MK4.2.85 open LCD error editor
June 18, 2016 04:48AM
sketch\module\lcd\ultralcd.cpp.o: In function `lcd_control_motion_menu':
sketch\module\lcd/ultralcd.cpp:1942: undefined reference to `zprobe_zoffset'
sketch\module\lcd\ultralcd.cpp.o: In function `_menu_action_setting_edit_float32':
sketch\module\lcd/ultralcd.cpp:2403: undefined reference to `zprobe_zoffset'
sketch\module\lcd\ultralcd.cpp.o:sketch\module\lcd/ultralcd.cpp:2403: more undefined references to `zprobe_zoffset' follow
collect2.exe: error: ld returned 1 exit status
exit status 1
Edited 1 time(s). Last edit at 06/18/2016 08:33AM by yg12344.
open | download - Configuration_Overall.h (43 KB)
Re: MK4.2.85 open LCD error editor
June 19, 2016 05:07PM
Riscontro anche io lo stesso problema dopo aver abilitato l'autolivellamento
sketch/module/lcd/ultralcd.cpp.o: In function `lcd_control_motion_menu':
sketch/module/lcd/ultralcd.cpp:1902: undefined reference to `zprobe_zoffset'
sketch/module/lcd/ultralcd.cpp.o: In function `_menu_action_setting_edit_float32':
sketch/module/lcd/ultralcd.cpp:2362: undefined reference to `zprobe_zoffset'
sketch/module/lcd/ultralcd.cpp.o:sketch/module/lcd/ultralcd.cpp:2362: more undefined references to `zprobe_zoffset' follow
collect2: error: ld returned 1 exit status
exit status 1
Errore durante la compilazione
Demiurgo meccanica Ultimaker - Ramps 1.4 - Hotend E3D V6 0,4mm - Firrmware MarlinKimbra - auto bed level con proximity - Simplify3D, Cura
Demiurgo_W corexy - Ramps 1.4 - Hotend E3D V6 0,4mm - Firrmware MK 4.2.6.dev - auto bed level con proximity - Simplify3D, Cura
Delta - Ramps 1.4 -Hotend E3d V6 0,4mm - Firmware MK 4.2.85
June 19, 2016 05:28PM
Ma quando lo avete scaricato??
L'ho corretto l'altro ieri!!!
My Blog - My Thingiverse
June 19, 2016 05:59PM
io ho scaricato l'aggiornamento e funzionava, poi ho attivato l'autolivellamento ed è uscito lo script sopra di errore quando attivo lcd
June 19, 2016 06:02PM
Riscarica perché ho corretto l'altro ieri...
June 20, 2016 05:58AM
Scaricato ora e mi da il seguente errore:
In file included from Configuration_Store.cpp:39:0: base.h:14:27: fatal error: module/macros.h: No such file or directory #include "module/macros.h" ^ compilation terminated. Errore durante la compilazione
June 20, 2016 11:29AM
Ma che versione hai di IDE??
June 20, 2016 03:38PM
Ho aggiornato IDE e ora è tutto ok
Grazie
June 20, 2016 10:45PM
IL problema è già stato risolto il problema MK4.2.86 scaricare, ma non ha smesso di Correre G30A figurano I seguenti codici per Molto Tempo non si Ferma
busy:processing
Echo:r:100.4000 (adj:0.000000) c:-1.4300
busy:processing
busy:processing
busy:processing
busy:processing
Echo:r:100.4000 (adj:0.000000) c:-1.4350
busy:processing
Echo:r:100.4000 (adj:0.000000) c:-1.4250
busy:processing
busy:processing
busy:processing
busy:processing
Echo:r:100.4000 (adj:0.000000) c:-1.4150
busy:processing
busy:processing
busy:processing
busy:processing
busy:processing
busy:processing
busy:processing
busy:processing
