Problema MK4DUO 4.3.6 con laser May 19, 2018 09:14AM |
Re: Problema MK4DUO 4.3.6 con laser May 19, 2018 09:40AM |
Re: Problema MK4DUO 4.3.6 con laser May 20, 2018 01:54PM |
Re: Problema MK4DUO 4.3.6 con laser May 20, 2018 02:40PM |
Re: Problema MK4DUO 4.3.6 con laser May 20, 2018 03:53PM |
Re: Problema MK4DUO 4.3.6 con laser May 22, 2018 04:17AM |
Re: Problema MK4DUO 4.3.6 con laser May 22, 2018 04:58AM |
Re: Problema MK4DUO 4.3.6 con laser May 22, 2018 08:48AM |
Re: Problema MK4DUO 4.3.6 con laser May 24, 2018 05:06AM |
Re: Problema MK4DUO 4.3.6 con laser May 24, 2018 06:09AM |
Re: Problema MK4DUO 4.3.6 con laser May 24, 2018 08:04AM |
Re: Problema MK4DUO 4.3.6 con laser May 24, 2018 10:42AM |
Re: Problema MK4DUO 4.3.6 con laser May 26, 2018 04:55AM |
Re: Problema MK4DUO 4.3.6 con laser May 26, 2018 05:10AM |
Re: Problema MK4DUO 4.3.6 con laser June 05, 2018 01:50PM |
Re: Problema MK4DUO 4.3.6 con laser June 08, 2018 04:23PM |
Re: Problema MK4DUO 4.3.6 con laser June 08, 2018 06:27PM |
Re: Problema MK4DUO 4.3.6 con laser June 19, 2018 08:08AM |
Re: Problema MK4DUO 4.3.6 con laser June 19, 2018 10:54AM |
Re: Problema MK4DUO 4.3.6 con laser June 19, 2018 12:03PM |
Re: Problema MK4DUO 4.3.6 con laser June 20, 2018 03:45AM |
#if ENABLED(LASER) #define LASER_PWR_PIN 6 #define LASER_PWM_PIN 6 #if ENABLED(LASER_PERIPHERALS) #define LASER_PERIPHERALS_PIN NoPin #define LASER_PERIPHERALS_STATUS_PIN NoPin #endif #endif
#define LASER_CONTROL 1 // questo è un bug del configuratore, in qualunque modo tu configuri il laser, il valore nel FW non cambia)
//#define INTENSITY_IN_BYTE
