mk 4.2.7 February 28, 2016 05:11AM |
In file included from sketch\base.h:20:0, from sketch\Configuration_Store.cpp:1: sketch\Configuration_Overall.h:17:0: warning: "BAUDRATE" redefined [enabled by default] #define BAUDRATE 250000 ^ In file included from sketch\base.h:19:0, from sketch\Configuration_Store.cpp:1: sketch\Configuration_Basic.h:29:0: note: this is the location of the previous definition #define BAUDRATE 115200 ^ In file included from sketch\base.h:20:0, from sketch\Configuration_Store.cpp:1: sketch\Configuration_Overall.h:18:0: warning: "STRING_CONFIG_H_AUTHOR" redefined [enabled by default] #define STRING_CONFIG_H_AUTHOR "(Lamer I3, default config)" ^ In file included from sketch\base.h:19:0, from sketch\Configuration_Store.cpp:1: sketch\Configuration_Basic.h:39:0: note: this is the location of the previous definition #define STRING_CONFIG_H_AUTHOR "(none, default config)" // Who made the changes. ^ In file included from sketch\base.h:20:0, from sketch\Configuration_Store.cpp:1: sketch\Configuration_Overall.h:37:0: warning: "TEMP_SENSOR_BED" redefined [enabled by default] #define TEMP_SENSOR_BED 1 ^ In file included from sketch\base.h:19:0, from sketch\Configuration_Store.cpp:1: sketch\Configuration_Basic.h:162:0: note: this is the location of the previous definition #define TEMP_SENSOR_BED 0 ^ In file included from sketch\base.h:20:0, from sketch\Configuration_Store.cpp:1: sketch\Configuration_Overall.h:38:0: warning: "TEMP_SENSOR_AD595_OFFSET" redefined [enabled by default] #define TEMP_SENSOR_AD595_OFFSET 0 ^ In file included from sketch\base.h:19:0, from sketch\Configuration_Store.cpp:1: sketch\Configuration_Basic.h:166:0: note: this is the location of the previous definition #define TEMP_SENSOR_AD595_OFFSET 0.0
Re: mk 4.2.7 February 28, 2016 05:50AM |
Re: mk 4.2.7 February 28, 2016 08:07AM |
Re: mk 4.2.7 February 28, 2016 08:20AM |
Re: mk 4.2.7 February 28, 2016 10:03AM |
