New 4.3.5 mi parte subito in stampa senza riscaldare nulla[risolto] February 19, 2018 08:35AM |
M303 E0 S205 C5dato che stampo a 205°
Re: New 4.3.5 mi parte subito in stampa senza riscaldare nulla February 19, 2018 01:17PM |
Re: New 4.3.5 mi parte subito in stampa senza riscaldare nulla February 19, 2018 03:17PM |
/** * M301: Set PID parameters P I D (and optionally C, L) * * H[heaters] H = 0-3 Hotend, H = -1 BED, H = -2 CHAMBER, H = -3 COOLER * * P[float] Kp term * I[float] Ki term * D[float] Kd term *
Re: New 4.3.5 mi parte subito in stampa senza riscaldare nulla February 19, 2018 04:20PM |
22:22:47.380 : X:0.00 Y:0.00 Z:253.521 E:0.0000 22:22:47.632 : Error: Need Tuning PID 22:22:47.929 : X:0.00 Y:0.00 Z:230.000 E:0.0000 22:22:48.031 : Error: Need Tuning PID 22:22:48.044 : Stampa layer 1 of 10
Re: New 4.3.5 mi parte subito in stampa senza riscaldare nulla February 19, 2018 05:21PM |
Re: New 4.3.5 mi parte subito in stampa senza riscaldare nulla February 19, 2018 05:35PM |
MagoKimbra
Con M503 leggi tutto...
Sto controllando se c'è qualche problema con la funzione tuning con un hotend e pid non ho problemi, verifico con il bed e i pid...
Domanda che non centra nulla, ma vi conviene usare i pid per il bed??? Senza sta fermo...
23:32:46.541 : Config: G21 ; Units in mm 23:32:46.541 : Configteps per unit: 23:32:46.544 : Config: M92 X80.450 Y80.450 Z80.450 T0 E95.300 23:32:46.545 : Config:Maximum feedrates (units/s): 23:32:46.545 : Config: M203 X300.000 Y300.000 Z300.000 T0 E100.000 23:32:46.545 : Config:Maximum Acceleration (units/s2): 23:32:46.545 : Config: M201 X1500 Y1500 Z1500 T0 E1500 23:32:46.545 : Config:Acceleration (units/s2): P V T* R 23:32:46.545 : Config: M204 P1500.000 V1500.000 T0 R10000.000 23:32:46.561 : Config:Advanced variables: S V B X Z T* E 23:32:46.561 : Config: M205 S0.000 V0.000 B20000 X10.000 Y10.000 Z10.000 T0 E5.000 23:32:46.561 : Config:Hotend Sensor parameters: H P A B C R L O 23:32:46.561 : Config: M305 H0 P13 A100000.0 B4036.0 C0.0000000000 R4700.0 L0 O0 23:32:46.561 : Config:Hotend Heater parameters: H P A B C L O U I 23:32:46.561 : Config: M306 H0 P10 A40 B230 C255 L5 O250 U1 I0 23:32:46.582 : Config:Bed Sensor parameters: P A B C R L O 23:32:46.582 : Config: M305 H-1 P14 A100000.0 B4036.0 C0.0000000000 R4700.0 L0 O0 23:32:46.584 : Config:Bed Heater parameters: P A B C L O U I 23:32:46.584 : Config: M306 H-1 P8 A80 B255 C255 L5 O90 U1 I0 23:32:46.584 : Config
ID settings: 23:32:46.584 : Config: M301 H0 P10.60 I0.79 D35.45 23:32:46.584 : Config: M301 H-1 P27.22 I1.39 D133.09 23:32:46.602 : Config:Fans: P U L F H I 23:32:46.602 : Config: M106 P0 U9 L0 F250 I0 23:32:46.602 : Config: M106 P1 U44 L0 F250 H0 I0 23:32:46.602 : Config:Endstop adjustment: 23:32:46.602 : Config: M666 X0.00 Y0.00 Z0.00 23:32:46.602 : Config:Geometry adjustment: ABC=TOWER_DIAGROD_ADJ, IJK=TOWER_ANGLE_ADJ, UVW=TOWER_RADIUS_ADJ 23:32:46.602 : Config: R=DELTA_RADIUS, D=DELTA_DIAGONAL_ROD, S=DELTA_SEGMENTS_PER_SECOND 23:32:46.602 : Config: O=DELTA_PRINTABLE_RADIUS, P=DELTA_PROBEABLE_RADIUS, H=DELTA_HEIGHT 23:32:46.611 : Config: M666 A0.000 B0.000 C0.000 I0.000 J0.000 K0.000 U0.000 V0.000 W0.000 R100.50 D217.00 S100.00 O85.00 P54.00 H300.170 23:32:46.611 : Config
robe Offset: 23:32:46.612 : Config: M851 X-1.000 Y-31.000 Z-1.750 23:32:46.612 : Stats: Total: 0, Finished: 0, Failed: 0 23:32:46.612 : Stats: Total print time: 0s, Power on time: 10s 23:32:46.612 : Stats: Filament used: 0Km 0m 0cm 0mm
Re: New 4.3.5 mi parte subito in stampa senza riscaldare nulla February 19, 2018 06:18PM |
Re: New 4.3.5 mi parte subito in stampa senza riscaldare nulla February 20, 2018 04:36PM |
