MK 4.3.6 ultima versione non va, ok versioni più vecchie March 17, 2019 02:09PM |
Re: MK 4.3.6 ultima versione non va, ok versioni più vecchie March 17, 2019 04:05PM |
Re: MK 4.3.6 ultima versione non va, ok versioni più vecchie March 17, 2019 05:00PM |
Re: MK 4.3.6 ultima versione non va, ok versioni più vecchie March 17, 2019 05:05PM |
Re: MK 4.3.6 ultima versione non va, ok versioni più vecchie March 17, 2019 05:56PM |
start
Info:Echo:MK4duo_4.3.6
Echo:Last Updated: Aug 19 2018 23:19:48 | Author: (none, default config)
Echo:Compiled: Aug 19 2018
Echo:Free Memory: 2771 PlannerBufferBytes: 1456
SD card ok
MKV50 stored settings retrieved (330 bytes; crc 26228)
Config:
G21 ; Units in (mm)
Configteps per unit:
Config: M92 X80.000 Y80.000 Z2560.000 T0 E600.000
Config:Maximum feedrates (units/s):
Config: M203 X300.000 Y300.000 Z2.000 T0 E100.000
Config:Maximum Acceleration (units/s2):
Config: M201 X1500 Y1500 Z50 T0 E3000
Config:Acceleration (units/s2): P V T* R:
Config: M204 P3000.000 V3000.000 T0 R10000.000
Config:Advanced variables: B S V:
Config: M205 B20000 S0.000 V0.000
Config:Junction Deviation: J:
Config: M205 J0.050
Config:Heater Sensor parameters: H P A B C R L O:
Config: M305 H0 P13 A100000.0 B4725.0 C0.0000000000 R4700.0 L0 O0
Config:Heater parameters: H P A B C L O U I:
Config: M306 H0 P10 A40 B230 C255 L5 O275 U1 I0
Config:Heater PID parameters: H P I D:
Config: M301 H0 P22.20 I1.08 D114.00
Config: M305 H-1 P14 A100000.0 B4725.0 C0.0000000000 R4700.0 L0 O0
Config: M306 H-1 P8 A80 B255 C255 L5 O150 U0 I0
Config:Fans: P U L F I H :
Config: M106 P0 U9 L0 F250 I0
Config: M149 C ; Units in Celsius
Config:Material heatup parameters:
Config: M145 S0 H190 B60 F255
Config: M145 S1 H240 B100 F255
Config: M145 S2 H230 B60 F255
Configtepper Direction:
Config: M569 X1 Y1 Z1 T0 E0
Configtepper driver control:
Config: M569 D0 P0 R500000
Configtepper driver current:
Config: M906 X750 Y750 Z750 T0 E750
Config:Hysteresis Correction:
Config: M99 X0.00 Y0.00 Z0.00 F1.00
Stats: Total: 0, Finished: 0, Failed: 0
Stats: Total print time: 0s, Power on time: 0s
Stats: Filament used: 0Km 0m 0cm 0mm
wait
SD card ok
start
Echo:Last Updated: Mar 17 2019 22:49:19 | Author: (none, default config)
Echo:Compiled: Mar 17 2019
Echo:Free Memory: 2780 PlannerBufferBytes: 1456
SD card ok
Echo:EEPROM version mismatch (EEPROM=MKV50 MK4duo=MKV51)
Re: MK 4.3.6 ultima versione non va, ok versioni più vecchie March 17, 2019 07:29PM |
Re: MK 4.3.6 ultima versione non va, ok versioni più vecchie March 17, 2019 07:41PM |
Re: MK 4.3.6 ultima versione non va, ok versioni più vecchie March 18, 2019 03:58AM |
Re: MK 4.3.6 ultima versione non va, ok versioni più vecchie March 18, 2019 06:18AM |
però non è normale che se dai un comando di movimento asse X (per esempio) si muova pure (e senza motivo) asse Y fino a Y200 (cosa che non succede sulla 4.3.7 e quindi non è il fatto che ZPROBE sia sempre triggered e su quello hai ragione)Quote
potrebbe esserci qualcosa di sbagliato nelle config (sono esperimenti).
Re: MK 4.3.6 ultima versione non va, ok versioni più vecchie March 18, 2019 07:05AM |
Re: MK 4.3.6 ultima versione non va, ok versioni più vecchie March 18, 2019 07:57AM |
Ok ma io non ho una coreXY ma una normale cartesiana con assi X e Y separatiQuote
MagoKimbra
Allora il movimento su X e anche di Y capita solo sulla coreXY dopo aver fatto G29, ma visto che g29 si fa solo una volta e poi si salva in eeprom e a inizio stampa si da il G28 il tutto non accade, questo lo so e sto investigando ma non avendo una core sto vedendo anche se su marlin risolvono.
Si quello della Delta (la Geeetech G2S è una delta).Quote
Il resto è assurdo, la lettura degli endstop avviene solo in home e si legge un pin se è allo stato 0 o allo stato 1, non si fa altro.
Di quale commento su github parli? Per caso quello della delta?
Serve solo ad evitare le contestazioni del tipo "hai ripristinato le config a default ? quando si cambia un fw bisogna sempre resettare a impost. di fabbrica e poi riconfigurare" che spesso si usa in informatica.Quote
Il problema è come si usa sta benedetta Eeprom, ma perché dovrei resettarli al valore di default??? A che diamine serve??
Re: MK 4.3.6 ultima versione non va, ok versioni più vecchie March 18, 2019 08:13AM |
Re: MK 4.3.6 ultima versione non va, ok versioni più vecchie March 18, 2019 09:27AM |
Re: MK 4.3.6 ultima versione non va, ok versioni più vecchie March 18, 2019 09:55AM |
Re: MK 4.3.6 ultima versione non va, ok versioni più vecchie March 18, 2019 10:37AM |
Re: MK 4.3.6 ultima versione non va, ok versioni più vecchie March 18, 2019 10:51AM |
Re: MK 4.3.6 ultima versione non va, ok versioni più vecchie March 18, 2019 11:28AM |
Re: MK 4.3.6 ultima versione non va, ok versioni più vecchie March 18, 2019 11:47AM |
Re: MK 4.3.6 ultima versione non va, ok versioni più vecchie March 18, 2019 11:53AM |
Re: MK 4.3.6 ultima versione non va, ok versioni più vecchie March 18, 2019 12:15PM |
const float z_homing_height = home_flag.ZHomed ? MIN_Z_HEIGHT_FOR_HOMING : 0;
const float z_homing_height = MIN_Z_HEIGHT_FOR_HOMING;
Re: MK 4.3.6 ultima versione non va, ok versioni più vecchie August 18, 2019 06:30AM |
Visto che il 4.3.9 è stato rilasciato, questa parte è poi diventata una opzione o c'è ancora da modificare cartesian_mechanics.cpp ?Quote
MagoKimbra
No non c'è, posso metterlo, ma nella 4.3.9, non nella 4.3.8...
per ora se vuoi cerca in cartesian_mechanics.cpp la riga
la cambi con
