Simplify3d Profili,Scripts e temperature... Bel caos.. July 07, 2018 01:07PM |
;Gcode HE DX (T0) M280 P0 F160 ; Reset BLTouch M104 S[extruder0_temperature] T0 M104 S0 T1 M109 S[extruder0_temperature] T0 G92 E0; resetta extruder G28 ; Autohome G29 ; Autolevel G1 X-10 Y15 F5000 G1 E20 F150 ;purge the filament a bit before starting print G92 E0; resetta extruder M530 S1; Start print
;Gcode HE SIN (T1) M280 P0 F160 ; Reset BLTouch M104 S[extruder1_temperature] T1 M104 S0 T0 M109 S[extruder1_temperature] T1 G92 E0; resetta extruder G28 ; Autohome G29 ; Autolevel G1 X0 Y15 F5000 G1 E20 F150 ;purge the filament a bit before starting print G92 E0; resetta extruder M530 S1; Start printQui imposto il riscaldamento del T1 e dico di attendere, imposto inoltre T0 a zero. Il piatto si arrangia da solo S3d
; G-Code generated by Simplify3D(R) Version 4.0.1 ; Jul 7, 2018 at 7:02:08 PM ; Settings Summary ..... ; printExtruders,Right Extruder Only ; extruderName,Right Extruder T0,Left Extruder T1 ; extruderToolheadNumber,0,1 ....... G90 M82 M106 S255 G4 P500 M106 S0 M140 S80 M190 S80 M280 P0 F160 ; Reset BLTouch M104 S230 T0 M104 S0 T1 M109 S230 T0 G92 E0; resetta extruder G28 ; Autohome G29 ; Autolevel G1 X-10 Y15 F5000 G1 E20 F150 ;purge the filament a bit before starting print G92 E0; resetta extruder M530 S1; Start print G92 E0 G1 E-5.0000 F3000 G1 Z0.300 F1002 ; process Color1 ; layer 1, Z = 0.200 M104 S230 T1 ;G4 P1000 M105 T0 ; tool H0.200 W0.460 ; skirte avanti..
Re: Simplify3d Profili,Scripts e temperature... Bel caos.. July 11, 2018 05:10PM |
Re: Simplify3d Profili,Scripts e temperature... Bel caos.. July 12, 2018 12:37AM |
