ventola PLA con configurazione EEB - MKS base_l June 09, 2018 01:20PM |
Re: ventola PLA con configurazione EEB - MKS base_l June 09, 2018 01:46PM |
Re: ventola PLA con configurazione EEB - MKS base_l June 09, 2018 02:07PM |
Re: ventola PLA con configurazione EEB - MKS base_l June 09, 2018 02:22PM |
Re: ventola PLA con configurazione EEB - MKS base_l June 09, 2018 02:36PM |
Re: ventola PLA con configurazione EEB - MKS base_l June 09, 2018 03:12PM |
#ifndef FAN_PIN #if ENABLED(IS_RAMPS_EF || ENABLED(IS_RAMPS_EFF) // Hotend, Fan, Bed or Hotend, Fan, Fan #define FAN_PIN RAMPS_D9_PIN #elif ENABLED(IS_RAMPS_EEF) || ENABLED(IS_RAMPS_SF) // Hotend, Hotend, Fan or Spindle, Fan #define FAN_PIN RAMPS_D8_PIN #elif ENABLED(IS_RAMPS_EE // Hotend, Hotend, Bed #define FAN_PIN 4 // IO pin. Buffer needed #else // Non-specific are "EFB" (i.e., "EFBF" or "EFBE") #define FAN_PIN RAMPS_D9_PIN #endif #endif
Re: ventola PLA con configurazione EEB - MKS base_l June 10, 2018 05:14AM |
#define HEATER_0_PIN RAMPS_D10_PIN #if ENABLED(IS_RAMPS_EFB ) // Hotend, Fan, Bed #define FAN_PIN RAMPS_D9_PIN #define HEATER_BED_PIN RAMPS_D8_PIN #elif ENABLED(IS_RAMPS_EEF) // Hotend, Hotend, Fan #define HEATER_1_PIN RAMPS_D9_PIN #define FAN_PIN RAMPS_D8_PIN #elif ENABLED(IS_RAMPS_EEB ) // Hotend, Hotend, Bed #define HEATER_1_PIN RAMPS_D9_PIN #define HEATER_BED_PIN RAMPS_D8_PIN #elif ENABLED(IS_RAMPS_EFF) // Hotend, Fan, Fan #define FAN_PIN RAMPS_D9_PIN #define FAN1_PIN RAMPS_D8_PIN #elif ENABLED(IS_RAMPS_SF) // Spindle, Fan #define FAN_PIN RAMPS_D8_PIN #else // Non-specific are "EFB" (i.e., "EFBF" or "EFBE") #define FAN_PIN RAMPS_D9_PIN #define HEATER_BED_PIN RAMPS_D8_PIN #if HOTENDS == 1 #define FAN1_PIN MOSFET_D_PIN #else #define HEATER_1_PIN MOSFET_D_PIN #endif #endif #ifndef FAN_PIN #define FAN_PIN 4 // IO pin. Buffer needed #endif
Re: ventola PLA con configurazione EEB - MKS base_l June 10, 2018 05:35AM |
Re: ventola PLA con configurazione EEB - MKS base_l June 10, 2018 08:02AM |
MagoKimbra
Sul MK4duo c'è e i pin sono 10 per Hotend 0, 7 per Hotend 1, 10 per il bed, e appunto il 9 per la fan.. Se cosi fosse non va bene la ramps in HHB perché ti mappa i pin sbagliati...
Re: ventola PLA con configurazione EEB - MKS base_l June 10, 2018 08:20AM |
Re: ventola PLA con configurazione EEB - MKS base_l June 10, 2018 08:23AM |
Re: ventola PLA con configurazione EEB - MKS base_l June 10, 2018 08:46AM |
MagoKimbra
Ma tu lo stai vedendo su Marlin... Io ti sto dicendo MK i pin sono 7 8 9 e 10 quindi tranne il bed che ha sempre l'uscita 8 perché ha l'alimentazione separata gli altri li puoi usare come vuoi, quindi se marlin usa 9 e 10 rimane fuori il 7...
#define USE_CONTROLLER_FAN #if ENABLED(USE_CONTROLLER_FAN) #define CONTROLLER_FAN_PIN 7 // Set a custom pin for the controller fan #define CONTROLLERFAN_SECS 60 // Duration in seconds for the fan to run after all motors are disabled #define CONTROLLERFAN_SPEED 255 // 255 == full speed #endif
Re: ventola PLA con configurazione EEB - MKS base_l June 10, 2018 09:20AM |
// // Heaters / Fans // // Power outputs EFBF or EFBE #define MOSFET_D_PIN 7 #define CASE_LIGHT_PIN 2 // // M3/M4/M5 - Spindle/Laser Control // #define SPINDLE_LASER_PWM_PIN 2 // MUST BE HARDWARE PWM #define SPINDLE_LASER_ENABLE_PIN 15 // Pin should have a pullup! #define SPINDLE_DIR_PIN 19 #include "pins_RAMPS.h"
#if ENABLED(IS_RAMPS_EF // Hotend, Fan, Bed #define HEATER_BED_PIN RAMPS_D8_PIN #elif ENABLED(IS_RAMPS_EEF) // Hotend, Hotend, Fan #define HEATER_1_PIN RAMPS_D9_PIN #elif ENABLED(IS_RAMPS_EE // Hotend, Hotend, Bed #define HEATER_1_PIN RAMPS_D9_PIN #define HEATER_BED_PIN RAMPS_D8_PIN #elif ENABLED(IS_RAMPS_EFF) // Hotend, Fan, Fan #define FAN1_PIN RAMPS_D8_PIN #elif DISABLED(IS_RAMPS_SF) // Not Spindle, Fan (i.e., "EFBF" or "EFBE") #define HEATER_BED_PIN RAMPS_D8_PIN #if HOTENDS == 1 #define FAN1_PIN MOSFET_D_PIN #else #define HEATER_1_PIN MOSFET_D_PIN #endif #endif #ifndef FAN_PIN #if ENABLED(IS_RAMPS_EF || ENABLED(IS_RAMPS_EFF) // Hotend, Fan, Bed or Hotend, Fan, Fan #define FAN_PIN RAMPS_D9_PIN #elif ENABLED(IS_RAMPS_EEF) || ENABLED(IS_RAMPS_SF) // Hotend, Hotend, Fan or Spindle, Fan #define FAN_PIN RAMPS_D8_PIN #elif ENABLED(IS_RAMPS_EE // Hotend, Hotend, Bed #define FAN_PIN 4 // IO pin. Buffer needed #else // Non-specific are "EFB" (i.e., "EFBF" or "EFBE") #define FAN_PIN RAMPS_D9_PIN #endif #endif
Re: ventola PLA con configurazione EEB - MKS base_l June 10, 2018 09:38AM |
