Primi passi con Kossel Xl
Primi passi con Kossel Xl March 17, 2016 10:04AM |
;Sliced at: {day} {date} {time}
;Basic settings: Layer height: {layer_height} Walls: {wall_thickness} Fill: {fill_density}
;Print time: {print_time}
;Filament used: {filament_amount}m {filament_weight}g
;Filament cost: {filament_cost}
;M190 S{print_bed_temperature} ;Uncomment to add your own bed temperature line
;M109 S{print_temperature} ;Uncomment to add your own temperature line
G21 ;metric values
G90 ;absolute positioning
M82 ;set extruder to absolute mode
M107 ;start with the fan off
G28 X0 Y0 ;move X/Y to min endstops
G28 Z0 ;move Z to min endstops
G29
G1 Z15.0 F{travel_speed} ;move the platform down 15mm
G92 E0 ;zero the extruded length
G1 F200 E3 ;extrude 3mm of feed stock
G92 E0 ;zero the extruded length again
G1 F{travel_speed}
;Put printing message on LCD screen
M117 Printing...
Re: Primi passi con Kossel Xl March 17, 2016 02:31PM |
Re: Primi passi con Kossel Xl March 18, 2016 01:28AM |
Re: Primi passi con Kossel Xl March 18, 2016 04:45AM |
//================= Bed Auto/Manual Leveling ====================
#define ENABLE_AUTO_BED_LEVELING // 是否开启自动调平功能
#ifdef ENABLE_AUTO_BED_LEVELING
#define DELTA_PROBABLE_RADIUS (DELTA_PRINTABLE_RADIUS-50)
#define LEFT_PROBE_BED_POSITION -DELTA_PROBABLE_RADIUS
#define RIGHT_PROBE_BED_POSITION DELTA_PROBABLE_RADIUS
#define BACK_PROBE_BED_POSITION DELTA_PROBABLE_RADIUS
#define FRONT_PROBE_BED_POSITION -DELTA_PROBABLE_RADIUS
#define X_PROBE_OFFSET_FROM_EXTRUDER 0.0
#define Y_PROBE_OFFSET_FROM_EXTRUDER 0.0
#define Z_PROBE_OFFSET_FROM_EXTRUDER 0.5//自动调平设置 过高减小 过低增大
#define Z_RAISE_BEFORE_HOMING 4 // 配置回原点前Z轴升起的高度,该高度要确保在Z轴最大高度范围内。
#define XY_TRAVEL_SPEED 2000 //执行自动调平移动的速度,增大速度增加,减小速度降低
#define Z_RAISE_BEFORE_PROBING 80 ////经过第一个检测点前Z轴抬起的高度,该高度要确保调平传感器可以正常放下。
#define Z_RAISE_BETWEEN_PROBINGS 5 //经过下一个检测点前Z轴抬起的高度
#define Z_SAFE_HOMING
#ifdef Z_SAFE_HOMING
#define Z_SAFE_HOMING_X_POINT (X_MAX_LENGTH/2)
#define Z_SAFE_HOMING_Y_POINT (Y_MAX_LENGTH/2)
#endif
#define ACCURATE_BED_LEVELING
#ifdef ACCURATE_BED_LEVELING
#define ACCURATE_BED_LEVELING_POINTS 3 //自动调平探头点点数 3为横竖向各点3个点,共9点,改为6就是横竖向各点6个点,共36个点。
#define ACCURATE_BED_LEVELING_GRID_X ((RIGHT_PROBE_BED_POSITION - LEFT_PROBE_BED_POSITION) / (ACCURATE_BED_LEVELING_POINTS - 1))
#define ACCURATE_BED_LEVELING_GRID_Y ((BACK_PROBE_BED_POSITION - FRONT_PROBE_BED_POSITION) / (ACCURATE_BED_LEVELING_POINTS - 1))
#define NONLINEAR_BED_LEVELING
#endif
#endif // ENABLE_AUTO_BED_LEVELING
// The position of the homing switches
#define MANUAL_HOME_POSITIONS // If defined, MANUAL_*_HOME_POS below will be used
#define BED_CENTER_AT_0_0 // If defined, the center of the bed is at (X=0, Y=0)
// Manual homing switch locations:
// For deltabots this means top and center of the cartesian print volume.
//手动回零开关的位置:
//对于三角洲结构这意味着笛卡尔打印机的顶部和中心的值。
#define MANUAL_X_HOME_POS 0
#define MANUAL_Y_HOME_POS 0
#define MANUAL_Z_HOME_POS 371.2 //370 // Z轴高度设置 // For delta: Distance between nozzle and print surface after homing.
//// MOVEMENT SETTINGS
#define NUM_AXIS 4 // The axis order in all axis related arrays is X, Y, Z, E
#define HOMING_FEEDRATE {60*60, 60*60, 60*60, 0} // set the homing speeds (mm/min)
// default settings
#define XYZ_FULL_STEPS_PER_ROTATION 200
#define XYZ_MICROSTEPS 16
#define XYZ_BELT_PITCH 2
#define XYZ_PULLEY_TEETH 16
#define XYZ_STEPS (XYZ_FULL_STEPS_PER_ROTATION * XYZ_MICROSTEPS / double(XYZ_BELT_PITCH) / double(XYZ_PULLEY_TEETH))
#define DEFAULT_AXIS_STEPS_PER_UNIT {XYZ_STEPS, XYZ_STEPS, XYZ_STEPS, 150} // default steps per unit for PowerWasp
#define DEFAULT_MAX_FEEDRATE {200, 200, 200, 200} // (mm/sec)
#define DEFAULT_MAX_ACCELERATION {9000,9000,9000,9000} // X, Y, Z, E maximum start speed for accelerated moves. E default values are good for skeinforge 40+, for older versions raise them a lot.
#define DEFAULT_ACCELERATION 3000 // X, Y, Z and E max acceleration in mm/s^2 for printing moves
#define DEFAULT_RETRACT_ACCELERATION 3000 // X, Y, Z and E max acceleration in mm/s^2 for retracts
// The speed change that does not require acceleration (i.e. the software might assume it can be done instantaneously)
#define DEFAULT_XYJERK 20.0 // (mm/sec)
#define DEFAULT_ZJERK 20.0 // (mm/sec)
#define DEFAULT_EJERK 20.0 // (mm/sec)
#include "Marlin.h"
#include "planner.h"
#include "temperature.h"
#include "ultralcd.h"
#include "ConfigurationStore.h"
void _EEPROM_writeData(int &pos, uint8_t* value, uint8_t size)
do
eeprom_write_byte((unsigned char*)pos, *value);
pos++;
value++;
}while(--size);
#define EEPROM_WRITE_VAR(pos, value) _EEPROM_writeData(pos, (uint8_t*)&value, sizeof(value))
void _EEPROM_readData(int &pos, uint8_t* value, uint8_t size)
do
*value = eeprom_read_byte((unsigned char*)pos);
pos++;
value++;
}while(--size);
#define EEPROM_READ_VAR(pos, value) _EEPROM_readData(pos, (uint8_t*)&value, sizeof(value))
#define EEPROM_OFFSET 100
// IMPORTANT: Whenever there are changes made to the variables stored in EEPROM
// in the functions below, also increment the version number. This makes sure that
// the default values are used whenever there is a change to the data, to prevent
// wrong data being written to the variables.
// ALSO: always make sure the variables in the Store and retrieve sections are in the same order.
#define EEPROM_VERSION "V10"
#ifdef EEPROM_SETTINGS
void Config_StoreSettings()
char ver[4]= "000";
int i=EEPROM_OFFSET;
EEPROM_WRITE_VAR(i,ver); // invalidate data first
EEPROM_WRITE_VAR(i,axis_steps_per_unit);
EEPROM_WRITE_VAR(i,max_feedrate);
EEPROM_WRITE_VAR(i,max_acceleration_units_per_sq_second);
EEPROM_WRITE_VAR(i,acceleration);
EEPROM_WRITE_VAR(i,retract_acceleration);
EEPROM_WRITE_VAR(i,minimumfeedrate);
EEPROM_WRITE_VAR(i,mintravelfeedrate);
EEPROM_WRITE_VAR(i,minsegmenttime);
EEPROM_WRITE_VAR(i,max_xy_jerk);
EEPROM_WRITE_VAR(i,max_z_jerk);
EEPROM_WRITE_VAR(i,max_e_jerk);
EEPROM_WRITE_VAR(i,add_homeing);
#ifdef DELTA
EEPROM_WRITE_VAR(i,endstop_adj);
#endif
#ifndef ULTIPANEL
int plaPreheatHotendTemp = PLA_PREHEAT_HOTEND_TEMP, plaPreheatHPBTemp = PLA_PREHEAT_HPB_TEMP, plaPreheatFanSpeed = PLA_PREHEAT_FAN_SPEED;
int absPreheatHotendTemp = ABS_PREHEAT_HOTEND_TEMP, absPreheatHPBTemp = ABS_PREHEAT_HPB_TEMP, absPreheatFanSpeed = ABS_PREHEAT_FAN_SPEED;
#endif
EEPROM_WRITE_VAR(i,plaPreheatHotendTemp);
EEPROM_WRITE_VAR(i,plaPreheatHPBTemp);
EEPROM_WRITE_VAR(i,plaPreheatFanSpeed);
EEPROM_WRITE_VAR(i,absPreheatHotendTemp);
EEPROM_WRITE_VAR(i,absPreheatHPBTemp);
EEPROM_WRITE_VAR(i,absPreheatFanSpeed);
EEPROM_WRITE_VAR(i,zprobe_zoffset);
#ifdef PIDTEMP
EEPROM_WRITE_VAR(i,Kp);
EEPROM_WRITE_VAR(i,Ki);
EEPROM_WRITE_VAR(i,Kd);
#else
float dummy = 3000.0f;
EEPROM_WRITE_VAR(i,dummy);
dummy = 0.0f;
#endif
#ifndef DOGLCD
int lcd_contrast = 32;
#endif
EEPROM_WRITE_VAR(i,lcd_contrast);
char ver2[4]=EEPROM_VERSION;
i=EEPROM_OFFSET;
EEPROM_WRITE_VAR(i,ver2); // validate data
SERIAL_ECHO_START;
SERIAL_ECHOLNPGM("Settings Stored");
#endif //EEPROM_SETTINGS
#ifndef DISABLE_M503
void Config_PrintSettings()
{ // Always have this function, even with EEPROM_SETTINGS disabled, the current values will be shown
SERIAL_ECHO_START;
SERIAL_ECHOLNPGM("Steps per unit:");
SERIAL_ECHO_START;
SERIAL_ECHOPAIR(" M92 X",axis_steps_per_unit[0]);
SERIAL_ECHOPAIR(" Y",axis_steps_per_unit[1]);
SERIAL_ECHOPAIR(" Z",axis_steps_per_unit[2]);
SERIAL_ECHOPAIR(" E",axis_steps_per_unit[3]);
SERIAL_ECHOLN("");
SERIAL_ECHO_START;
SERIAL_ECHOLNPGM("Maximum feedrates (mm/s):");
SERIAL_ECHO_START;
SERIAL_ECHOPAIR(" M203 X",max_feedrate[0]);
SERIAL_ECHOPAIR(" Y",max_feedrate[1] );
SERIAL_ECHOPAIR(" Z", max_feedrate[2] );
SERIAL_ECHOPAIR(" E", max_feedrate[3]);
SERIAL_ECHOLN("");
SERIAL_ECHO_START;
SERIAL_ECHOLNPGM("Maximum Acceleration (mm/s2):");
SERIAL_ECHO_START;
SERIAL_ECHOPAIR(" M201 X" ,max_acceleration_units_per_sq_second[0] );
SERIAL_ECHOPAIR(" Y" , max_acceleration_units_per_sq_second[1] );
SERIAL_ECHOPAIR(" Z" ,max_acceleration_units_per_sq_second[2] );
SERIAL_ECHOPAIR(" E" ,max_acceleration_units_per_sq_second[3]);
SERIAL_ECHOLN("");
SERIAL_ECHO_START;
SERIAL_ECHOLNPGM("Acceleration: S=acceleration, T=retract acceleration");
SERIAL_ECHO_START;
SERIAL_ECHOPAIR(" M204 S",acceleration );
SERIAL_ECHOPAIR(" T" ,retract_acceleration);
SERIAL_ECHOLN("");
SERIAL_ECHO_START;
SERIAL_ECHOLNPGM("Advanced variables: S=Min feedrate (mm/s), T=Min travel feedrate (mm/s), B=minimum segment time (ms), X=maximum XY jerk (mm/s), Z=maximum Z jerk (mm/s), E=maximum E jerk (mm/s)");
SERIAL_ECHO_START;
SERIAL_ECHOPAIR(" M205 S",minimumfeedrate );
SERIAL_ECHOPAIR(" T" ,mintravelfeedrate );
SERIAL_ECHOPAIR(" B" ,minsegmenttime );
SERIAL_ECHOPAIR(" X" ,max_xy_jerk );
SERIAL_ECHOPAIR(" Z" ,max_z_jerk);
SERIAL_ECHOPAIR(" E" ,max_e_jerk);
SERIAL_ECHOLN("");
SERIAL_ECHO_START;
SERIAL_ECHOLNPGM("Home offset (mm):");
SERIAL_ECHO_START;
SERIAL_ECHOPAIR(" M206 X",add_homeing[0] );
SERIAL_ECHOPAIR(" Y" ,add_homeing[1] );
SERIAL_ECHOPAIR(" Z" ,add_homeing[2] );
SERIAL_ECHOLN("");
#ifdef DELTA
SERIAL_ECHO_START;
SERIAL_ECHOLNPGM("Endstop adjustement (mm):");
SERIAL_ECHO_START;
SERIAL_ECHOPAIR(" M666 X",endstop_adj[0] );
SERIAL_ECHOPAIR(" Y" ,endstop_adj[1] );
SERIAL_ECHOPAIR(" Z" ,endstop_adj[2] );
SERIAL_ECHOLN("");
#endif
#ifdef PIDTEMP
SERIAL_ECHO_START;
SERIAL_ECHOLNPGM("PID settings:");
SERIAL_ECHO_START;
SERIAL_ECHOPAIR(" M301 P",Kp);
SERIAL_ECHOPAIR(" I" ,unscalePID_i(Ki));
SERIAL_ECHOPAIR(" D" ,unscalePID_d(Kd));
SERIAL_ECHOLN("");
#endif
#endif
void Config_RetrieveSettings()
char stored_ver[4];
char ver[4]=EEPROM_VERSION;
EEPROM_READ_VAR(i,stored_ver); //read stored version
// SERIAL_ECHOLN("Version: [" << ver << "] Stored version: [" << stored_ver << "]");
if (strncmp(ver,stored_ver,3) == 0)
// version number match
EEPROM_READ_VAR(i,axis_steps_per_unit);
EEPROM_READ_VAR(i,max_feedrate);
EEPROM_READ_VAR(i,max_acceleration_units_per_sq_second);
// steps per sq second need to be updated to agree with the units per sq second (as they are what is used in the planner)
reset_acceleration_rates();
EEPROM_READ_VAR(i,acceleration);
EEPROM_READ_VAR(i,retract_acceleration);
EEPROM_READ_VAR(i,minimumfeedrate);
EEPROM_READ_VAR(i,mintravelfeedrate);
EEPROM_READ_VAR(i,minsegmenttime);
EEPROM_READ_VAR(i,max_xy_jerk);
EEPROM_READ_VAR(i,max_z_jerk);
EEPROM_READ_VAR(i,max_e_jerk);
EEPROM_READ_VAR(i,add_homeing);
#ifdef DELTA
EEPROM_READ_VAR(i,endstop_adj);
#endif
#ifndef ULTIPANEL
int plaPreheatHotendTemp, plaPreheatHPBTemp, plaPreheatFanSpeed;
int absPreheatHotendTemp, absPreheatHPBTemp, absPreheatFanSpeed;
#endif
EEPROM_READ_VAR(i,plaPreheatHotendTemp);
EEPROM_READ_VAR(i,plaPreheatHPBTemp);
EEPROM_READ_VAR(i,plaPreheatFanSpeed);
EEPROM_READ_VAR(i,absPreheatHotendTemp);
EEPROM_READ_VAR(i,absPreheatHPBTemp);
EEPROM_READ_VAR(i,absPreheatFanSpeed);
EEPROM_READ_VAR(i,zprobe_zoffset);
#ifndef PIDTEMP
float Kp,Ki,Kd;
#endif
// do not need to scale PID values as the values in EEPROM are already scaled
EEPROM_READ_VAR(i,Kp);
EEPROM_READ_VAR(i,Ki);
EEPROM_READ_VAR(i,Kd);
#ifndef DOGLCD
int lcd_contrast;
#endif
EEPROM_READ_VAR(i,lcd_contrast);
// Call updatePID (similar to when we have processed M301)
updatePID();
SERIAL_ECHO_START;
SERIAL_ECHOLNPGM("Stored settings retrieved");
else
Config_ResetDefault();
#ifdef EEPROM_CHITCHAT
Config_PrintSettings();
#endif
#endif
void Config_ResetDefault()
float tmp1[]=DEFAULT_AXIS_STEPS_PER_UNIT;
float tmp2[]=DEFAULT_MAX_FEEDRATE;
long tmp3[]=DEFAULT_MAX_ACCELERATION;
for (short i=0;i<4;i++)
axis_steps_per_unit=tmp1;
max_feedrate=tmp2;
max_acceleration_units_per_sq_second=tmp3;
acceleration=DEFAULT_ACCELERATION;
retract_acceleration=DEFAULT_RETRACT_ACCELERATION;
minimumfeedrate=DEFAULT_MINIMUMFEEDRATE;
minsegmenttime=DEFAULT_MINSEGMENTTIME;
mintravelfeedrate=DEFAULT_MINTRAVELFEEDRATE;
max_xy_jerk=DEFAULT_XYJERK;
max_z_jerk=DEFAULT_ZJERK;
max_e_jerk=DEFAULT_EJERK;
add_homeing[0] = add_homeing[1] = add_homeing[2] = 0;
#ifdef DELTA
endstop_adj[0] = endstop_adj[1] = endstop_adj[2] = 0;
#endif
#ifdef ULTIPANEL
plaPreheatHotendTemp = PLA_PREHEAT_HOTEND_TEMP;
plaPreheatHPBTemp = PLA_PREHEAT_HPB_TEMP;
absPreheatHotendTemp = ABS_PREHEAT_HOTEND_TEMP;
absPreheatHPBTemp = ABS_PREHEAT_HPB_TEMP;
#endif
zprobe_zoffset = -Z_PROBE_OFFSET_FROM_EXTRUDER;
#endif
#ifdef DOGLCD
lcd_contrast = DEFAULT_LCD_CONTRAST;
#endif
#ifdef PIDTEMP
Kp = DEFAULT_Kp;
Ki = scalePID_i(DEFAULT_Ki);
Kd = scalePID_d(DEFAULT_Kd);
// call updatePID (similar to when we have processed M301)
updatePID();
#ifdef PID_ADD_EXTRUSION_RATE
Kc = DEFAULT_Kc;
#endif//PID_ADD_EXTRUSION_RATE
#endif//PIDTEMP
SERIAL_ECHO_START;
SERIAL_ECHOLNPGM("Hardcoded Default Settings Loaded");
Re: Primi passi con Kossel Xl March 22, 2016 03:51PM |
Re: Primi passi con Kossel Xl March 23, 2016 10:40AM |
