ok, c'ho provato, non funziona.In più tra un comando ogni tanto gli stepper di z fanno un casino come se si fossero bloccati ,che vuol dire? Ti lascio i log che partono da quando la stampante parte ,grazie.
16:52:16.303 : Printer reset detected - initalizing
16:52:16.303 : start
16:52:16.303 : echo: External Reset
16:52:16.304 : Marlin 1.1.8_12302017
16:52:16.308 : echo: Last Updated: 2017-12-30 12:00PM | Author: (Wysocki, Gtech 1.1.7 12192017)
16:52:16.308 : echo:Compiled: Sep 27 2018
16:52:16.311 : echo: Free Memory: 3800 PlannerBufferBytes: 1232
16:52:16.321 : echo:V47 stored settings retrieved (614 bytes; crc 23021)
16:52:16.323 : echo: G21 ; Units in mm
16:52:16.323 : echo: M149 C ; Units in Celsius
16:52:16.325 : echo:Filament settings: Disabled
16:52:16.326 : echo: M200 D1.75
16:52:16.326 : echo: M200 D0
16:52:16.327 : echo
teps per unit:
16:52:16.329 : echo: M92 X81.50 Y81.50 Z2577.46 E94.00
16:52:16.330 : echo:Maximum feedrates (units/s):
16:52:16.333 : echo: M203 X400.00 Y400.00 Z2.00 E45.00
16:52:16.334 : echo:Maximum Acceleration (units/s2):
16:52:16.336 : echo: M201 X4000 Y4000 Z40 E4000
16:52:16.338 : echo:Acceleration (units/s2): P R T
16:52:16.340 : echo: M204 P3000.00 R3000.00 T3000.00
16:52:16.345 : echo:Advanced: S T B X Z E
16:52:16.348 : echo: M205 S0.00 T0.00 B20000 X10.00 Y10.00 Z0.30 E5.00
16:52:16.349 : echo:Home offset:
16:52:16.350 : echo: M206 X0.00 Y0.00 Z0.00
16:52:16.350 : echo:Auto Bed Leveling:
16:52:16.351 : echo: M420 S0
16:52:16.353 : echo:Material heatup parameters:
16:52:16.354 : echo: M145 S0 H180 B70 F0
16:52:16.354 : echo: M145 S1 H215 B105 F0
16:52:16.355 : echo
ID settings:
16:52:16.357 : echo: M301 P22.20 I1.08 D114.00
16:52:16.358 : echo:Z-Probe Offset (mm):
16:52:16.358 : echo: M851 Z0.00
16:52:16.495 : N1 M110*34
16:52:16.495 : N2 M115*36
16:52:16.495 : N3 M105*36
16:52:16.495 : N4 M114*35
16:52:16.503 : N5 M111 S6*98
16:52:16.506 : N6 T0*60
16:52:16.506 : N7 M20*22
16:52:16.512 : N8 M80*19
16:52:16.513 : N9 M105*46
16:52:19.553 : N10 M105*22
16:52:20.232 : FIRMWARE_NAME:Marlin 1.1.8_12302017 (Wysocki) SOURCE_CODE_URL:[
github.com] PROTOCOL_VERSION:1.0 MACHINE_TYPE
i3 Pro B EXTRUDER_COUNT:1 UUID:cede2a2f-41a2-4748-9b12-c55c62f367ff
16:52:20.232 : N11 M220 S100*81
16:52:20.233 : Cap
ERIAL_XON_XOFF:0
16:52:20.233 : Cap:EEPROM:1
16:52:20.234 : Cap:VOLUMETRIC:1
16:52:20.234 : Cap:AUTOREPORT_TEMP:1
16:52:20.236 : Cap
ROGRESS:0
16:52:20.236 : Cap
RINT_JOB:1
16:52:20.237 : Cap:AUTOLEVEL:1
16:52:20.237 : Cap:Z_PROBE:1
16:52:20.238 : Cap:LEVELING_DATA:1
16:52:20.238 : Cap:BUILD_PERCENT:0
16:52:20.239 : Cap
OFTWARE_POWER:0
16:52:20.241 : Cap:TOGGLE_LIGHTS:0
16:52:20.242 : Cap:CASE_LIGHT_BRIGHTNESS:0
16:52:20.242 : Cap:EMERGENCY_PARSER:0
16:52:20.249 : X:0.00 Y:0.00 Z:0.00 E:0.00 Count X:0 Y:0 Z:0
16:52:20.249 : echo
EBUG:INFO,ERRORS
16:52:20.249 : N12 M221 S100*83
16:52:20.250 : N13 M111 S6*85
16:52:20.255 : echo:Active Extruder: 0
16:52:20.255 : Begin file list
16:52:20.262 : N14 T0*15
16:52:20.262 : N15 M155 S1*84
16:52:20.263 : End file list
16:52:20.272 : echo
EBUG:INFO,ERRORS
16:52:20.272 : echo:Active Extruder: 0
16:52:21.423 : echo
D init fail
16:53:24.455 : N16 M140 S60*100
16:53:25.031 : N17 M104 T0 S200*21
16:54:24.622 : Slic3r installed in a loclized path. Using an 8.3 path: "C:\PROGRA~1\REPETI~1\Slic3rPE\"
16:54:37.214 : N18 M140 S0*92
16:54:37.621 : N19 M104 T0 S0*25
