errore compilazione settaggio x offset Pibot Risolto June 29, 2017 03:28PM |
sketch\src/sanitycheck.h:736:10: error: #error "The given RIGHT_PROBE_BED_POSITION can't be reached by the Z probe."
^exit status 1
Errore durante la compilazione per la scheda Arduino/Genuino Mega or Mega 2560.
#define Z_PROBE_FIX_MOUNTED
//#define BLTOUCH
//#define BLTOUCH_DELAY 375 // (ms) Enable and increase if needed
//#define Z_PROBE_SLED
#define SLED_DOCKING_OFFSET 5
#define X_PROBE_OFFSET_FROM_NOZZLE -21
#define Y_PROBE_OFFSET_FROM_NOZZLE 0
#define Z_PROBE_OFFSET_FROM_NOZZLE -10
#define XY_PROBE_SPEED 8000
#define Z_PROBE_SPEED_FAST 200
#define Z_PROBE_SPEED_SLOW 100
//#define PROBE_DOUBLE_TOUCH
#define Z_MIN_PROBE_REPEATABILITY_TEST
#define Z_PROBE_DEPLOY_HEIGHT 15
#define Z_PROBE_BETWEEN_HEIGHT 10
#define Z_PROBE_OFFSET_RANGE_MIN -50
#define Z_PROBE_OFFSET_RANGE_MAX 50
//#define LCD_BED_LEVELING
#define LCD_Z_STEP 0.025
#define LCD_PROBE_Z_RANGE 4 // Z Range centered on Z_MIN_POS 0
#define X_HOME_DIR -1
#define Y_HOME_DIR -1
#define Z_HOME_DIR -1
#define E_HOME_DIR -1
#define MIN_Z_HEIGHT_FOR_HOMING 0
#define X_ENABLE_ON 0
#define Y_ENABLE_ON 0
#define Z_ENABLE_ON 0
#define E_ENABLE_ON 0
#define INVERT_X_STEP_PIN false
#define INVERT_Y_STEP_PIN false
#define INVERT_Z_STEP_PIN false
#define INVERT_E_STEP_PIN false
#define INVERT_X_DIR false
#define INVERT_Y_DIR false
#define INVERT_Z_DIR false
#define INVERT_E0_DIR false
#define INVERT_E1_DIR false
#define INVERT_E2_DIR false
#define INVERT_E3_DIR false
#define INVERT_E4_DIR false
#define INVERT_E5_DIR false
#define DISABLE_X false
#define DISABLE_Y false
#define DISABLE_Z false
#define DISABLE_E false
//#define DISABLE_INACTIVE_EXTRUDER
#define X_MAX_POS 198
#define X_MIN_POS -20
#define Y_MAX_POS 288
#define Y_MIN_POS -10
#define Z_MAX_POS 240
#define Z_MIN_POS 0
#define E_MIN_POS 0
#define AXIS_RELATIVE_MODES {false, false, false, false}
#define Z_SAFE_HOMING
#define Z_SAFE_HOMING_X_POINT 100
#define Z_SAFE_HOMING_Y_POINT 150
//#define MESH_BED_LEVELING
#define AUTO_BED_LEVELING_LINEAR
//#define AUTO_BED_LEVELING_BILINEAR
//#define AUTO_BED_LEVELING_3POINT
//#define DEBUG_LEVELING_FEATURE
#define MESH_INSET 10
#define MESH_MIN_X (X_MIN_POS + MESH_INSET)
#define MESH_MAX_X (X_MAX_POS - (MESH_INSET))
#define MESH_MIN_Y (Y_MIN_POS + MESH_INSET)
#define MESH_MAX_Y (Y_MAX_POS - (MESH_INSET))
//#define MESH_G28_REST_ORIGIN
#define GRID_MAX_POINTS_X 3
#define GRID_MAX_POINTS_Y 3
#define LEFT_PROBE_BED_POSITION 20
#define RIGHT_PROBE_BED_POSITION 180
#define FRONT_PROBE_BED_POSITION 20
#define BACK_PROBE_BED_POSITION 268
#define MIN_PROBE_EDGE 10
//#define PROBE_Y_FIRST
//#define ABL_BILINEAR_SUBDIVISION
#define BILINEAR_SUBDIVISIONS 3
#define ABL_PROBE_PT_1_X 15
#define ABL_PROBE_PT_1_Y 180
#define ABL_PROBE_PT_2_X 15
#define ABL_PROBE_PT_2_Y 15
#define ABL_PROBE_PT_3_X 180
#define ABL_PROBE_PT_3_Y 15
//#define Z_PROBE_END_SCRIPT "G1 Z10 F8000\nG1 X10 Y10\nG1 Z0.5"
#define ENABLE_LEVELING_FADE_HEIGHT
//#define BED_CENTER_AT_0_0
//#define MANUAL_X_HOME_POS 0
//#define MANUAL_Y_HOME_POS 0
//#define MANUAL_Z_HOME_POS 0
Re: errore compilazione settaggio x offset Pibot June 29, 2017 04:02PM |
Re: errore compilazione settaggio x offset Pibot June 29, 2017 04:03PM |
