mk 4.2.7
Posted by lamerhouse
mk 4.2.7
February 28, 2016 05:11AM
ciao mago ..
ho provato a prendere dalla gibhub la versione 4.2.7 ho sostituito solo overall e pin dalla versione 4.2.5 dev.. ma al momento della compilazione mi da moltissimi errori .. non posso piu sostituire solo i 2 file ???
anche dall'autocompilatore facendogli leggere il file overall da tutti gli errori
In file included from sketch\base.h:20:0,
                 from sketch\Configuration_Store.cpp:1:
sketch\Configuration_Overall.h:17:0: warning: "BAUDRATE" redefined [enabled by default]
 #define BAUDRATE 250000
In file included from sketch\base.h:19:0,
sketch\Configuration_Basic.h:29:0: note: this is the location of the previous definition
 #define BAUDRATE 115200
sketch\Configuration_Overall.h:18:0: warning: "STRING_CONFIG_H_AUTHOR" redefined [enabled by default]
 #define STRING_CONFIG_H_AUTHOR "(Lamer I3, default config)"
sketch\Configuration_Basic.h:39:0: note: this is the location of the previous definition
 #define STRING_CONFIG_H_AUTHOR "(none, default config)"   // Who made the changes.
sketch\Configuration_Overall.h:37:0: warning: "TEMP_SENSOR_BED" redefined [enabled by default]
 #define TEMP_SENSOR_BED 1
sketch\Configuration_Basic.h:162:0: note: this is the location of the previous definition
 #define TEMP_SENSOR_BED 0
sketch\Configuration_Overall.h:38:0: warning: "TEMP_SENSOR_AD595_OFFSET" redefined [enabled by default]
 #define TEMP_SENSOR_AD595_OFFSET 0
sketch\Configuration_Basic.h:166:0: note: this is the location of the previous definition
 #define TEMP_SENSOR_AD595_OFFSET 0.0
Edited 1 time(s). Last edit at 02/28/2016 05:13AM by lamerhouse.
Prusa I3 mega 2560 - Micron3DP all-metal - MK4duo 4.3.20_dev
Robo3d - PICO all-metal - MK4duo 4.3.20_dev
Falla 3d - Alligator 24v - Micron3DP all-metal - MK4duo 4.3.20_dev
Kossel XL Alligator - Micron3DP all-metal - MK4duo 4.3.20_dev
Desktop 3D Scanner EinScan-S
MK - Autoconfiguratore
Re: mk 4.2.7
February 28, 2016 05:50AM
Disabilita i warning da Arduino IDE. Impostazioni -> Warning -> nessuno
E riprova
My Blog - My Thingiverse
Re: mk 4.2.7
February 28, 2016 08:07AM
Re: mk 4.2.7
February 28, 2016 08:20AM
molto piu lento.. della versione 4.2.5. sia nella gestione del display... che nel ABL quando fa il controllo scende e si muove piu lentamente.. e ogni tanto si ferma a pensare mezzo secondo.. tra il primo e il secondo controllo .... al primo giro non ha stampato correttamente.. rifaccio una altra prova
Re: mk 4.2.7
February 28, 2016 10:03AM
seconda stampa ok .. cmq. rimane tutto piu lento in generale... meno performante... sembra molto piu pesante come immagine e la scheda fa fatica a rispondere... cmq. funziona tutto..
