Re: Chiarimento dopo comando G29 November 14, 2016 03:02PM |
Azzz!! dopo quasi 30 minuti pensavo non andasse bene.Quote
MagoKimbra
Noooo perché hai fermato stava solo al'iterzione 6 di solito ci mette almeno 10 a salire fino ad arrivare anche ben oltre le 20 dipende da quanto è starata la geometria..
Re: Chiarimento dopo comando G29 November 14, 2016 03:14PM |
Re: Chiarimento dopo comando G29 November 15, 2016 08:15AM |
Re: Chiarimento dopo comando G29 November 15, 2016 05:46PM |
23:31:20.930 : Config:Current Delta geometry values: 23:31:20.930 : Config(Endstop Adj): -0.848 23:31:20.930 : Config:Y (Endstop Adj): -4.748 23:31:20.930 : Config:Z (Endstop Adj): -2.271 23:31:20.930 : Config
(ZProbe ZOffset): -2.100 23:31:20.930 : Config:A (Tower A Position Correction): 0.000 23:31:20.930 : Config:B (Tower B Position Correction): 0.000 23:31:20.930 : Config:C (Tower C Position Correction): 0.000 23:31:20.930 : Config:I (Tower A Radius Correction): -5.965 23:31:20.930 : Config:J (Tower B Radius Correction): -4.250 23:31:20.930 : Config:K (Tower C Radius Correction): -3.125 23:31:20.930 : Config:U (Tower A Diagonal Rod Correction): 0.000 23:31:20.930 : Config:V (Tower B Diagonal Rod Correction): 0.000 23:31:20.930 : Config:W (Tower C Diagonal Rod Correction): 0.000 23:31:20.930 : Config:R (Delta Radius): 97.3499 23:31:20.930 : Config
(Diagonal Rod Length): 200.7999 23:31:20.930 : Config
(Delta Segments per second): 200.0 23:31:20.930 : Config:H (Z-Height): 194.074
Re: Chiarimento dopo comando G29 November 15, 2016 05:59PM |
Re: Chiarimento dopo comando G29 November 16, 2016 02:19AM |
Re: Chiarimento dopo comando G29 November 16, 2016 03:24AM |
Re: Chiarimento dopo comando G29 November 16, 2016 07:32AM |
Re: Chiarimento dopo comando G29 November 16, 2016 08:57AM |
Re: Chiarimento dopo comando G29 November 16, 2016 04:51PM |
22:43:08.028 : G29 Auto Bed Leveling 22:43:56.861 : 0.05 0.16 0.27 0.50 0.72 22:43:56.861 : -0.00 0.09 0.17 0.30 0.42 22:43:56.861 : -0.01 0.01 0.06 0.10 0.10 22:43:56.861 : -0.03 -0.03 -0.03 -0.05 -0.08 22:43:56.861 : -0.11 -0.06 -0.01 -0.20 -0.25
; Default start code G28 ; Home extruder G29 ; ABL ; M320 ; Abilita ABL MK ; M321 ; Disabilita ABL MK G1 Z15 F{Z_TRAVEL_SPEED} M107 ; Turn off fan G90 ; Absolute positioning M82 ; Extruder in absolute mode ; Activate all used extruder {IF_EXT0}M104 T0 S{TEMP0} {IF_BED}M190 S{BED} G92 E0 ; Reset extruder position ; Wait for all used extruders to reach temperature {IF_EXT0}M109 T0 S{TEMP0} M84 S0
22:53:17.833 : G29 Auto Bed Leveling 22:53:17.833 : ?Probe position out of range. 22:53:17.833 : ?Probe position out of range.
Re: Chiarimento dopo comando G29 November 16, 2016 05:23PM |
Re: Chiarimento dopo comando G29 November 16, 2016 05:37PM |
#define DEFAULT_DELTA_RADIUS (DELTA_SMOOTH_ROD_OFFSET - DELTA_EFFECTOR_OFFSET - DELTA_CARRIAGE_OFFSET)Dove i tre valori tra parentesi li hai messi tu o sul configuratore o a mano in marlin (è uguale).
Re: Chiarimento dopo comando G29 November 17, 2016 07:56AM |
Re: Chiarimento dopo comando G29 November 17, 2016 11:49AM |
Re: Chiarimento dopo comando G29 November 17, 2016 12:10PM |
Re: Chiarimento dopo comando G29 November 17, 2016 12:43PM |
MagoKimbra
No in nessuno dei due casi necessita.. Il delta radius modifica il movimento concavo o convesso verso l'esterno, se non hai di questi problemi don devi variarlo se ce l'hai lo vari. AL centro non fa nulla è verso gli esterni che incide
Re: Chiarimento dopo comando G29 November 17, 2016 01:43PM |
Re: Chiarimento dopo comando G29 November 17, 2016 05:24PM |
Re: Chiarimento dopo comando G29 November 19, 2016 04:16PM |
22:08:42.796 : Config:Current Delta geometry values: 22:08:42.796 : ConfigPoi ho fatto un M500 per salvare tutto in eeprom e quì mi fermo per chiedere ancora lumi.(Endstop Adj): -1.417 22:08:42.796 : Config:Y (Endstop Adj): -1.347 22:08:42.796 : Config:Z (Endstop Adj): -3.081 22:08:42.796 : Config
(ZProbe ZOffset): -2.400 22:08:42.796 : Config:A (Tower A Position Correction): 0.000 22:08:42.796 : Config:B (Tower B Position Correction): 0.000 22:08:42.796 : Config:C (Tower C Position Correction): 0.000 22:08:42.796 : Config:I (Tower A Radius Correction): -6.000 22:08:42.796 : Config:J (Tower B Radius Correction): -3.750 22:08:42.796 : Config:K (Tower C Radius Correction): -3.000 22:08:42.796 : Config:U (Tower A Diagonal Rod Correction): 0.000 22:08:42.796 : Config:V (Tower B Diagonal Rod Correction): 0.000 22:08:42.796 : Config:W (Tower C Diagonal Rod Correction): 0.000 22:08:42.796 : Config:R (Delta Radius): 97.0499 22:08:42.796 : Config
(Diagonal Rod Length): 199.0000 22:08:42.796 : Config
(Delta Segments per second): 200.0 22:08:42.796 : Config:H (Z-Height): 193.316
Re: Chiarimento dopo comando G29 November 19, 2016 04:48PM |
Re: Chiarimento dopo comando G29 November 19, 2016 05:03PM |
MagoKimbra
E' normale, riregola l'altezza e impostala con M666 h, quella impostata in repetier serve solo al software per sapere se il pezzo è nell'area di stampa...
22:08:42.796 : Config:Current Delta geometry values: 22:08:42.796 : Confignel configuratore per riscaricare il software di nuovo e non rifare l'autocalibrazione?(Endstop Adj): -1.417 22:08:42.796 : Config:Y (Endstop Adj): -1.347 22:08:42.796 : Config:Z (Endstop Adj): -3.081 22:08:42.796 : Config
Re: Chiarimento dopo comando G29 November 20, 2016 05:06AM |
Re: Chiarimento dopo comando G29 November 30, 2016 03:30PM |
/#define Z_PROBE_ALLEN_KEY #define Z_PROBE_DEPLOY_START_LOCATION {1,1,30,0} #define Z_PROBE_DEPLOY_END_LOCATION {1,1,30,0} #define Z_PROBE_RETRACT_START_LOCATION {1,1,30,0} #define Z_PROBE_RETRACT_END_LOCATION {1,1,30,0} #define X_PROBE_OFFSET_FROM_NOZZLE -24 #define Y_PROBE_OFFSET_FROM_NOZZLE -2 #define Z_PROBE_OFFSET_FROM_NOZZLE -2.15 #define XY_PROBE_SPEED 2000 #define Z_PROBE_SPEED 1200
