GT2560 Firmware Marlin Anet A8 June 22, 2018 11:36AM |
In file included from sketch\MarlinConfig.h:40:0, from sketch\G26_Mesh_Validation_Tool.cpp:27: SanityCheck.h:825: error: 'LEFT_PROBE_BED_POSITION' was not declared in this scope static_assert(LEFT_PROBE_BED_POSITION < RIGHT_PROBE_BED_POSITION, "LEFT_PROBE_BED_POSITION must be less than RIGHT_PROBE_BED_POSITION."); ^ SanityCheck.h:825: error: 'RIGHT_PROBE_BED_POSITION' was not declared in this scope static_assert(LEFT_PROBE_BED_POSITION < RIGHT_PROBE_BED_POSITION, "LEFT_PROBE_BED_POSITION must be less than RIGHT_PROBE_BED_POSITION."); ^ SanityCheck.h:826: error: 'FRONT_PROBE_BED_POSITION' was not declared in this scope static_assert(FRONT_PROBE_BED_POSITION < BACK_PROBE_BED_POSITION, "FRONT_PROBE_BED_POSITION must be less than BACK_PROBE_BED_POSITION."); ^ SanityCheck.h:826: error: 'BACK_PROBE_BED_POSITION' was not declared in this scope static_assert(FRONT_PROBE_BED_POSITION < BACK_PROBE_BED_POSITION, "FRONT_PROBE_BED_POSITION must be less than BACK_PROBE_BED_POSITION."); ^ SanityCheck.h:827: error: 'LEFT_PROBE_BED_POSITION' was not declared in this scope static_assert(LEFT_PROBE_BED_POSITION >= MIN_PROBE_X, "LEFT_PROBE_BED_POSITION can't be reached by the Z probe."); ^ SanityCheck.h:828: error: 'RIGHT_PROBE_BED_POSITION' was not declared in this scope static_assert(RIGHT_PROBE_BED_POSITION <= MAX_PROBE_X, "RIGHT_PROBE_BED_POSITION can't be reached by the Z probe."); ^ SanityCheck.h:829: error: 'FRONT_PROBE_BED_POSITION' was not declared in this scope static_assert(FRONT_PROBE_BED_POSITION >= MIN_PROBE_Y, "FRONT_PROBE_BED_POSITION can't be reached by the Z probe."); ^ SanityCheck.h:830: error: 'BACK_PROBE_BED_POSITION' was not declared in this scope static_assert(BACK_PROBE_BED_POSITION <= MAX_PROBE_Y, "BACK_PROBE_BED_POSITION can't be reached by the Z probe."); ^
Re: GT2560 Firmware Marlin Anet A8 June 22, 2018 11:52AM |
Re: GT2560 Firmware Marlin Anet A8 June 22, 2018 11:58AM |
Re: GT2560 Firmware Marlin Anet A8 June 23, 2018 06:46AM |
//#define ENDSTOP_INTERRUPTS_FEATURE
// Not all used endstop/probe -pins can raise interrupts. Please deactivate ENDSTOP_INTERRUPTS or change the pin configuration!
Re: GT2560 Firmware Marlin Anet A8 June 23, 2018 10:06AM |
Re: GT2560 Firmware Marlin Anet A8 June 23, 2018 05:17PM |
Re: GT2560 Firmware Marlin Anet A8 June 24, 2018 04:36AM |
onekk
Beh per marlin non so per MarlinKimbra MK4duo c'èil configuratore online, ABL lo uso sulla mia cartesiana P3Steel e va, presumo che scheda sia supportata, e mi pare che ci sia anche una configurazione per la Anet A8 in giro non dovrebbe essere complicato adattarla a MarlinKimbra.
Il funzionamento è simile però MK4duo un buon configuratore online che si prende carico di molte cose complicate come settare i #DEFINE quando sono collegati tra loro e magari vanno settati in punti diversi dei file.
Altro punto di forza di MK4duo è il file Configuration_Overall.h che ti permette di trasferire una configurazione tra versioni del firmware diverse caricando solo quello.
L'unica pecca è la documentazione fine, ma ci stiamo lavorando e il Mago lo trovi sul forum e se può aiuta.
Saluti
Carlo D.
Re: GT2560 Firmware Marlin Anet A8 June 24, 2018 04:37AM |
Re: GT2560 Firmware Marlin Anet A8 June 24, 2018 05:01AM |
Re: GT2560 Firmware Marlin Anet A8 June 24, 2018 10:57AM |
onekk
Il firmware è il programma che ti permette di far funzionare la scheda, è una cosa abbastanza complicata per cui:
1) usi un firmware pre compilato che trovi in giro e che va bene per la tua scheda
2) ne compili uno tu con una guida online (devi leggere e soprattutto sapere bene cosa usi come motori, termistori, sonde e pin di collegamenti vari)
3) ne compili uno usando un firmware che abbia un configuratore online (e devi sapere le stesse cose del punto 2)
4) trovi una buonanima che te lo compili lui.
Nel tuo caso, hai comprato una scheda, non conosco le motivazioni per cui la scheda stock non vada bene.
Però se non vuoi sbatterti un pochino e imparare le cose, che vuol dire leggere alcune cosucce in giro e perderci un po' di tempo, le uniche vie che hai sono la 1 o la 4.
Però anche in questi casi devi comunque dirci cosa monta la tua stampante, perché anet A8 ce ne sono varie versioni e quindi ritorni ancora nella casistica del 2 e del 3, almeno per comunicarle alla buonanima del punto 4 oppure scegliere con cognizione di causa un firmware precompilato al punto 1.
Saluti e buone future stampe
Carlo D.
Re: GT2560 Firmware Marlin Anet A8 June 24, 2018 11:23AM |
Re: GT2560 Firmware Marlin Anet A8 June 24, 2018 12:13PM |
Re: GT2560 Firmware Marlin Anet A8 June 24, 2018 12:44PM |
