Errori MK 4.2.9
Posted by M_a_X_Italy
Errori MK 4.2.9
March 03, 2017 12:51PM
La stampante stampa cmq, i pezzi vengono fuori bene, mi domandavo se è veramente un problema.
18:50:12.941 : Error:checksum mismatch, Last Line: 254322
18:50:13.124 : Error:Line Number is not Last Line Number+1, Last Line: 254322
18:50:16.436 : Error:Line Number is not Last Line Number+1, Last Line: 254499
18:50:16.902 : Error:Line Number is not Last Line Number+1, Last Line: 254503
18:50:17.663 : Error:Line Number is not Last Line Number+1, Last Line: 254538
18:50:18.093 : Error:Line Number is not Last Line Number+1, Last Line: 254542
18:50:20.487 : Error:Line Number is not Last Line Number+1, Last Line: 254640
18:50:21.105 : Error:Line Number is not Last Line Number+1, Last Line: 254644
18:50:21.555 : Error:Line Number is not Last Line Number+1, Last Line: 254648
18:50:22.006 : Error:Line Number is not Last Line Number+1, Last Line: 254653
18:50:22.747 : Error:Line Number is not Last Line Number+1, Last Line: 254691
18:50:23.194 : Error:Line Number is not Last Line Number+1, Last Line: 254695
18:50:24.174 : Error:Line Number is not Last Line Number+1, Last Line: 254728
18:50:24.590 : Error:Line Number is not Last Line Number+1, Last Line: 254732
18:50:25.009 : Error:Line Number is not Last Line Number+1, Last Line: 254732
18:50:25.176 : Error:Line Number is not Last Line Number+1, Last Line: 254732
18:50:25.371 : Error:Line Number is not Last Line Number+1, Last Line: 254733
18:50:28.654 : Stampa layer 94 of 478
18:50:28.884 : Error:Line Number is not Last Line Number+1, Last Line: 254880
18:50:29.596 : Error:Line Number is not Last Line Number+1, Last Line: 254884
Prusa I3 R2 Pro MK4.3.5; doppio alim., ugelli: 0.35, 0.60, 0.80 / piatto riscaldato in alluminio spessore 6mm 330mmx240mm coibentato
Aggiunte: fine corsa magnetici
Cad modellazione: Solid Works
Software per slicing: Repetier host con plug-in Cura
Filo: 1,75; ABS e NinjaFlex
[www.thingiverse.com]
Re: Errori MK 4.2.9
March 03, 2017 01:05PM
No solo che hai una connessione ballerina... Io abbasserei il baud rate e/o stamperei solo da SD...
My Blog - My Thingiverse
Re: Errori MK 4.2.9
March 03, 2017 01:18PM
Provo prima col baud rate, la sd, è un pò che non funziona...grazie
