Problema compilazione MK4Duo 4.3.8 March 06, 2019 03:52PM |
Arduino:1.8.8 (Windows Store 1.8.19.0) (Windows 10), Scheda:"Arduino Due (Programming Port)" In file included from sketch\src\core\eeprom\../../../src/platform/platform.h:33:0, from sketch\src\core\eeprom\../../../MK4duo.h:111, from sketch\src\core\eeprom\eeprom.cpp:39: sketch\src\core\eeprom\eeprom.cpp: In static member function 'static void EEPROM:rint_Settings()': sketch\src\core\eeprom\eeprom.cpp:1941:27: error: 'class GCodeParser' has no member named 'temp_units_code' SERIAL_CHR(parser.temp_units_code); ^ sketch\src\core\eeprom\../../../src/platform/common/communication.h:124:57: note: in definition of macro 'SERIAL_CHR' #define SERIAL_CHR(c) (Com::write(c)) ^ sketch\src\core\eeprom\eeprom.cpp:1943:27: error: 'class GCodeParser' has no member named 'temp_units_name' SERIAL_PGM(parser.temp_units_name()); ^ sketch\src\core\eeprom\../../../src/platform/common/communication.h:118:60: note: in definition of macro 'SERIAL_PGM' #define SERIAL_PGM(message) (Com::printPGM(message)) ^ sketch\src\core\eeprom\eeprom.cpp:1939:37: error: 'class GCodeParser' has no member named 'to_temp_units' #define TEMP_UNIT(N) parser.to_temp_units(N) ^ sketch\src\core\eeprom\../../../src/platform/common/communication.h:123:57: note: in definition of macro 'SERIAL_VAL' #define SERIAL_VAL(val, ...) (Com::print(val, ## __VA_ARGS__)) ^ sketch\src\core\eeprom\eeprom.cpp:2061:9: note: in expansion of macro 'SERIAL_MV' SERIAL_MV(" H", TEMP_UNIT(lcdui.preheat_hotend_temp)); ^ sketch\src\core\eeprom\eeprom.cpp:2061:25: note: in expansion of macro 'TEMP_UNIT' SERIAL_MV(" H", TEMP_UNIT(lcdui.preheat_hotend_temp)); ^ sketch\src\core\eeprom\eeprom.cpp:1939:37: error: 'class GCodeParser' has no member named 'to_temp_units' #define TEMP_UNIT(N) parser.to_temp_units(N) ^ sketch\src\core\eeprom\../../../src/platform/common/communication.h:123:57: note: in definition of macro 'SERIAL_VAL' #define SERIAL_VAL(val, ...) (Com::print(val, ## __VA_ARGS__)) ^ sketch\src\core\eeprom\eeprom.cpp:2062:9: note: in expansion of macro 'SERIAL_MV' SERIAL_MV(" B", TEMP_UNIT(lcdui.preheat_bed_temp)); ^ sketch\src\core\eeprom\eeprom.cpp:2062:25: note: in expansion of macro 'TEMP_UNIT' SERIAL_MV(" B", TEMP_UNIT(lcdui.preheat_bed_temp)); ^ exit status 1 Errore durante la compilazione per la scheda Arduino Due (Programming Port).
Re: Problema compilazione MK4Duo 4.3.8 March 07, 2019 02:51AM |
Re: Problema compilazione MK4Duo 4.3.8 March 07, 2019 06:57AM |
