Dopo l'auto livellamento l'asse z si alza e stampa a vuoto
Posted by Filippo01
Re: Dopo l'auto livellamento l'asse z si alza e stampa a vuoto
October 04, 2018 10:58AM
ok, c'ho provato, non funziona.In più tra un comando ogni tanto gli stepper di z fanno un casino come se si fossero bloccati ,che vuol dire? Ti lascio i log che partono da quando la stampante parte ,grazie.
16:52:16.303 : Printer reset detected - initalizing
16:52:16.303 : start
16:52:16.303 : echo: External Reset
16:52:16.304 : Marlin 1.1.8_12302017
16:52:16.308 : echo: Last Updated: 2017-12-30 12:00PM | Author: (Wysocki, Gtech 1.1.7 12192017)
16:52:16.308 : echo:Compiled: Sep 27 2018
16:52:16.311 : echo: Free Memory: 3800 PlannerBufferBytes: 1232
16:52:16.321 : echo:V47 stored settings retrieved (614 bytes; crc 23021)
16:52:16.323 : echo: G21 ; Units in mm
16:52:16.323 : echo: M149 C ; Units in Celsius
16:52:16.325 : echo:Filament settings: Disabled
16:52:16.326 : echo: M200 D1.75
16:52:16.326 : echo: M200 D0
16:52:16.327 : echoconfused smileyteps per unit:
16:52:16.329 : echo: M92 X81.50 Y81.50 Z2577.46 E94.00
16:52:16.330 : echo:Maximum feedrates (units/s):
16:52:16.333 : echo: M203 X400.00 Y400.00 Z2.00 E45.00
16:52:16.334 : echo:Maximum Acceleration (units/s2):
16:52:16.336 : echo: M201 X4000 Y4000 Z40 E4000
16:52:16.338 : echo:Acceleration (units/s2): P R T
16:52:16.340 : echo: M204 P3000.00 R3000.00 T3000.00
16:52:16.345 : echo:Advanced: S T B X Z E
16:52:16.348 : echo: M205 S0.00 T0.00 B20000 X10.00 Y10.00 Z0.30 E5.00
16:52:16.349 : echo:Home offset:
16:52:16.350 : echo: M206 X0.00 Y0.00 Z0.00
16:52:16.350 : echo:Auto Bed Leveling:
16:52:16.351 : echo: M420 S0
16:52:16.353 : echo:Material heatup parameters:
16:52:16.354 : echo: M145 S0 H180 B70 F0
16:52:16.354 : echo: M145 S1 H215 B105 F0
16:52:16.355 : echotongue sticking out smileyID settings:
16:52:16.357 : echo: M301 P22.20 I1.08 D114.00
16:52:16.358 : echo:Z-Probe Offset (mm):
16:52:16.358 : echo: M851 Z0.00
16:52:16.495 : N1 M110*34
16:52:16.495 : N2 M115*36
16:52:16.495 : N3 M105*36
16:52:16.495 : N4 M114*35
16:52:16.503 : N5 M111 S6*98
16:52:16.506 : N6 T0*60
16:52:16.506 : N7 M20*22
16:52:16.512 : N8 M80*19
16:52:16.513 : N9 M105*46
16:52:19.553 : N10 M105*22
16:52:20.232 : FIRMWARE_NAME:Marlin 1.1.8_12302017 (Wysocki) SOURCE_CODE_URL:[github.com] PROTOCOL_VERSION:1.0 MACHINE_TYPEtongue sticking out smileyi3 Pro B EXTRUDER_COUNT:1 UUID:cede2a2f-41a2-4748-9b12-c55c62f367ff
16:52:20.232 : N11 M220 S100*81
16:52:20.233 : Capconfused smileyERIAL_XON_XOFF:0
16:52:20.233 : Cap:EEPROM:1
16:52:20.234 : Cap:VOLUMETRIC:1
16:52:20.234 : Cap:AUTOREPORT_TEMP:1
16:52:20.236 : Captongue sticking out smileyROGRESS:0
16:52:20.236 : Captongue sticking out smileyRINT_JOB:1
16:52:20.237 : Cap:AUTOLEVEL:1
16:52:20.237 : Cap:Z_PROBE:1
16:52:20.238 : Cap:LEVELING_DATA:1
16:52:20.238 : Cap:BUILD_PERCENT:0
16:52:20.239 : Capconfused smileyOFTWARE_POWER:0
16:52:20.241 : Cap:TOGGLE_LIGHTS:0
16:52:20.242 : Cap:CASE_LIGHT_BRIGHTNESS:0
16:52:20.242 : Cap:EMERGENCY_PARSER:0
16:52:20.249 : X:0.00 Y:0.00 Z:0.00 E:0.00 Count X:0 Y:0 Z:0
16:52:20.249 : echogrinning smileyEBUG:INFO,ERRORS
16:52:20.249 : N12 M221 S100*83
16:52:20.250 : N13 M111 S6*85
16:52:20.255 : echo:Active Extruder: 0
16:52:20.255 : Begin file list
16:52:20.262 : N14 T0*15
16:52:20.262 : N15 M155 S1*84
16:52:20.263 : End file list
16:52:20.272 : echogrinning smileyEBUG:INFO,ERRORS
16:52:20.272 : echo:Active Extruder: 0
16:52:21.423 : echoconfused smileyD init fail
16:53:24.455 : N16 M140 S60*100
16:53:25.031 : N17 M104 T0 S200*21
16:54:24.622 : Slic3r installed in a loclized path. Using an 8.3 path: "C:\PROGRA~1\REPETI~1\Slic3rPE\"
16:54:37.214 : N18 M140 S0*92
16:54:37.621 : N19 M104 T0 S0*25
October 04, 2018 11:05AM
se qualcuno usa la mia stampante e il bltouch mi condividerebbe il suo marlin e magari il gcode personalizzato che aggiunge allo slicer, che non ce la faccio piùeye rolling smiley
Edited 1 time(s). Last edit at 10/04/2018 11:06AM by Filippo01.
October 04, 2018 11:27AM
Ho fatto un'altro test,ho fatto G29 a mano, inizialmente al 4 punto si bloccava poi ho risolto aggiustando l'inclinazione del bltouch(è molto alto forse dovrei abbassarlo un pochino) comunque dopo ha funzionato e sta perfettamente a terra.Io non voglio dire ma perchè a mano va e automaticamente no?non ha senso, e poi non ce un modo,che so levare nel gcode personalizzato tutti i comandi di home e magari farli manualmente prima della stampa così ce li ha già salvati?
Edited 1 time(s). Last edit at 10/04/2018 11:29AM by Filippo01.
October 07, 2018 12:44PM
allora ho provato col metodo che ho scritto prima e funziona ma ce un problema ho notato che tutte le stampe che facevo risultavano schiacciate ed il pla superava di altezza l'estrusore.Guardando meglio ho notato che dopo ogni layer lo stepper quando è in procinto di muoversi per aumentare l'altezza fa un rumorino strano per mezzo secondo o meno ma non si muove. Il punto è che funzionano perfettamente i motori(credo) perchè se li controllo io girano e poi girano anche nel bel mezzo della stampa per conpensare il piatto livellato male, solo in quel punto si bloccano. In più anche il problema della home che mi tocca fare a mano perchè nel gcode personalizzato non va (il problema è descritto sopra) non so più cosa fare sono disperato sad smiley . Aprirò un'altro topic visto che questo è un'altro problema(credo)
October 07, 2018 02:48PM
allora ho fatto un controllo muovendoli a 10 1 0,1 e 0,01 mm non sono i motori
