Settaggi per sensore diametro filamento / controllo volumetrico January 24, 2017 07:26PM |
#define VOLUMETRIC_DEFAULT_ON #define DEFAULT_NOMINAL_FILAMENT_DIA 1.75 #define FILAMENT_SENSOR #define FILAMENT_SENSOR_EXTRUDER_NUM 0 #define MEASUREMENT_DELAY_CM 70 //measurement delay in cm. This is the distance from filament sensor to middle of barrel #define MEASURED_UPPER_LIMIT 2 #define MEASURED_LOWER_LIMIT 1.35 #define MAX_MEASUREMENT_DELAY 75 //delay buffer size in bytes (1 byte = 1cm)- limits maximum measurement delay allowable (must be larger than MEASUREMENT_DELAY_CM and lower number saves RAM)
#define FILWIDTH_PIN 59 // A5
Arduino:1.6.13 (Linux), Scheda:"Arduino/Genuino Mega or Mega 2560, ATmega2560 (Mega 2560)"
sketch/src/MK_Main.cpp: In function 'void gcode_M405()':
sketch/src/MK_Main.cpp:7958:47: error: 'widthFil_to_size_ratio' was not declared in this scope
int temp_ratio = widthFil_to_size_ratio();
exit status 1
Errore durante la compilazione per la scheda Arduino/Genuino Mega or Mega 2560.
#if HAS(FILAMENT_SENSOR)
static float analog2widthFil(); // Convert raw Filament Width to millimeters
static int widthFil_to_size_ratio(); // Convert raw Filament Width to an extrusion ratio
#endif
#if ENABLED(FILAMENT_SENSOR)
float Temperature::analog2widthFil() {
return current_raw_filwidth / 16383.0 * 5.0;
//return current_raw_filwidth;
// Convert raw Filament Width to a ratio
int Temperature::widthFil_to_size_ratio() {
float temp = filament_width_meas;
if (temp < MEASURED_LOWER_LIMIT) temp = filament_width_nominal; //assume sensor cut out
else NOMORE(temp, MEASURED_UPPER_LIMIT);
return filament_width_nominal / temp * 100;
#endif
Re: Settaggi per sensore diametro filamento / controllo volumetrico January 25, 2017 02:38AM |
int temp_ratio = thermalManager.widthFil_to_size_ratio();
Re: Settaggi per sensore diametro filamento / controllo volumetrico January 25, 2017 04:11AM |
MagoKimbra
Un'ultima cosa a questo punto se lavori in volumetrico ricordati di settare lo slicer in volumetrico e non in lineare...
Re: Settaggi per sensore diametro filamento / controllo volumetrico January 25, 2017 05:54AM |
