: MarlinKimbra 4.2 (e precedenti) mi stampa sempre inclinato ! October 17, 2015 05:06AM |
11:11:57.612 : N30 G29 V4 *67 11:11:57.612 : echo: gcode_G29 >>> 11:11:57.612 : echo: G29 Auto Bed Leveling 11:11:57.612 : echo: setup_for_endstop_move > enable_endstops(true) 11:11:57.627 : echo: z_before = (before) 6.00 11:11:57.627 : echo: probe_pt >>> 11:11:57.627 : echo: > ProbeAction:1 > current_position: (20.00, 20.00, 7.49) 11:11:57.627 : echo: Z Raise to z_before 6.00 > do_blocking_move_to_z 6.00 11:11:57.643 : echo: do_blocking_move_to: (20.00, 20.00, 6.00) 11:11:57.643 : echo: > do_blocking_move_to_xy 20.00, 20.00 11:11:57.643 : echo: do_blocking_move_to: (20.00, 20.00, 6.00) 11:11:57.643 : echo: > ProbeDeploy 11:11:57.658 : echo: deploy_z_probe > current_position: (20.00, 20.00, 6.00) 11:11:58.362 : echo: run_z_probe > current_position: (20.00, 20.00, 7.52) 11:11:58.377 : echo: Bed X: 71.000 Y: 20.000 Z: 7.520 11:11:58.377 : echo: <<< probe_pt 11:11:58.377 : echo: z_before = (between) 12.52 11:11:58.377 : echo: probe_pt >>> 11:11:58.377 : echo: > ProbeAction:0 > current_position: (20.00, 20.00, 7.52) 11:11:58.393 : echo: Z Raise to z_before 12.52 > do_blocking_move_to_z 12.52 11:11:58.393 : echo: do_blocking_move_to: (20.00, 20.00, 12.52) 11:11:59.158 : echo: > do_blocking_move_to_xy 140.00, 20.00 11:11:59.158 : echo: do_blocking_move_to: (140.00, 20.00, 12.52) 11:12:01.415 : echo: run_z_probe > current_position: (140.00, 20.00, 7.09) 11:12:01.415 : echo: Bed X: 191.000 Y: 20.000 Z: 7.095 11:12:01.415 : echo: <<< probe_pt 11:12:01.431 : echo: z_before = (between) 12.09 11:12:01.431 : echo: probe_pt >>> 11:12:01.431 : echo: > ProbeAction:0 > current_position: (140.00, 20.00, 7.09) 11:12:01.431 : echo: Z Raise to z_before 12.09 > do_blocking_move_to_z 12.09 11:12:01.447 : echo: do_blocking_move_to: (140.00, 20.00, 12.09) 11:12:02.212 : echo: > do_blocking_move_to_xy 260.00, 20.00 11:12:02.212 : echo: do_blocking_move_to: (260.00, 20.00, 12.09) 11:12:04.337 : echo: run_z_probe > current_position: (260.00, 20.00, 7.62) 11:12:04.353 : echo: Bed X: 311.000 Y: 20.000 Z: 7.618 11:12:04.353 : echo: <<< probe_pt 11:12:04.353 : echo: z_before = (between) 12.62 11:12:04.353 : echo: probe_pt >>> 11:12:04.353 : echo: > ProbeAction:0 > current_position: (260.00, 20.00, 7.62) 11:12:04.368 : echo: Z Raise to z_before 12.62 > do_blocking_move_to_z 12.62 11:12:04.368 : echo: do_blocking_move_to: (260.00, 20.00, 12.62) 11:12:05.125 : echo: > do_blocking_move_to_xy 260.00, 140.00 11:12:05.141 : echo: do_blocking_move_to: (260.00, 140.00, 12.62) 11:12:07.328 : echo: run_z_probe > current_position: (260.00, 140.00, 7.87) 11:12:07.328 : echo: Bed X: 311.000 Y: 140.000 Z: 7.870 11:12:07.344 : echo: <<< probe_pt 11:12:07.344 : echo: z_before = (between) 12.87 11:12:07.344 : echo: probe_pt >>> 11:12:07.344 : echo: > ProbeAction:0 > current_position: (260.00, 140.00, 7.87) 11:12:07.360 : echo: Z Raise to z_before 12.87 > do_blocking_move_to_z 12.87 11:12:07.360 : echo: do_blocking_move_to: (260.00, 140.00, 12.87) 11:12:08.122 : echo: > do_blocking_move_to_xy 140.00, 140.00 11:12:08.122 : echo: do_blocking_move_to: (140.00, 140.00, 12.87) 11:12:10.408 : echo: run_z_probe > current_position: (140.00, 140.00, 7.27) 11:12:10.408 : echo: Bed X: 191.000 Y: 140.000 Z: 7.268 11:12:10.408 : echo: <<< probe_pt 11:12:10.408 : echo: z_before = (between) 12.27 11:12:10.408 : echo: probe_pt >>> 11:12:10.424 : echo: > ProbeAction:0 > current_position: (140.00, 140.00, 7.27) 11:12:10.424 : echo: Z Raise to z_before 12.27 > do_blocking_move_to_z 12.27 11:12:10.424 : echo: do_blocking_move_to: (140.00, 140.00, 12.27) 11:12:11.190 : echo: > do_blocking_move_to_xy 20.00, 140.00 11:12:11.190 : echo: do_blocking_move_to: (20.00, 140.00, 12.27) 11:12:13.373 : echo: run_z_probe > current_position: (20.00, 140.00, 7.38) 11:12:13.388 : echo: Bed X: 71.000 Y: 140.000 Z: 7.378 11:12:13.388 : echo: <<< probe_pt 11:12:13.388 : echo: z_before = (between) 12.38 11:12:13.388 : echo: probe_pt >>> 11:12:13.404 : echo: > ProbeAction:0 > current_position: (20.00, 140.00, 7.38) 11:12:13.404 : echo: Z Raise to z_before 12.38 > do_blocking_move_to_z 12.38 11:12:13.404 : echo: do_blocking_move_to: (20.00, 140.00, 12.38) 11:12:14.170 : echo: > do_blocking_move_to_xy 20.00, 260.00 11:12:14.170 : echo: do_blocking_move_to: (20.00, 260.00, 12.38) 11:12:16.377 : echo: run_z_probe > current_position: (20.00, 260.00, 7.42) 11:12:16.377 : echo: Bed X: 71.000 Y: 260.000 Z: 7.418 11:12:16.377 : echo: <<< probe_pt 11:12:16.377 : echo: z_before = (between) 12.42 11:12:16.377 : echo: probe_pt >>> 11:12:16.392 : echo: > ProbeAction:0 > current_position: (20.00, 260.00, 7.42) 11:12:16.392 : echo: Z Raise to z_before 12.42 > do_blocking_move_to_z 12.42 11:12:16.392 : echo: do_blocking_move_to: (20.00, 260.00, 12.42) 11:12:17.158 : echo: > do_blocking_move_to_xy 140.00, 260.00 11:12:17.158 : echo: do_blocking_move_to: (140.00, 260.00, 12.42) 11:12:19.459 : echo: run_z_probe > current_position: (140.00, 260.00, 6.69) 11:12:19.459 : echo: Bed X: 191.000 Y: 260.000 Z: 6.693 11:12:19.459 : echo: <<< probe_pt 11:12:19.459 : echo: z_before = (between) 11.69 11:12:19.459 : echo: probe_pt >>> 11:12:19.475 : echo: > ProbeAction:2 > current_position: (140.00, 260.00, 6.69) 11:12:19.475 : echo: Z Raise to z_before 11.69 > do_blocking_move_to_z 11.69 11:12:19.475 : echo: do_blocking_move_to: (140.00, 260.00, 11.69) 11:12:20.241 : echo: > do_blocking_move_to_xy 260.00, 260.00 11:12:20.241 : echo: do_blocking_move_to: (260.00, 260.00, 11.69) 11:12:22.381 : echo: run_z_probe > current_position: (260.00, 260.00, 7.16) 11:12:22.397 : echo: > ProbeStow (stow_z_probe will do Z Raise) 11:12:22.397 : echo: stow_z_probe > current_position: (260.00, 260.00, 7.16) 11:12:22.397 : echo: Bed X: 311.000 Y: 260.000 Z: 7.163 11:12:22.413 : echo: <<< probe_pt 11:12:22.413 : echo: > probing complete > current_position: (260.00, 260.00, 7.16) 11:12:22.413 : echo: setup_for_endstop_move > enable_endstops(false) 11:12:22.428 : echo: Eqn coefficients: a: 0.00046528 b: -0.00133334 d: 7.43335628 11:12:22.428 : echo: planeNormal x: -0.000465 y: 0.001333 z: 1.000000 11:12:22.444 : echo: set_bed_level_equation_lsq > current_position: (260.00, 259.99, 7.39) 11:12:22.444 : echo: +-----------+ 11:12:22.444 : echo: |...Back....| 11:12:22.444 : echo: |Left..Right| 11:12:22.444 : echo: |...Front...| 11:12:22.459 : echo: +-----------+ 11:12:22.459 : echo: Measured Bed Topography: 11:12:22.459 : echo: +7.41750 +6.69250 +7.16250 11:12:22.459 : echo: +7.37750 +7.26750 +7.87000 11:12:22.459 : echo: +7.52000 +7.09500 +7.61750 11:12:22.459 : echo: Corrected Bed Topography: 11:12:22.475 : echo: +0.72500 +0.00000 +0.47000 11:12:22.475 : echo: +0.68500 +0.57500 +1.17750 11:12:22.475 : echo: +0.82750 +0.40250 +0.92500 11:12:22.475 : echo: Corrected Bed Topography in new coordinates: 11:12:22.475 : echo: +0.78083 +0.00000 +0.41417 11:12:22.491 : echo: +0.58083 +0.41500 +0.96166 11:12:22.491 : echo: +0.56333 +0.08250 +0.54916 11:12:22.491 : echo: Height from Bed to Nozzle 11:12:22.491 : echo: (+) above, or (-) below surface : 11:12:22.506 : echo: +0.18083 +0.96166 +0.54750 11:12:22.506 : echo: +0.38083 +0.54667 +0.00000 11:12:22.506 : echo: +0.39833 +0.87917 +0.41250 11:12:22.506 : echo: Bed Level Correction Matrix: 11:12:22.506 : echo: +1.000000 +0.000000 +0.000465 11:12:22.522 : echo: +0.000001 +0.999999 -0.001333 11:12:22.522 : echo: -0.000465 +0.001333 +0.999999 11:12:22.522 : echo: > AFTER apply_rotation_xyz > current_position[Z_AXIS]= 6.94250 11:12:22.522 : echo: <<< gcode_G29 11:12:22.538 : ok X:260.00 Y:259.99 Z:6.94 E:0.00 Count X: 260.00 Y:260.00 Z:6.72 11:12:22.538 : echo: X:260.00 Y:259.99 Z:6.94 E:0.00 Count X: 260.00 Y:260.00 Z:6.72 11:12:22.538 : ok
Re: MarlinKimbra 4.2 (e precedenti) mi stampa sempre inclinato ! October 17, 2015 05:45AM |
Re: MarlinKimbra 4.2 (e precedenti) mi stampa sempre inclinato ! October 17, 2015 05:46AM |
MagoKimbra
Ecco lo sapevo!!!
Ricapitoliamo per vedere se ci siamo capiti... L'endstop Y è dietro?
Se invece è davanti verso di te è sbagliato che sia un Ymin ma deve essere un Ymax. Il mio consiglio è spostarlo dietro senza cambiare nulla. Inoltre rimetti false a inverter asse Y...
Re: MarlinKimbra 4.2 (e precedenti) mi stampa sempre inclinato ! October 17, 2015 07:02AM |
//#define ENDSTOPPULLUPS #if DISABLED(ENDSTOPPULLUPS) // fine endstop settings: Individual pullups. will be ignored if ENDSTOPPULLUPS is defined #define ENDSTOPPULLUP_XMIN #define ENDSTOPPULLUP_YMIN //#define ENDSTOPPULLUP_ZMIN #define ENDSTOPPULLUP_Z2MIN #define ENDSTOPPULLUP_XMAX #define ENDSTOPPULLUP_YMAX #define ENDSTOPPULLUP_ZMAX #define ENDSTOPPULLUP_Z2MAX #define ENDSTOPPULLUP_ZPROBE #define ENDSTOPPULLUP_EMIN #endif /*******
Re: MarlinKimbra 4.2 (e precedenti) mi stampa sempre inclinato ! October 31, 2015 04:46AM |
// coarse Endstop Settings
//#define ENDSTOPPULLUPS // Comment this out (using // at the start of the line) to disable the endstop pullup resistors
#ifndef ENDSTOPPULLUPS
//#define ENDSTOPPULLUP_ZPROBE
#endif
// Mechanical endstop with COM to ground and NC to Signal uses "false" here (most common setup).
#define X_MIN_ENDSTOP_LOGIC false // set to true to invert the logic of the endstop.
#define Y_MIN_ENDSTOP_LOGIC false // set to true to invert the logic of the endstop.
#define Z_MIN_ENDSTOP_LOGIC false // set to true to invert the logic of the endstop.
#define E_MIN_ENDSTOP_LOGIC false // set to true to invert the logic of the endstop.
#define X_MAX_ENDSTOP_LOGIC false // set to true to invert the logic of the endstop.
#define Y_MAX_ENDSTOP_LOGIC false // set to true to invert the logic of the endstop.
#define Z_MAX_ENDSTOP_LOGIC false // set to true to invert the logic of the endstop.
#define Z_PROBE_ENDSTOP_LOGIC false // set to true to invert the logic of the endstop.
// ENDSTOP SETTINGS:
// Sets direction of endstop when homing; 1=MAX, -1=MIN
#define X_HOME_DIR -1
#define Y_HOME_DIR -1
#define Z_HOME_DIR -1
#define E_HOME_DIR -1
#define min_software_endstops true // If true, axis won't move to coordinates less than HOME_POS.
#define max_software_endstops true // If true, axis won't move to coordinates greater than the defined lengths below.
#define X_ENABLE_ON 0
#define Y_ENABLE_ON 0
#define Z_ENABLE_ON 0
#define E_ENABLE_ON 0 // For all extruder
// Disables axis when it's not being used.
#define DISABLE_X false
#define DISABLE_Y false
#define DISABLE_Z false
#define DISABLE_E false // For all extruder
#define DISABLE_INACTIVE_EXTRUDER false //disable only inactive extruder and keep active extruder enabled
// Invert the stepper direction. Change (or reverse the motor connector) if an axis goes the wrong way.
#define INVERT_X_DIR false
#define INVERT_Y_DIR false
#define INVERT_Z_DIR false
#define INVERT_E0_DIR false
#define INVERT_E1_DIR false
#define INVERT_E2_DIR false
#define INVERT_E3_DIR false
// Travel limits after homing (units are in mm)
#define X_MAX_POS 270
#define X_MIN_POS 0
#define Y_MAX_POS 240
#define Y_MIN_POS 0
#define Z_MAX_POS 180
#define Z_MIN_POS 0
#define E_MIN_POS 0
//============================= Bed Manual or Auto Leveling ===========================
// set the rectangle in which to probe in manual or automatic
#define LEFT_PROBE_BED_POSITION 20
#define RIGHT_PROBE_BED_POSITION 220
#define BACK_PROBE_BED_POSITION 220
#define XY_TRAVEL_SPEED 10000 // X and Y axis travel speed between probes, in mm/min
//If you have enabled the Auto Bed Levelling and are using the same Z Probe for Z Homing,
//it is highly recommended you let this Z_SAFE_HOMING enabled!!!
//#define Z_SAFE_HOMING
#ifdef Z_SAFE_HOMING
#define Z_SAFE_HOMING_X_POINT (X_MAX_LENGTH/2) // X point for Z homing when homing all axis (G28) or homing Z
#define Z_SAFE_HOMING_Y_POINT (Y_MAX_LENGTH/2) // Y point for Z homing when homing all axis (G28) or homing Z
#endif
#define ENABLE_AUTO_BED_LEVELING // Delete the comment to enable (ABL)
#define Z_PROBE_REPEATABILITY_TEST // Delete the comment to enable
#ifdef ENABLE_AUTO_BED_LEVELING
// There are 2 different ways to specify probing locations
// - "grid" mode
// Probe several points in a rectangular grid.
// You specify the rectangle and the density of sample points.
// This mode is preferred because there are more measurements.
// - "3-point" mode
// Probe 3 arbitrary points on the bed (that aren't colinear)
// You specify the XY coordinates of all 3 points.
// Enable this to sample the bed in a grid (least squares solution)
// Note: this feature generates 10KB extra code size
#ifdef AUTO_BED_LEVELING_GRID
// Set the number of grid points per dimension
// You probably don't need more than 3 (squared=9)
#define AUTO_BED_LEVELING_GRID_POINTS 2
#else // not AUTO_BED_LEVELING_GRID
// Arbitrary points to probe. A simple cross-product
// is used to estimate the plane of the bed.
#define ABL_PROBE_PT_1_X 35
#define ABL_PROBE_PT_1_Y 250
#define ABL_PROBE_PT_2_X 35
#define ABL_PROBE_PT_2_Y 35
#define ABL_PROBE_PT_3_X 250
#define ABL_PROBE_PT_3_Y 35
#endif // AUTO_BED_LEVELING_GRID
// Offsets to the probe relative to the extruder tip (Hotend - Probe)
// X and Y offsets MUST be INTEGERS
#define X_PROBE_OFFSET_FROM_EXTRUDER 0 // Probe on: -left +right
#define Z_PROBE_OFFSET_FROM_EXTRUDER -3.3
// -below (always!)
#define Z_RAISE_BEFORE_HOMING 10 // (in mm) Raise Z before homing (G28) for Probe Clearance.
// Be sure you have this distance over your Z_MAX_POS in case
#define Z_RAISE_BEFORE_PROBING 10 // much the extruder will be raised before travelling to the first probing point.
#define Z_RAISE_BETWEEN_PROBINGS 10 // much the extruder will be raised when travelling from between next probing points
//#define Z_PROBE_SLED // turn on if you have a z-probe mounted on a sled like those designed by Charles Bell
//#define SLED_DOCKING_OFFSET 5 // the extra distance the X axis must travel to pick up the sled. 0 should be fine but you can push it further if you'd like.
//If defined, the Probe servo will be turned on only during movement and then turned off to avoid jerk
//The value is the delay to turn the servo off after powered on - depends on the servo speed; 300ms is good value, but you can try lower it.
//You MUST HAVE the SERVO ENDSTOPS defined to use here a value higher than zero otherwise your code will not compile.
#define PROBE_SERVO_DEACTIVATION_DELAY 300
// Support for a dedicated Z PROBE endstop separate from the Z MIN endstop.
// If you would like to use both a Z PROBE and a Z MIN endstop together or just a Z PROBE with a custom pin, uncomment #define Z_PROBE_ENDSTOP and read the instructions below.
// If you want to still use the Z min endstop for homing, disable Z_SAFE_HOMING above. Eg; to park the head outside the bed area when homing with G28.
// WARNING: The Z MIN endstop will need to set properly as it would without a Z PROBE to prevent head crashes and premature stopping during a print.
// To use a separte Z PROBE endstop, you must have a Z_PROBE_PIN defined in the pins.h file for your control board.
// If you are using a servo based Z PROBE, you will need to enable NUM_SERVOS, SERVO_ENDSTOPS and SERVO_ENDSTOPS_ANGLES in the R/C Servo below.
// WARNING: Setting the wrong pin may have unexpected and potentially disastrous outcomes. Use with caution and do your homework.
//#define Z_PROBE_ENDSTOP
#endif // ENABLE_AUTO_BED_LEVELING
Questo è invece quello che ottengo con G29 V4< 09:39:39: : N5170 G29 V4 *67 < 09:39:39: : G29 Auto Bed Leveling < 09:40:05: : Eqn coefficients: a: -0.00246249 b: 0.00003750 d: 3.42474865 < 09:40:05: : Mean of sampled points: 3.13374996 < 09:40:05: : Bed Height Topography: < 09:40:05: : +-----------+ < 09:40:05: : |...Back....| < 09:40:05: : |Left..Right| < 09:40:05: : |...Front...| < 09:40:05: : +-----------+ < 09:40:05: : +0.24875 -0.24125 < 09:40:05: : +0.24375 -0.25125 < 09:40:05: : planeNormal x: 0.002462 y: -0.000038 z: 1.000000 < 09:40:05: : Bed Level Correction Matrix: < 09:40:05: : +0.999997 +0.000000 -0.002462 < 09:40:05: : +0.000000 +1.000000 +0.000037 < 09:40:05: : +0.002462 -0.000038 +0.999997all'nizio credevo fosse un problema legato alla mancanza di planarità in z ma ho effettuato diverse prove anche senza sensore con il classico endstop su z e calibrando il piatto col foglio
< 09:54:02: : M49 Z-Probe Repeatability test < 09:55:05: Mean: 3.212750 < 09:55:05: Standard Deviation: 0.002358Resto in attesa di un riscontro da parte del mago o di qualcuno che magari ha avuto loo stesso problema e lo ha risolto
Re: MarlinKimbra 4.2 (e precedenti) mi stampa sempre inclinato ! November 01, 2015 08:00AM |
Re: MarlinKimbra 4.2 (e precedenti) mi stampa sempre inclinato ! November 01, 2015 02:29PM |
Ora un Pibot ma ho provato anche con un sensore induttivo e mi succedeva la stessa cosa!Quote
davdino81
Che sensore hai?
Re: MarlinKimbra 4.2 (e precedenti) mi stampa sempre inclinato ! November 01, 2015 03:22PM |
Re: MarlinKimbra 4.2 (e precedenti) mi stampa sempre inclinato ! November 02, 2015 03:44AM |
OkQuote
MagoKimbra
Sto passando un periodo un po incasinato per lavoro e altre cose cercate di capirmi se non riesco a star dietro a tutti...
L'origine degli assi cartesiani è questo:
Se guardiamo solo il piano X Y è questo:
Ok ci siamo...
Quindi in una core XY lo zero è davanti a sinistra... In una Cartesiana vedi prusa è X a sinistra e il carrello Y dietro in modo che il nozzle si trovi davanti...
Non è complicato....
Quindi mdcompositi che scrivi: I miei endstop x ed y sono a sinistra e dietro guardando la stampante che è una corexy
No è sbagliato l'endstop y deve essere davanti... altrimenti hai il piano y rovesciato e quindi ecco perché la matrice del autobed level viene specchiata...
Fatemi sapere....
//=========================================================================== //=============================Mechanical Settings=========================== //=========================================================================== // coarse Endstop Settings //#define ENDSTOPPULLUPS // Comment this out (using // at the start of the line) to disable the endstop pullup resistors #ifndef ENDSTOPPULLUPS // fine endstop settings: Individual pullups. will be ignored if ENDSTOPPULLUPS is defined #define ENDSTOPPULLUP_XMAX #define ENDSTOPPULLUP_YMAX #define ENDSTOPPULLUP_ZMAX #define ENDSTOPPULLUP_XMIN #define ENDSTOPPULLUP_YMIN //#define ENDSTOPPULLUP_ZMIN //#define ENDSTOPPULLUP_ZPROBE #define ENDSTOPPULLUP_EMIN #endif // Mechanical endstop with COM to ground and NC to Signal uses "false" here (most common setup). #define X_MIN_ENDSTOP_LOGIC true // set to true to invert the logic of the endstop. #define Y_MIN_ENDSTOP_LOGIC false // set to true to invert the logic of the endstop. #define Z_MIN_ENDSTOP_LOGIC false // set to true to invert the logic of the endstop. #define E_MIN_ENDSTOP_LOGIC false // set to true to invert the logic of the endstop. #define X_MAX_ENDSTOP_LOGIC false // set to true to invert the logic of the endstop. #define Y_MAX_ENDSTOP_LOGIC false // set to true to invert the logic of the endstop. #define Z_MAX_ENDSTOP_LOGIC false // set to true to invert the logic of the endstop. #define Z_PROBE_ENDSTOP_LOGIC false // set to true to invert the logic of the endstop. // ENDSTOP SETTINGS: // Sets direction of endstop when homing; 1=MAX, -1=MIN #define X_HOME_DIR -1 #define Y_HOME_DIR -1 #define Z_HOME_DIR -1 #define E_HOME_DIR -1 #define min_software_endstops true // If true, axis won't move to coordinates less than HOME_POS. #define max_software_endstops true // If true, axis won't move to coordinates greater than the defined lengths below. // For Inverting Stepper Enable Pins (Active Low) use 0, Non Inverting (Active High) use 1 #define X_ENABLE_ON 0 #define Y_ENABLE_ON 0 #define Z_ENABLE_ON 0 #define E_ENABLE_ON 0 // For all extruder // Disables axis when it's not being used. #define DISABLE_X false #define DISABLE_Y false #define DISABLE_Z false #define DISABLE_E false // For all extruder #define DISABLE_INACTIVE_EXTRUDER false //disable only inactive extruder and keep active extruder enabled // Invert the stepper direction. Change (or reverse the motor connector) if an axis goes the wrong way. #define INVERT_X_DIR true #define INVERT_Y_DIR true #define INVERT_Z_DIR false #define INVERT_E0_DIR false #define INVERT_E1_DIR false #define INVERT_E2_DIR false #define INVERT_E3_DIR false // Travel limits after homing (units are in mm) #define X_MAX_POS 270 #define X_MIN_POS 0 #define Y_MAX_POS 240 #define Y_MIN_POS 0 #define Z_MAX_POS 180 #define Z_MIN_POS 0 #define E_MIN_POS 0
Re: MarlinKimbra 4.2 (e precedenti) mi stampa sempre inclinato ! November 02, 2015 04:37AM |
Re: MarlinKimbra 4.2 (e precedenti) mi stampa sempre inclinato ! November 02, 2015 04:45AM |
se metto true quando faccio la home non la prende, va in avanti di un po e basta e invece non va piu indietro verso le x negative!!Quote
MagoKimbra
Perché hai questo??
#define X_HOME_DIR 1lo stesso nn funziona!!
Re: MarlinKimbra 4.2 (e precedenti) mi stampa sempre inclinato ! November 02, 2015 05:32AM |
Re: MarlinKimbra 4.2 (e precedenti) mi stampa sempre inclinato ! November 02, 2015 05:36AM |
Re: MarlinKimbra 4.2 (e precedenti) mi stampa sempre inclinato ! November 02, 2015 05:42AM |
Re: MarlinKimbra 4.2 (e precedenti) mi stampa sempre inclinato ! November 02, 2015 06:15AM |
ho cambiato l'endstop con uno nuovo!!Quote
MagoKimbra
E allora è un problema dell'endstop hai sempre un contatto chiuso a massa!!!! Se hai messo la logica a false altrimenti non chiude mai a massa se hai messo la logica a true...
Re: MarlinKimbra 4.2 (e precedenti) mi stampa sempre inclinato ! November 02, 2015 07:33AM |
Re: MarlinKimbra 4.2 (e precedenti) mi stampa sempre inclinato ! November 02, 2015 08:04AM |
avevo un'altro arduino di scorta e per velocizzare la cosa l'ho sostituito!Quote
MagoKimbra
Arduino secondo me... Sposta x min su xmax invertendo i pin...
/**************************************************************************************** * 33 * RAMPS 1.3 / 1.4 * RAMPS_13_EFB (Extruder, Fan, Bed) ****************************************************************************************/ #if MB(RAMPS_13_EF#define KNOWN_BOARD 1 #if !defined(__AVR_ATmega1280__) && !defined(__AVR_ATmega2560__) #error Oops! Make sure you have 'Arduino Mega' selected from the 'Tools -> Boards' menu. #endif #define LARGE_FLASH true //X axis pins #define ORIG_X_STEP_PIN 54 #define ORIG_X_DIR_PIN 55 #define ORIG_X_ENABLE_PIN 38 #define X_MIN_PIN 2 #define X_MAX_PIN 3
