MK4DUO 4.3.6 e PT100 September 16, 2018 08:03AM |
Re: MK4DUO 4.3.6 e PT100 September 16, 2018 08:24AM |
Re: MK4DUO 4.3.6 e PT100 September 16, 2018 10:00AM |
Re: MK4DUO 4.3.6 e PT100 September 16, 2018 10:24AM |
Re: MK4DUO 4.3.6 e PT100 September 16, 2018 10:34AM |
Re: MK4DUO 4.3.6 e PT100 September 16, 2018 11:21AM |
Re: MK4DUO 4.3.6 e PT100 September 16, 2018 11:35AM |
Re: MK4DUO 4.3.6 e PT100 September 16, 2018 03:21PM |
Re: MK4DUO 4.3.6 e PT100 September 16, 2018 04:16PM |
Re: MK4DUO 4.3.6 e PT100 September 16, 2018 04:51PM |
Re: MK4DUO 4.3.6 e PT100 September 17, 2018 02:52AM |
Re: MK4DUO 4.3.6 e PT100 September 17, 2018 03:45AM |
Re: MK4DUO 4.3.6 e PT100 September 17, 2018 03:46AM |
Re: MK4DUO 4.3.6 e PT100 September 17, 2018 10:50AM |
Re: MK4DUO 4.3.6 e PT100 September 18, 2018 02:52AM |
M43 - Display pin status, watch pins for changes, watch endstops & toggle LED, Z servo probe test, toggle pins * * M43 - report name and state of pin(s) * P Pin to read or watch. If omitted, reads all pins. * I Flag to ignore MK4duo's pin protection. * * M43 W - Watch pins -reporting changes- until reset, click, or M108. * P Pin to read or watch. If omitted, read/watch all pins. * I Flag to ignore MK4duo's pin protection. * * M43 E - Enable / disable background endstop monitoring * - Machine continues to operate * - Reports changes to endstops * - Toggles LED when an endstop changes * - Can not reliably catch the 5mS pulse from BLTouch type probes * * M43 T - Toggle pin(s) and report which pin is being toggled * S - Start Pin number. If not given, will default to 0 * L - End Pin number. If not given, will default to last pin defined for this board * I - Flag to ignore MK4duo's pin protection. Use with caution!!!! * R - Repeat pulses on each pin this number of times before continueing to next pin * W - Wait time (in miliseconds) between pulses. If not given will default to 500 * * M43 S - Servo probe test * P - Probe index (optional - defaults to 0
Re: MK4DUO 4.3.6 e PT100 September 18, 2018 01:53PM |
Re: MK4DUO 4.3.6 e PT100 September 18, 2018 02:54PM |
* M305 - Set thermistor and ADC parameters: H[heaters] H = 0-3 Hotend, H = -1 BED, H = -2 CHAMBER, H = -3 COOLER, * A[float] Thermistor resistance at 25°C, B[float] BetaK, C[float] Steinhart-Hart C coefficien, R[float] Pullup resistor value, * L[int] ADC low offset correction, O[int] ADC high offset correction, P[int] Sensor Pin
Re: MK4DUO 4.3.6 e PT100 September 18, 2018 03:32PM |
Re: MK4DUO 4.3.6 e PT100 September 18, 2018 03:46PM |
Re: MK4DUO 4.3.6 e PT100 September 19, 2018 03:10PM |
P[int] Sensor Pin
Re: MK4DUO 4.3.6 e PT100 September 19, 2018 05:50PM |
Re: MK4DUO 4.3.6 e PT100 September 20, 2018 02:13PM |
Re: MK4DUO 4.3.6 e PT100 September 20, 2018 05:58PM |
diff -b -y --left-column ~/devel/MK4duo/MK4duo/Configuration_Overall.h ~/3D/MK4duo/Configuration_Overall.h > ~/diff.txt
