firmware test - 'prepare_move' was not declared in this scope January 05, 2017 04:45AM |
sketch\src\fwtest\firmware_test.cpp: In function 'void FirmwareTest()':
sketch\src\fwtest\firmware_test.cpp:352:16: error: 'prepare_move' was not declared in this scope
prepare_move();
exit status 1
Errore durante la compilazione per la scheda Arduino/Genuino Mega or Mega 2560.
Re: firmware test - 'prepare_move' was not declared in this scope January 05, 2017 05:08AM |
Re: firmware test - 'prepare_move' was not declared in this scope January 05, 2017 06:06AM |
Re: firmware test - 'prepare_move' was not declared in this scope January 05, 2017 06:27AM |
Re: firmware test - 'prepare_move' was not declared in this scope January 05, 2017 09:13AM |
Re: firmware test - 'prepare_move' was not declared in this scope January 05, 2017 09:20AM |
// // Temperature Sensors // #if TEMP_SENSOR_0 == -1 #define ORIG_TEMP_0_PIN 11 // ANALOG NUMBERING #else #define ORIG_TEMP_0_PIN 15 // ANALOG NUMBERING #endif #if TEMP_SENSOR_1 == -1 #define ORIG_TEMP_1_PIN 10 // ANALOG NUMBERING #else #define ORIG_TEMP_1_PIN 13 // ANALOG NUMBERING #endif #if TEMP_SENSOR_2 == -1 #define ORIG_TEMP_2_PIN 9 // ANALOG NUMBERING #else #define ORIG_TEMP_2_PIN 12 // ANALOG NUMBERING #endif #if TEMP_SENSOR_BED == -1 #define ORIG_TEMP_BED_PIN 8 // ANALOG NUMBERING #else #define ORIG_TEMP_BED_PIN 14 // ANALOG NUMBERING #endif
Re: firmware test - 'prepare_move' was not declared in this scope January 05, 2017 10:16AM |
Re: firmware test - 'prepare_move' was not declared in this scope January 05, 2017 10:34AM |
Re: firmware test - 'prepare_move' was not declared in this scope January 07, 2017 07:03PM |
Comincia a mettere solo un hotend senza bed... E vediamo cosa dice. Metti su T0 E non misurare la resistenza sul connettore quando è attaccata, ma misura la tensione ai capi!
Re: firmware test - 'prepare_move' was not declared in this scope January 08, 2017 01:51PM |
