aiuto autoleveling endstop April 04, 2016 03:09PM |
//================= Kossel Self-leveling configuration ====================
#define ENABLE_AUTO_BED_LEVELING // Auto-leveling feature is turned on or not.
#ifdef ENABLE_AUTO_BED_LEVELING
#define DELTA_PROBABLE_RADIUS (DELTA_PRINTABLE_RADIUS-50)//Here the probe is set to leveling the range of movement,Increasing the leveling range, reduce the "-50" This value,Reducing leveling range, increase the "-50" value
//如:#define DELTA_PROBABLE_RADIUS (DELTA_PRINTABLE_RADIUS-60)
#define LEFT_PROBE_BED_POSITION -DELTA_PROBABLE_RADIUS
#define RIGHT_PROBE_BED_POSITION DELTA_PROBABLE_RADIUS
#define BACK_PROBE_BED_POSITION DELTA_PROBABLE_RADIUS
#define FRONT_PROBE_BED_POSITION -DELTA_PROBABLE_RADIUS
#define X_PROBE_OFFSET_FROM_EXTRUDER 0.0
#define Y_PROBE_OFFSET_FROM_EXTRUDER 0.0
#define Z_PROBE_OFFSET_FROM_EXTRUDER 0.5//Automatic leveling settings,too high reduce,low increases
#define Z_RAISE_BEFORE_HOMING 4 // Configuration of before homing, Z-axis height raised,the height must be ensured in the range of the maximum height in the Z-axis.
#define XY_TRAVEL_SPEED 2000 //Automatic leveling speed of movement,increasing the speed increase, decrease speed reduction
#define Z_RAISE_BEFORE_PROBING 80 ////Before the first pre-test point, Z-axis height raised, the height should ensure that the leveling sensors can normally be put down.
#define Z_RAISE_BETWEEN_PROBINGS 5 //The next pre-test point,Z-axis height raised
#define Z_SAFE_HOMING
#ifdef Z_SAFE_HOMING
#define Z_SAFE_HOMING_X_POINT (X_MAX_LENGTH/2)
#define Z_SAFE_HOMING_Y_POINT (Y_MAX_LENGTH/2)
#endif
#define ACCURATE_BED_LEVELING
#ifdef ACCURATE_BED_LEVELING
#define ACCURATE_BED_LEVELING_POINTS 3 //Automatic leveling probes,point 3 points, vertical and horizontal axes each point three points,the total is 9 points;If changed to 6, the vertical and horizontal axes points 6 points each, a total of 36 points.
#define ACCURATE_BED_LEVELING_GRID_X ((RIGHT_PROBE_BED_POSITION - LEFT_PROBE_BED_POSITION) / (ACCURATE_BED_LEVELING_POINTS - 1))
#define ACCURATE_BED_LEVELING_GRID_Y ((BACK_PROBE_BED_POSITION - FRONT_PROBE_BED_POSITION) / (ACCURATE_BED_LEVELING_POINTS - 1))
#define NONLINEAR_BED_LEVELING
#endif
#endif
// The position of the homing switches
#define MANUAL_HOME_POSITIONS // If defined, MANUAL_*_HOME_POS below will be used
#define BED_CENTER_AT_0_0 // If defined, the center of the bed is at (X=0, Y=0)
//Manual homing switch locations:
// For deltabots this means top and center of the cartesian print volume.
#define MANUAL_X_HOME_POS 0
#define MANUAL_Y_HOME_POS 0
#define MANUAL_Z_HOME_POS 320//306.6 // For delta: Distance between nozzle and print surface after homing.
//Because there will be differences for each machine installation, need your own measurement,after setting finished remember to keep Modify.
//// MOVEMENT SETTINGS
#define NUM_AXIS 4 // The axis order in all axis related arrays is X, Y, Z, E
#define HOMING_FEEDRATE {60*60, 60*60, 60*60, 0} // set the homing speeds (mm/min)
#define XYZ_FULL_STEPS_PER_ROTATION 200 //Stepper motor weekly number of steps, namely 360 / stepper motor angle
//For example, 1.8 degrees, the number of steps should be 360 / 1.8 = 200; if it is 0.9 degree motor 360 / 0.9 = 400.
#define XYZ_MICROSTEPS 16 //Breakdown of the number of stepper drive
#define XYZ_BELT_PITCH 2 //Belt tooth pitch
#define XYZ_PULLEY_TEETH 16 //Synchronization number of teeth
#define XYZ_STEPS (XYZ_FULL_STEPS_PER_ROTATION * XYZ_MICROSTEPS / double(XYZ_BELT_PITCH) / double(XYZ_PULLEY_TEETH))
//This is the formula: number of subdivisions number * stepping stepper motor driver / belt tooth spacing / synchronous tooth number
#define DEFAULT_AXIS_STEPS_PER_UNIT {XYZ_STEPS, XYZ_STEPS, XYZ_STEPS, 150} //Extruder amount
#define DEFAULT_MAX_FEEDRATE {200, 200, 200, 200}
#define DEFAULT_MAX_ACCELERATION {3000,3000,3000,3000}
//Acceleration configuration, when out of step if the print is too large, this value can be piecemeal
#define DEFAULT_ACCELERATION 3000
#define DEFAULT_RETRACT_ACCELERATION 3000
//Do not need to speed up the distance between the axes, ie without acceleration, immediate completion of the distance (ie, software thinks he can complete in an instant)
#define DEFAULT_XYJERK 20.0
#define DEFAULT_ZJERK 20.0
#define DEFAULT_EJERK 20.0
Re: aiuto autoleveling endstop April 04, 2016 03:14PM |
Re: aiuto autoleveling endstop April 04, 2016 03:19PM |
//=========================================================================== //============================= Mechanical Settings ================================ //=========================================================================== // Uncomment the following line to enable CoreXY kinematics // #define COREXY // coarse Endstop Settings #define ENDSTOPPULLUPS // Comment this out (using // at the start of the line) to disable the endstop pullup resistors #ifndef ENDSTOPPULLUPS // fine Enstop settings: Individual Pullups. will be ignored if ENDSTOPPULLUPS is defined // #define ENDSTOPPULLUP_XMAX // #define ENDSTOPPULLUP_YMAX // #define ENDSTOPPULLUP_ZMAX // #define ENDSTOPPULLUP_XMIN // #define ENDSTOPPULLUP_YMIN // #define ENDSTOPPULLUP_ZMIN #endif #ifdef ENDSTOPPULLUPS #define ENDSTOPPULLUP_XMAX #define ENDSTOPPULLUP_YMAX #define ENDSTOPPULLUP_ZMAX #define ENDSTOPPULLUP_XMIN #define ENDSTOPPULLUP_YMIN #define ENDSTOPPULLUP_ZMIN #endif // The pullups are needed if you directly connect a mechanical endswitch between the signal and ground pins. const bool X_MIN_ENDSTOP_INVERTING = false; const bool Y_MIN_ENDSTOP_INVERTING = false; const bool Z_MIN_ENDSTOP_INVERTING = false; const bool X_MAX_ENDSTOP_INVERTING = false; const bool Y_MAX_ENDSTOP_INVERTING = false; const bool Z_MAX_ENDSTOP_INVERTING = false; //#define DISABLE_MAX_ENDSTOPS //#define DISABLE_MIN_ENDSTOPS // Disable max endstops for compatibility with endstop checking routine #if defined(COREXY) && !defined(DISABLE_MAX_ENDSTOPS) #define DISABLE_MAX_ENDSTOPS #endif // For Inverting Stepper Enable Pins (Active Low) use 0, Non Inverting (Active High) use 1 #define X_ENABLE_ON 0 #define Y_ENABLE_ON 0 #define Z_ENABLE_ON 0 #define E_ENABLE_ON 0 // For all extruders // Disables axis when it's not being used. #define DISABLE_X false #define DISABLE_Y false #define DISABLE_Z false #define DISABLE_E false // For all extruders #define INVERT_X_DIR true // for Mendel set to false, for Orca set to true #define INVERT_Y_DIR true // for Mendel set to true, for Orca set to false #define INVERT_Z_DIR true // for Mendel set to false, for Orca set to true #define INVERT_E0_DIR false // for direct drive extruder v9 set to true, for geared extruder set to false #define INVERT_E1_DIR false // for direct drive extruder v9 set to true, for geared extruder set to false #define INVERT_E2_DIR false // for direct drive extruder v9 set to true, for geared extruder set to false // ENDSTOP SETTINGS: // Sets direction of endstops when homing; 1=MAX, -1=MIN #define X_HOME_DIR 1 #define Y_HOME_DIR 1 #define Z_HOME_DIR 1 #define min_software_endstops false // If true, axis won't move to coordinates less than HOME_POS. #define max_software_endstops true // If true, axis won't move to coordinates greater than the defined lengths below. // Travel limits after homing #define X_MAX_POS DELTA_PRINTABLE_RADIUS #define X_MIN_POS -DELTA_PRINTABLE_RADIUS #define Y_MAX_POS DELTA_PRINTABLE_RADIUS #define Y_MIN_POS -DELTA_PRINTABLE_RADIUS #define Z_MAX_POS MANUAL_Z_HOME_POS #define Z_MIN_POS 0 #define X_MAX_LENGTH (X_MAX_POS - X_MIN_POS) #define Y_MAX_LENGTH (Y_MAX_POS - Y_MIN_POS) #define Z_MAX_LENGTH (Z_MAX_POS - Z_MIN_POS)
Re: aiuto autoleveling endstop April 04, 2016 03:47PM |
