Repetier-host
Posted by Frankq
Repetier-host
April 06, 2017 08:50AM
Ciao a tutti
su un portatile con Win7 32bit ho installato Repetier-host 1.6.2
Non mi appare la griglia 3D e naturalmente quando carico un .stl non mi visualizza l'oggetto.
Ecco il log di Repetier.
14:39:00.188 : OpenGL version:1.4.0 - Build 8.14.10.1930
14:39:00.204 : OpenGL extensions:GL_EXT_blend_minmax GL_EXT_blend_subtract GL_EXT_blend_color GL_EXT_abgr
GL_EXT_texture3D GL_EXT_clip_volume_hint GL_EXT_compiled_vertex_array GL_EXT_cull_vertex
GL_SGIS_texture_edge_clamp GL_SGIS_generate_mipmap GL_EXT_draw_range_elements GL_SGIS_texture_lod
GL_EXT_rescale_normal GL_EXT_packed_pixels GL_EXT_separate_specular_color GL_ARB_multitexture
GL_EXT_texture_env_combine GL_EXT_bgra GL_EXT_blend_func_separate GL_EXT_secondary_color GL_EXT_fog_coord
GL_EXT_texture_env_add GL_ARB_texture_cube_map GL_ARB_transpose_matrix GL_ARB_texture_env_add
GL_IBM_texture_mirrored_repeat GL_EXT_multi_draw_arrays GL_NV_blend_square GL_ARB_texture_compression
GL_3DFX_texture_compression_FXT1 GL_EXT_texture_filter_anisotropic GL_ARB_texture_border_clamp
GL_ARB_point_parameters GL_ARB_texture_env_combine GL_ARB_texture_env_dot3 GL_ARB_texture_env_crossbar
GL_EXT_texture_compression_s3tc GL_ARB_shadow GL_ARB_window_pos GL_EXT_shadow_funcs GL_EXT_stencil_wrap
GL_ARB_vertex_program GL_ARB_fragment_program GL_EXT_stencil_two_side GL_ARB_vertex_buffer_object
GL_EXT_texture_lod_bias GL_NV_texgen_reflection GL_ARB_depth_texture GL_WIN_swap_hint
14:39:00.204 : OpenGL renderer:Intel 945GM
14:39:00.204 : Using fast VBOs for rendering is possible
Forse manca qualche libreria?
Franco
CoreXY HyperCube , MKDuo, HotEnd 0,4 Repetier Host Cura engine
Mostly CNC con MKDuo
Re: Repetier-host
April 06, 2017 10:59AM
Re: Repetier-host
April 07, 2017 04:48PM
aggiorna i driver della scheda video, anche quelli intel se hai la doppia scheda.
Re: Repetier-host
April 08, 2017 01:26AM
Grazie, oggi ci provo
Franco
