Errore compilazione MK4.3.9 April 22, 2019 06:09AM |
"C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -MMD -flto -mmcu=atmega2560 -DF_CPU=16000000L -DARDUINO=10805 -DARDUINO_AVR_MEGA2560 -DARDUINO_ARCH_AVR "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino" "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\variants\mega" "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\SPI\src" "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\Wire\src" "C:\Users\CARLO~1.CAR\AppData\Local\Temp\arduino_build_95393\sketch\src\lcd\menu\menu_advanced.cpp" -o "C:\Users\CARLO~1.CAR\AppData\Local\Temp\arduino_build_95393\sketch\src\lcd\menu\menu_advanced.cpp.o"
C:\Users\CARLO~1.CAR\AppData\Local\Temp\arduino_build_95393\sketch\src\lcd\menu\menu_advanced.cpp:368:55: error: macro "PID_BED_MENU_ITEMS" passed 2 arguments, but takes just 0
if (beds[0].isUsePid()) { PID_BED_MENU_ITEMS("", 0); }
C:\Users\CARLO~1.CAR\AppData\Local\Temp\arduino_build_95393\sketch\src\lcd\menu\menu_advanced.cpp: In function 'void menu_advanced_temperature()':
C:\Users\CARLO~1.CAR\AppData\Local\Temp\arduino_build_95393\sketch\src\lcd\menu\menu_advanced.cpp:368:31: error: 'PID_BED_MENU_ITEMS' was not declared in this scope
Re: Errore compilazione MK4.3.9 April 22, 2019 08:16AM |
Re: Errore compilazione MK4.3.9 April 22, 2019 09:10AM |
….. ….. 14:40:23.274 : Config: M603 T3 L900.00 U900.00 14:40:23.274 : Stats: Total:80, Finished:62, Failed:18 14:40:23.274 : Stats: Total print time:1d 21h 40m 9s, Longest job:11h 43m 11s 14:40:23.274 : Stats: Power on time:5d 4h 39m 20s 14:40:23.274 : Stats: Filament used:244m 73cm 8mm 14:40:24.540 : Nextion 7" connected! 14:40:24.618 : ErrorD init fail 14:40:24.618 : SD initialization failed. 14:40:24.618 : Do not reformat the card! 14:40:24.618 : Is the card correctly inserted? 14:40:24.618 : Is chipSelect set to the correct value? 14:40:24.618 : Does another SPI device need to be disabled? 14:40:24.618 : Is there a wiring/soldering problem? 14:40:25.118 : errorCode: 48ok 14:40:26.181 : Printer reset detected - initalizing 14:40:26.181 : start 14:40:26.181 : Printer reset detected - initalizing 14:40:26.181 : start 14:40:26.181 : echo:echo:MK4duo_4.3.9 14:40:26.181 : echo:Last Updated: Apr 22 2019 14:29:56 | Author: (Carlo, V439 ABL NXT Box El) 14:40:26.181 : echo:Compiled: Apr 22 2019 14:40:26.181 : echo:Free Memory: 2698 PlannerBufferBytes: 1200 14:40:26.181 : Error
D init fail 14:40:26.181 : SD initialization failed. 14:40:26.181 : Do not reformat the card! 14:40:26.181 : Is the card correctly inserted? 14:40:26.181 : Is chipSelect set to the correct value? 14:40:26.181 : Does another SPI device need to be disabled? 14:40:26.181 : Is there a wiring/soldering problem? 14:40:26.524 : errorCode: 48echo:MKV63 Stored settings retrieved (522 bytes; crc 50746) 14:40:26.524 : Config: G21 ; Units in (mm) 14:40:26.524 : Config
teps per unit: 14:40:26.524 : Config: M92 X80.100 Y80.100 Z400.000 14:40:26.524 : Config: M92 T0 E94.000 14:40:26.524 : Config: M92 T1 E94.000 14:40:26.524 : Config: M92 T2 E94.000 …. ….
Re: Errore compilazione MK4.3.9 April 22, 2019 10:17AM |
Re: Errore compilazione MK4.3.9 April 22, 2019 10:41AM |
Re: Errore compilazione MK4.3.9 April 22, 2019 12:03PM |
Re: Errore compilazione MK4.3.9 April 22, 2019 01:06PM |
D init fail", bo! comunque la SD poi la legge regolarmente.|
Re: Errore compilazione MK4.3.9 April 22, 2019 01:36PM |
Re: Errore compilazione MK4.3.9 April 26, 2019 04:39AM |
In file included from sketch\src/platform/platform.h:42:0,
from sketch\MK4duo.h:112,
from C:\Users\Roberto\Desktop\MK4duo\MK4duo.ino:343:
sketch\src/commands/parser.h: In static member function 'static char* GCodeParser::temp_units_name()':
sketch\src/commands/parser.h:280:127: error: invalid conversion from 'const char*' to 'char*' [-fpermissive]
return input_temp_units == TEMPUNIT_K ? PSTR("Kelvin") : input_temp_units == TEMPUNIT_F ? PSTR("Fahrenheit") : PSTR("Celsius");
sketch\src/platform/HAL_DUE/HAL.h:96:17: note: in definition of macro 'PSTR'
#define PSTR(s) s
exit status 1
Errore durante la compilazione per la scheda Arduino Due (Programming Port).
Re: Errore compilazione MK4.3.9 April 26, 2019 08:50AM |
