G28 move Z-axis up too fast
Posted by randyf1965
October 18, 2015 03:03PM
I am having issues with the G28 command moving the Z-axis up in 20mm increments (the raise before homing value). The first move is faster than my steppers can move so they stall on my Prusa i3, running Ramps 1.4 with 8825 drivers.
I have changed the homing values, below are the settings from my configuration_overall.h
#define HOMING_FEEDRATE {150*60, 150*60, 300, 0}
#define MANUAL_FEEDRATE {100*60, 100*60, 300, 60}
#define DEFAULT_AXIS_STEPS_PER_UNIT {80, 80, 800, 94.1, 625, 625, 625}
#define MICROSTEP_MODES {16, 16, 32, 16}
#define MOTOR_CURRENT {1, 1, 1, 1, 1, 1, 1}
#define DEFAULT_MAX_FEEDRATE {5000, 5000, 100, 200, 100, 100, 100}
#define DEFAULT_MAX_ACCELERATION {1000, 1000, 100, 5000, 3000, 3000, 3000}
Edited 1 time(s). Last edit at 10/18/2015 03:05PM by randyf1965.
Re: G28 move Z-axis up too fast
October 21, 2015 09:26AM
You have too high values
My values are:
#define HOMING_FEEDRATE {50*60, 50*60, 10, 0}
#define MANUAL_FEEDRATE {100*60, 100*60, 20, 60}
Davide
Immagina e Crea
My Thingiverse
October 21, 2015 04:42PM
With feedrates set at 10 Z axis BARELY moves
October 21, 2015 09:17PM
I am running 8mm acme lead screw Tr8*8-4 from [openbuildspartstore.com]
November 20, 2015 09:36PM
Still having the same issues with the 1st G28 moving too fast and too far
November 26, 2015 08:20AM
I reflashed my controller and have a similar issue
Now it works the 1st time :
>>>G28
SENDING:G28
echo: gcode_G28 >>>
echo: setup_for_endstop_move > enable_endstops(true)
echo: Raise Z (before homing) by 5.00 > (home_all_axis || homeZ) > destination: (0.00, 0.00, 5.00)
echo: >>> homeaxis(0)
echo: setup_for_endstop_move > enable_endstops(false)
echo: > TRIGGER ENDSTOP > current_position: (0.00, 0.00, 0.00)
echo: set_axis_is_at_home 0 > (home_offset[axis]==0.00) > current_position: (0.00, 0.00, 0.00)
echo: > AFTER set_axis_is_at_home > current_position: (0.00, 0.00, 0.00)
echo: <<< homeaxis(0)
echo: > homeX: (0.00, 0.00, 0.00)
echo: >>> homeaxis(1)
echo: set_axis_is_at_home 1 > (home_offset[axis]==0.00) > current_position: (0.00, 0.00, 0.00)
echo: <<< homeaxis(1)
echo: > homeY: (0.00, 0.00, 0.00)
echo: >>> homeaxis(2)
echo: deploy_z_probe > current_position: (0.00, 0.00, 0.00)
echo: set_axis_is_at_home 2 > (home_offset[axis]==0.00) > current_position: (0.00, 0.00, 8.41)
echo: > AFTER set_axis_is_at_home > current_position: (0.00, 0.00, 8.41)
echo: > SERVO_LEVELING > stow_z_probe
echo: stow_z_probe > current_position: (0.00, 0.00, 8.41)
echo: Raise Z (after) by 5.00
echo: > SERVO_ENDSTOPS > do_blocking_move_to_z 13.41
echo: do_blocking_move_to: (0.00, 0.00, 13.41)
echo: <<< homeaxis(2)
echo: > (home_all_axis || homeZ) > final: (0.00, 0.00, 13.41)
But the 2nd time it moves down instead of up unless I do a G92 Z0:
>>>G28
SENDING:G28
echo: gcode_G28 >>>
echo: > TRIGGER ENDSTOP > current_position: (0.00, 0.00, 13.41)
echo: set_axis_is_at_home 0 > (home_offset[axis]==0.00) > current_position: (0.00, 0.00, 13.41)
echo: > AFTER set_axis_is_at_home > current_position: (0.00, 0.00, 13.41)
echo: > homeX: (0.00, 0.00, 13.41)
Reset.
echo: set_axis_is_at_home 1 > (home_offset[axis]==0.00) > current_position: (0.00, 0.00, 13.41)
echo: > homeY: (0.00, 0.00, 13.41)
start THIS IS WHERE I RESET since the extruder is trying to drive thru the hot bed
