MarlinKimbra Autocalibration Delta abbandonato December 08, 2015 09:07AM |
Re: MarlinKimbra Autocalibration Delta abbandonato December 08, 2015 10:47AM |
Re: MarlinKimbra Autocalibration Delta abbandonato December 08, 2015 11:42AM |
Re: MarlinKimbra Autocalibration Delta abbandonato December 10, 2015 11:04AM |
Re: MarlinKimbra Autocalibration Delta aggiornato February 24, 2016 11:46AM |
17:33:57.854 : Echo: -0.085 -0.101 -0.079 -0.056 0.061 0.010 -0.061 0.000 0.177 17:33:57.870 : Echo: -0.045 -0.054 -0.063 -0.011 0.041 -0.020 -0.025 0.022 0.074 17:33:57.870 : Echo: -0.005 -0.040 -0.046 0.034 0.021 -0.050 0.066 0.045 -0.030 17:33:57.870 : Echo: -0.023 -0.026 -0.030 -0.078 0.004 0.007 0.016 -0.033 -0.081 17:33:57.870 : Echo: -0.025 -0.086 -0.048 -0.020 0.039 0.060 -0.035 0.037 -0.036 17:33:57.870 : Echo: -0.007 -0.016 -0.025 -0.029 0.012 -0.004 -0.083 -0.033 -0.070 17:33:57.870 : Echo: -0.085 -0.019 -0.056 0.026 -0.059 0.020 -0.040 0.011 -0.030 17:33:57.885 : Echo: -0.005 -0.084 0.038 -0.070 -0.035 -0.070 -0.065 -0.061 0.043 17:33:57.885 : Echo: -0.011 0.004 -0.081 -0.066 -0.032 -0.041 -0.050 -0.159 -0.082
17:29:27.510 : Echo: Current Delta geometry values: 17:29:27.510 : Echo: X (Endstop Adj): 0.000 17:29:27.510 : Echo: Y (Endstop Adj): -3.421 17:29:27.510 : Echo: Z (Endstop Adj): -0.166 17:29:27.510 : Echo: P (Z-Probe Offset): X0.00 Y-10.00 Z-12.30 17:29:27.510 : Echo: A (Tower A Position Correction): 0.000 17:29:27.510 : Echo: B (Tower B Position Correction): 0.000 17:29:27.510 : Echo: C (Tower C Position Correction): 0.000 17:29:27.510 : Echo: I (Tower A Radius Correction): 0.000 17:29:27.510 : Echo: J (Tower B Radius Correction): 0.648 17:29:27.526 : Echo: K (Tower C Radius Correction): 0.000 17:29:27.526 : Echo: U (Tower A Diagonal Rod Correction): 0.000 17:29:27.526 : Echo: V (Tower B Diagonal Rod Correction): 0.000 17:29:27.526 : Echo: W (Tower C Diagonal Rod Correction): 0.000 17:29:27.526 : Echo: R (Delta Radius): 110.74 17:29:27.526 : Echo: D (Diagonal Rod Length): 217.00 17:29:27.526 : Echo: H (Z-Height): 210.07
Re: MarlinKimbra Autocalibration Delta aggiornato February 24, 2016 12:51PM |
...tra l'altro non lo stavi abbandonando l'autoclibrazione? Faresti una prova anche con il tuo calibratore online? Giusto per vedere se ci sono grosse differenze...
