MarlinKimbra vers. 4.3.24dev Errore compilazione
Posted by Adryzz
July 02, 2017 09:06AM
Ciao,
Compilando (Arduino 1.8.3) mi da il seguente errore, versione precedente da cui ho preso il config.overall 4.3.19dev che funziona benissimo.
In file included from sketch\base.h:82:0,
from D:\Documents\Arduino\MK4duo_4_3_24_CORE\MK4duo\MK4duo.ino:257:
sketch\src/conditionals_post.h:44:0: error: unterminated #if
#if ENABLED(ARDUINO_ARCH_SAM)
sketch\src/conditionals_post.h:28:0: error: unterminated #ifndef
#ifndef _CONDITIONALS_POST_H
In file included from sketch\base.h:83:0,
sketch\src/sanitycheck.h:1731:6: error: #error DEPENDENCY ERROR: HEATER_0_PIN not EXIST for this board
exit status 1
Errore durante la compilazione per la scheda Arduino/Genuino Mega or Mega 2560.
Stampante CoreXY BLV mgn 30X30X22 con estrusore diretto E3D V6 originale
Duet 2 wifi
BLTouch originale
Ugello 0,4
Filo 1,75
open | download - Configuration_Overall.h (42.3 KB)
Re: MarlinKimbra vers. 4.3.24dev Errore compilazione
July 02, 2017 10:54AM
Si non so cosa sia successo ma i file sul server del configuratore erano vuoti o parziali... Forse quando ho fatto upload non li ha presi o no so cosa sia successo... li ho rimessi tutti e controllati.
My Blog - My Thingiverse
July 02, 2017 04:24PM
Scaricato nuovamente e riprovato ....
Nuovo errore :
sketch\src\eeprom\eeprom.cpp: In static member function 'static bool EEPROM:confused smileytore_Settings()':
sketch\src\eeprom\eeprom.cpp:341:20: error: 'bedlevel' was not declared in this scope
EEPROM_WRITE(bedlevel.z_fade_height);
sketch\src\eeprom\eeprom.cpp:206:65: note: in definition of macro 'EEPROM_WRITE'
#define EEPROM_WRITE(VAR) write_data(eeprom_index, (uint8_t*)&VAR, sizeof(VAR), &working_crc)
sketch\src\eeprom\eeprom.cpp: In static member function 'static bool EEPROM::Load_Settings()':
sketch\src\eeprom\eeprom.cpp:672:21: error: 'bedlevel' was not declared in this scope
EEPROM_READ(bedlevel.z_fade_height);
sketch\src\eeprom\eeprom.cpp:207:64: note: in definition of macro 'EEPROM_READ'
#define EEPROM_READ(VAR) read_data(eeprom_index, (uint8_t*)&VAR, sizeof(VAR), &working_crc)
sketch\src\eeprom\eeprom.cpp: In static member function 'static void EEPROM::Factory_Settings()':
sketch\src\eeprom\eeprom.cpp:1002:5: error: 'bedlevel' was not declared in this scope
bedlevel.z_fade_height = 0.0;
exit status 1
Duet 2 wifi
BLTouch originale
Ugello 0,4
Filo 1,75
July 02, 2017 04:45PM
Colpa mia che non metto i controlli.. Ma come mai hai attivato ENABLE_LEVELING_FADE_HEIGHT e non hai il bed level??
July 02, 2017 05:42PM
Questo non lo so, ho caricato il vecchio overall e basta senza modificare nulla, e in nessuna versione precedente ho mai attivato cose relative al bed level, lo taro a mano sufficientemente bene.
In ogni caso commentando quella riga ha compilato e caricato, poi sono andato a spulciare le versioni precedenti e me la porto dietro dalla 4.3.09, anche se non ho mai usato i settaggi per il bed level.
Forse qualche vecchio bug, va a sapere.
Duet 2 wifi
BLTouch originale
Ugello 0,4
Filo 1,75
