MK 4.2.5 January 30, 2016 06:22AM |
Re: MK 4.2.5 January 30, 2016 09:01AM |
Re: MK 4.2.5 January 30, 2016 09:09AM |
la cartella su github si chaima ancor marlinKimbra
se da oggi si chiama MK partiamo dalle cartelle
...scherzo...|
Re: MK 4.2.5 January 30, 2016 09:14AM |
lamerhouse
allora .. prima considerazionela cartella su github si chaima ancor marlinKimbra
caricato su prusa i3 test iniziale assi tutto ok ..endstop ok .. motori ok, pibot ok
lanciata una stampa di 15 minuti vediamo ..
Re: MK 4.2.5 January 30, 2016 09:16AM |
maralb
EndStop che piacciano a Me?????
Eprom Veloce come Repetier?????
Re: MK 4.2.5 January 30, 2016 09:33AM |
In file included from sketch\base.h:44:0,
from X:\3d stampante\firmware_ok\MarlinKimbra-dev\MarlinKimbra\MarlinKimbra.ino:192:
sketch\module/sanitycheck.h:1459:10: error: #error DEPENDENCY ERROR: You must set Z_PROBE_PIN to a valid pin if you enable Z_PROBE_ENDSTOP
exit status 1
Errore durante la compilazione
sketch\module\MK_Main.cpp: In function 'void gcode_M0_M1()':
sketch\module\MK_Main.cpp:4191:9: error: 'IS_SD_PRINTING' was not declared in this scope
if (IS_SD_PRINTING)
exit status 1
Re: MK 4.2.5 January 30, 2016 09:48AM |
Re: MK 4.2.5 January 30, 2016 09:58AM |
In file included from sketch\module\lcd\ultralcd.cpp:44:0:
sketch\module\lcd\dogm_lcd_implementation.h:14:21: fatal error: ../base.h: No such file or directory
#include "../base.h"
compilation terminated.
exit status 1
Re: MK 4.2.5 January 30, 2016 10:18AM |
Re: MK 4.2.5 January 30, 2016 10:26AM |
C:\Program Files (x86)\Arduino\libraries\U8glib\utility\u8g_rot.c:48:1: warning: initialization from incompatible pointer type [enabled by default]
u8g_dev_t u8g_dev_rot = { u8g_dev_rot_dummy_fn, NULL, NULL };
C:\Program Files (x86)\Arduino\libraries\U8glib\utility\u8g_rot.c:48:1: warning: (near initialization for 'u8g_dev_rot.dev_fn') [enabled by default]
Re: MK 4.2.5 January 30, 2016 10:56AM |
Re: MK 4.2.5 January 30, 2016 11:06AM |
Re: MK 4.2.5 January 30, 2016 11:13AM |
Re: MK 4.2.5 January 30, 2016 12:46PM |
Re: MK 4.2.5 January 30, 2016 01:09PM |
Re: MK 4.2.5 January 30, 2016 01:39PM |
Re: MK 4.2.5 January 30, 2016 02:02PM |
Re: MK 4.2.5 January 30, 2016 06:09PM |
Re: MK 4.2.5 January 31, 2016 02:57AM |
Re: MK 4.2.5 January 31, 2016 05:29AM |
Re: MK 4.2.5 January 31, 2016 07:14AM |
Re: MK 4.2.5 January 31, 2016 07:27AM |
sketch\module\HAL.cpp:89:3: error: 'ring_buffer_tx' does not name a type
ring_buffer_tx tx_buffer = { { 0 }, 0, 0};
sketch\module\HAL.cpp: In function 'void rf_store_char(unsigned char, ring_buffer*)':
sketch\module\HAL.cpp:92:38: error: 'SERIAL_BUFFER_MASK' was not declared in this scope
uint8_t i = (buffer->head + 1) & SERIAL_BUFFER_MASK;
sketch\module\HAL.cpp: In function 'void __vector_26()':
sketch\module\HAL.cpp:153:13: error: 'tx_buffer' was not declared in this scope
if (tx_buffer.head == tx_buffer.tail) {
sketch\module\HAL.cpp:156:37: error: 'bit_clear' was not declared in this scope
bit_clear(UCSR0B, UDRIE0);
sketch\module\HAL.cpp:171:51: error: 'SERIAL_TX_BUFFER_MASK' was not declared in this scope
tx_buffer.tail = (tx_buffer.tail + 1) & SERIAL_TX_BUFFER_MASK;
sketch\module\HAL.cpp: At global scope:
sketch\module\HAL.cpp:262:62: error: 'ring_buffer_tx' has not been declared
MKHardwareSerial::MKHardwareSerial(ring_buffer *rx_buffer, ring_buffer_tx *tx_buffer,
sketch\module\HAL.cpp:262:3: error: prototype for 'MKHardwareSerial::MKHardwareSerial(ring_buffer*, int*, volatile uint8_t*, volatile uint8_t*, volatile uint8_t*, volatile uint8_t*, volatile uint8_t*, uint8_t, uint8_t, uint8_t, uint8_t, uint8_t)' does not match any in class 'MKHardwareSerial'
In file included from sketch\module\../module/HAL/HAL.h:76:0,
from sketch\module\../base.h:38,
from sketch\module\HAL.cpp:26:
sketch\module\../module/HAL/HardwareSerial.h:75:9: error: candidates are: constexpr MKHardwareSerial::MKHardwareSerial(MKHardwareSerial&&)
class MKHardwareSerial {
sketch\module\../module/HAL/HardwareSerial.h:75:9: error: constexpr MKHardwareSerial::MKHardwareSerial(const MKHardwareSerial&)
sketch\module\../module/HAL/HardwareSerial.h:77:7: error: MKHardwareSerial::MKHardwareSerial()
MKHardwareSerial();
sketch\module\HAL.cpp:283:8: error: prototype for 'void MKHardwareSerial::begin(long unsigned int)' does not match any in class 'MKHardwareSerial'
void MKHardwareSerial::begin(unsigned long baud) {
sketch\module\../module/HAL/HardwareSerial.h:78:12: error: candidate is: void MKHardwareSerial::begin(long int)
void begin(long);
sketch\module\HAL.cpp: In member function 'void MKHardwareSerial::end()':
sketch\module\HAL.cpp:331:12: error: '_tx_buffer' was not declared in this scope
while (_tx_buffer->head != _tx_buffer->tail)
sketch\module\HAL.cpp:334:16: error: '_ucsrb' was not declared in this scope
bit_clear(*_ucsrb, _rxen);
sketch\module\HAL.cpp:334:24: error: '_rxen' was not declared in this scope
sketch\module\HAL.cpp:334:29: error: 'bit_clear' was not declared in this scope
sketch\module\HAL.cpp:335:24: error: '_txen' was not declared in this scope
bit_clear(*_ucsrb, _txen);
sketch\module\HAL.cpp:336:24: error: '_rxcie' was not declared in this scope
bit_clear(*_ucsrb, _rxcie);
sketch\module\HAL.cpp:337:24: error: '_udrie' was not declared in this scope
bit_clear(*_ucsrb, _udrie);
sketch\module\HAL.cpp:343:5: error: '_rx_buffer' was not declared in this scope
_rx_buffer->head = _rx_buffer->tail;
sketch\module\HAL.cpp:346:7: error: redefinition of 'int MKHardwareSerial::available()'
int MKHardwareSerial::available(void) {
sketch\module\../module/HAL/HardwareSerial.h:84:24: error: 'int MKHardwareSerial::available()' previously defined here
FORCE_INLINE int available(void) {
sketch\module\HAL.cpp:350:42: error: no 'int MKHardwareSerial
utputUnused()' member function declared in class 'MKHardwareSerial'
utputUnused(void) {
sketch\module\HAL.cpp: In member function 'int MKHardwareSerial::peek()':
sketch\module\HAL.cpp:355:9: error: '_rx_buffer' was not declared in this scope
if (_rx_buffer->head == _rx_buffer->tail)
sketch\module\HAL.cpp:357:12: error: '_rx_buffer' was not declared in this scope
return _rx_buffer->buffer[_rx_buffer->tail];
sketch\module\HAL.cpp: In member function 'int MKHardwareSerial::read()':
sketch\module\HAL.cpp:362:9: error: '_rx_buffer' was not declared in this scope
if (_rx_buffer->head == _rx_buffer->tail) {
sketch\module\HAL.cpp:365:23: error: '_rx_buffer' was not declared in this scope
unsigned char c = _rx_buffer->buffer[_rx_buffer->tail];
sketch\module\HAL.cpp:366:49: error: 'SERIAL_BUFFER_MASK' was not declared in this scope
_rx_buffer->tail = (_rx_buffer->tail + 1) & SERIAL_BUFFER_MASK;
sketch\module\HAL.cpp: In member function 'void MKHardwareSerial::flush()':
sketch\module\HAL.cpp:371:12: error: '_tx_buffer' was not declared in this scope
while (_tx_buffer->head != _tx_buffer->tail);
sketch\module\HAL.cpp:382:5: error: prototype for 'size_t MKHardwareSerial::write(uint8_t)' does not match any in class 'MKHardwareSerial'
MKHardwareSerial::write(uint8_t c) {
sketch\module\../module/HAL/HardwareSerial.h:110:25: error: candidates are: void MKHardwareSerial::write(const uint8_t*, size_t)
FORCE_INLINE void write(const uint8_t *buffer, size_t size) { while (size--) write(*buffer++); }
sketch\module\../module/HAL/HardwareSerial.h:109:25: error: void MKHardwareSerial::write(const char*)
FORCE_INLINE void write(const char *str) { while (*str) write(*str++); }
sketch\module\../module/HAL/HardwareSerial.h:88:25: error: void MKHardwareSerial::write(uint8_t)
FORCE_INLINE void write(uint8_t c) {
sketch\module\HAL.cpp:408:44: error: 'tx_buffer' was not declared in this scope
MKHardwareSerial MKSerial(&rx_buffer, &tx_buffer, &UBRR0H, &UBRR0L, &UCSR0A, &UCSR0B, &UDR0, RXEN0, TXEN0, RXCIE0, UDRIE0, U2X0);
exit status 1
Re: MK 4.2.5 January 31, 2016 08:35AM |
Re: MK 4.2.5 January 31, 2016 08:44AM |
Re: MK 4.2.5 January 31, 2016 08:48AM |
Re: MK 4.2.5 January 31, 2016 08:56AM |
Re: MK 4.2.5 January 31, 2016 09:18AM |
15:14:00.027 : Info: Bed probe heights: 0.1875 0.2063 0.2125 0.1938 0.2062 mean 0.2013
15:14:03.011 : Info: Bed probe heights: 0.0250 0.0313 0.0313 0.0313 0.0375 mean 0.0313
15:14:06.104 : Info: Bed probe heights: -0.8812 -0.8812 -0.8812 -0.8812 -0.8875 mean -0.8825
15:14:09.479 : Info: Bed probe heights: 0.0500 0.0250 0.0313 0.0375 0.0188 mean 0.0325
15:14:12.432 : Info: Bed probe heights: 0.5125 0.5000 0.5125 0.5000 0.4938 mean 0.5038
15:14:15.370 : Info: Bed probe heights: -0.0250 0.0000 0.0000 -0.0062 -0.0562 mean -0.0175
15:14:18.839 : Info: Bed probe heights: 0.5625 0.5625 0.5688 0.5750 0.5688 mean 0.5675
15:14:22.136 : Info: Bed probe heights: 0.1938 0.2125 0.2125 0.2188 0.2125 mean 0.2100
15:14:22.136 : Echo: | Z-Tower Endstop Offsets
15:14:22.136 : Echo: | 0.0313 X:-1.5050 Y:-5.8537 Z:-0.6790
15:14:22.151 : Echo: | 0.5675 -0.8825 Tower Offsets
15:14:22.151 : Echo: | 0.2100 A:0.00 B:0.00 C:0.00
15:14:22.151 : Echo: | 0.0325 -0.0175 I:0.50 J:2.00 K:-3.00
15:14:22.151 : Echo: | 0.5038 Delta Radius: 177.0000
15:14:22.167 : Echo: | X-Tower Y-Tower Diagonal Rod: 288.0000
15:14:22.167 : Echo: Endstop adjustment complete
15:14:22.870 : Info: <<< gcode_G30
15:14:22.933 : Error: ;?????4??F??[??z???????X?z5g??]??#??0??d??8_?w?????????F?????w????????????Yz?N????Z?p??@k?e?6[V???[?????Y???????r??S}???????;??#??????n*M?~??????ru?O?.x?Kjv???S<|{????????O?{~?q?????]?I??&;?????KjbgK
15:14:22.948 : ??)???~?m??????l??o?z??t?Q???V???????f??????????{??kCo|?O????r???????T?N??)
??^?????r?z>?5?????????w???{??>n?L???O ????W?????????1iu?R>????y???v??f]79??????s?????n?????*??Y"b%????]??|.?????>???+??????.W.?#????7?{^?|m<????]?6,{?-????i?
15:14:22.964 : k0?U???? ?;i?l;????-??????????w`r????y????y?J?d?5x"?????V?Z?$???7???????~??v??`???P???????k5????c?E?+.????'D?w
15:14:22.964 : ?z2??7?????f7r4r??v??{ub?k???1???3y??????{???????}??????'?6_?j??vb?9O??h???m???b?'D??)la?0?o?K????-h????>???#???<????
15:14:22.979 : ????????????????4??&M????m?{s?????t???E?d????54
15:14:22.979 : Resend: 55
Re: MK 4.2.5 January 31, 2016 09:22AM |
Re: MK 4.2.5 January 31, 2016 11:14AM |
Re: MK 4.2.5 January 31, 2016 11:52AM |
