Segnalazione errori di compilazione SOLO VERSIONI IN SVILUPPO (DEV) September 19, 2017 07:28PM |
Re: Segnalazione errori di compilazione SOLO VERSIONI IN SVILUPPO (DEV) September 19, 2017 07:33PM |
Arduino:1.8.3 (Linux), Scheda:"Arduino/Genuino Mega or Mega 2560, ATmega2560 (Mega 2560)"
sketch/src/sd/SDFat.cpp: In member function 'bool Sd2Card::readData(uint8_t*, size_t)':
sketch/src/sd/SDFat.cpp:3286:13: error: 'SD_CARD_ERROR_CRC' was not declared in this scope
error(SD_CARD_ERROR_CRC);
sketch/src/sd/SDFat.cpp:3283:14: error: crosses initialization of 'uint16_t recvCrc'
uint16_t recvCrc = spiReceive() << 8;
sketch/src/sd/SDFat.cpp:3282:14: error: crosses initialization of 'uint16_t calcCrc'
uint16_t calcCrc = CRC_CCITT(dst, count);
exit status 1
Errore durante la compilazione per la scheda Arduino/Genuino Mega or Mega 2560.
Questo report potrebbe essere più ricco di informazioni abilitando l'opzione
"Mostra un output dettagliato durante la compilazione"
in "File -> Impostazioni"
Re: Segnalazione errori di compilazione SOLO VERSIONI IN SVILUPPO (DEV) September 21, 2017 10:22AM |
In file included from sketch/src/commands/../gcode/gcode.h:153:0,
from sketch/src/commands/commands.cpp:30:
sketch/src/commands/../gcode/multimode/m6.h: In function 'void gcode_M6()':
sketch/src/commands/../gcode/multimode/m6.h:36:62: error: 'tool_change_cnc' was not declared in this scope
inline void gcode_M6(void) { tool_change_cnc(CNC_M6_TOOL_ID); }
In file included from sketch/src/commands/../gcode/gcode.h:211:0,
sketch/src/commands/../gcode/tools/tcode.h: In function 'void gcode_T()':
sketch/src/commands/../gcode/tools/tcode.h:62:45: error: 'tool_change_cnc' was not declared in this scope
tool_change_cnc(tool_id, wait, raise_z);
exit status 1
Re: Segnalazione errori di compilazione SOLO VERSIONI IN SVILUPPO (DEV) September 21, 2017 03:50PM |
Re: Segnalazione errori di compilazione SOLO VERSIONI IN SVILUPPO (DEV) September 22, 2017 01:04PM |
ok T:29.5 /0 B:24.0 /0 @:0 B@:0 CHAMBER: C:24.5 /0 C@:0
ok T:24.5 /0 B:23.1 /0 R:21.2 /0 @:0 B@:0Più pulito, ma manca l'@ della chamber.
ok T:24.5 /0 B:23.1 /0 R:21.2 /0 @:0 B@:0 R@:0
Re: Segnalazione errori di compilazione SOLO VERSIONI IN SVILUPPO (DEV) September 22, 2017 05:59PM |
Re: Segnalazione errori di compilazione SOLO VERSIONI IN SVILUPPO (DEV) September 22, 2017 07:11PM |
sketch/src/cncrouter/cncrouter.cpp: In static member function 'static void Cncrouter::tool_change(uint8_t, bool, bool)':
sketch/src/cncrouter/cncrouter.cpp:107:9: error: 'wait_for_user' was not declared in this scope
wait_for_user = true;
exit status 1
Errore durante la compilazione per la scheda Arduino/Genuino Mega or Mega 2560."
Re: Segnalazione errori di compilazione SOLO VERSIONI IN SVILUPPO (DEV) September 23, 2017 08:53PM |
In file included from sketch/src/commands/../gcode/gcode.h:147:0,
sketch/src/commands/../gcode/motion/g2_g3.h: In function 'void gcode_G2_G3(bool)':
sketch/src/commands/../gcode/motion/g2_g3.h:119:32: error: 'current_position' was not declared in this scope
mechanics.plan_arc(current_position, arc_offset, clockwise);
exit status 1
Re: Segnalazione errori di compilazione SOLO VERSIONI IN SVILUPPO (DEV) September 24, 2017 03:19AM |
Re: Segnalazione errori di compilazione SOLO VERSIONI IN SVILUPPO (DEV) September 24, 2017 07:12PM |
Re: Segnalazione errori di compilazione SOLO VERSIONI IN SVILUPPO (DEV) September 27, 2017 05:40PM |
Re: Segnalazione errori di compilazione SOLO VERSIONI IN SVILUPPO (DEV) November 20, 2017 10:36AM |
Arduino:1.8.5 (Linux), Scheda:"Arduino/Genuino Mega or Mega 2560, ATmega2560 (Mega 2560)"
In file included from sketch/MK4duo.h:158:0,
from /media/fabio/ST_32GB/1 - Dati/arduino/sketchbook/MK4duo_4.3.29_dev/MK4duo_4.3.29_dev.ino:288:
sketch/src/feature/rgbled/neopixel.h:34:33: fatal error: Adafruit_NeoPixel.h: No such file or directory
#include
compilation terminated.
exit status 1
Re: Segnalazione errori di compilazione SOLO VERSIONI IN SVILUPPO (DEV) November 20, 2017 10:46AM |
Re: Segnalazione errori di compilazione SOLO VERSIONI IN SVILUPPO (DEV) November 20, 2017 11:20AM |
Re: Segnalazione errori di compilazione SOLO VERSIONI IN SVILUPPO (DEV) November 22, 2017 11:24AM |
Re: Segnalazione errori di compilazione SOLO VERSIONI IN SVILUPPO (DEV) November 22, 2017 12:11PM |
Re: Segnalazione errori di compilazione SOLO VERSIONI IN SVILUPPO (DEV) November 22, 2017 04:49PM |
Re: Segnalazione errori di compilazione SOLO VERSIONI IN SVILUPPO (DEV) November 22, 2017 05:35PM |
Re: Segnalazione errori di compilazione SOLO VERSIONI IN SVILUPPO (DEV) November 22, 2017 06:10PM |
Re: Segnalazione errori di compilazione SOLO VERSIONI IN SVILUPPO (DEV) November 26, 2017 11:42AM |
Re: Segnalazione errori di compilazione SOLO VERSIONI IN SVILUPPO (DEV) November 26, 2017 01:19PM |
Re: Segnalazione errori di compilazione SOLO VERSIONI IN SVILUPPO (DEV) November 26, 2017 05:09PM |
Re: Segnalazione errori di compilazione SOLO VERSIONI IN SVILUPPO (DEV) November 26, 2017 05:52PM |
Re: Segnalazione errori di compilazione SOLO VERSIONI IN SVILUPPO (DEV) November 26, 2017 06:08PM |
Re: Segnalazione errori di compilazione SOLO VERSIONI IN SVILUPPO (DEV) November 27, 2017 02:05AM |
Re: Segnalazione errori di compilazione SOLO VERSIONI IN SVILUPPO (DEV) December 16, 2017 09:24AM |
Fan:0 pin:9, frequency:250Hz, min:0 inverted:false ok
Echo:Unknown command: "M107" ok
Echo:Unknown command: "M114" ok
open failed, File: init.g
Re: Segnalazione errori di compilazione SOLO VERSIONI IN SVILUPPO (DEV) December 17, 2017 11:11AM |
Re: Segnalazione errori di compilazione SOLO VERSIONI IN SVILUPPO (DEV) December 17, 2017 05:33PM |
#define NEOPIXEL_TYPE NEO_RGB...non GBR, quindi bohh.
Re: Segnalazione errori di compilazione SOLO VERSIONI IN SVILUPPO (DEV) December 17, 2017 06:21PM |
Re: Segnalazione errori di compilazione SOLO VERSIONI IN SVILUPPO (DEV) December 17, 2017 08:08PM |
// Check for commands that require the printer to be homed
if (mechanics.axis_unhomed_error()) {
const int8_t p_val = parser.intval('P', -1);
if (p_val == 1 || p_val == 2 || p_val == 4 || parser.seen('J'))
mechanics.Home(true);
//if (mechanics.axis_unhomed_error()) return;e funzionava perfettamente. (usavo ABL e non UBL)
