Mk4duo 4.3.9 problema motori e software di gestione May 20, 2019 02:34AM |
Re: Mk4duo 4.3.9 problema motori e software di gestione May 20, 2019 11:48AM |
17:40:54.220 : N22 M43*36 17:40:54.570 : populated. populated. Port: E0 RXD protected 17:40:54.570 : populated. populated. Port: E1 TXD protected 17:40:54.571 : populated. populated. Port: E4 Input = 0 TIMER3B leRunout WGM: 0 COM3B: 0 CS: 2 TCCR3A: 0 TCCR3B: 2 TIMSK3: 2 non-standard PWM mode 17:40:54.580 : populated. populated. Port: E5 X_MIN_PIN populated. TIMER3C leRunout WGM: 0 COM3C: 0 CS: 2 TCCR3A: 0 TCCR3B: 2 TIMSK3: 2 non-standard PWM mode 17:40:54.581 : populated. populated. Port: G5 SERVO3_PIN Input = 0 TIMER0B leRunout WGM: 3 COM0B: 0 CS: 3 TCCR0A: 3 TCCR0B: 3 TIMSK0: 5 compare interrupt enabled overflow interrupt enabled 17:40:54.581 : populated. populated. Port: E3 SERVO2_PIN Input = 0 TIMER3A leRunout WGM: 0 COM3A: 0 CS: 2 TCCR3A: 0 TCCR3B: 2 TIMSK3: 2 non-standard PWM mode compare interrupt enabled 17:40:54.581 : populated. populated. Port: H3 SERVO1_PIN Input = 0 TIMER4A leRunout WGM: 1 COM4A: 0 CS: 3 TCCR4A: 1 TCCR4B: 3 TIMSK4: 0 17:40:54.581 : populated. populated. Port: H4 Input = 0 TIMER4B leRunout WGM: 1 COM4B: 0 CS: 3 TCCR4A: 1 TCCR4B: 3 TIMSK4: 0 17:40:54.582 : populated. populated. Port: H5 HEATER_BED0_PIN Output = 0 TIMER4C leRunout WGM: 1 COM4C: 0 CS: 3 TCCR4A: 1 TCCR4B: 3 TIMSK4: 0 17:40:54.582 : populated. populated. Port: H6 FAN0_PIN Output = 0 TIMER2B leRunout WGM: 1 COM2B: 0 CS: 4 TCCR2A: 1 TCCR2B: 4 TIMSK2: 0 17:40:54.582 : populated. populated. Port: B4 HEATER_HE0_PIN Output = 0 TIMER2A leRunout WGM: 1 COM2A: 0 CS: 4 TCCR2A: 1 TCCR2B: 4 TIMSK2: 0 17:40:54.583 : populated. populated. Port: B5 SERVO0_PIN Output = 0 TIMER1A leRunout WGM: 4 COM1A: 0 CS: 2 TCCR1A: 0 TCCR1B: 10 TIMSK1: 2 non-standard PWM mode compare interrupt enabled 17:40:54.583 : populated. populated. Port: B6 PS_ON_PIN Input = 0 TIMER1B leRunout WGM: 4 COM1B: 0 CS: 2 TCCR1A: 0 TCCR1B: 10 TIMSK1: 2 non-standard PWM mode 17:40:54.583 : populated. populated. Port: B7 LED_PIN Input = 0 TIMER0A leRunout WGM: 3 COM0A: 0 CS: 3 TCCR0A: 3 TCCR0B: 3 TIMSK0: 5 overflow interrupt enabled 17:40:54.583 : . TIMER1C is also tied to this pin TIMER1C out WGM: 4 COM1C: 0 CS: 2 TCCR1A: 0 TCCR1B: 10 TIMSK1: 2 non-standard PWM mode 17:40:54.584 : populated. populated. Port: J1 Y_MIN_PIN Input = 1 17:40:54.584 : populated. populated. Port: J0 Input = 0 17:40:54.584 : populated. populated. Port: H1 LCD_PINS_RS Output = 1 17:40:54.584 : populated. populated. Port: H0 LCD_PINS_ENABLE Output = 0 17:40:54.584 : populated. populated. Port: D3 Z_MIN_PIN Input = 0 17:40:54.584 : populated. populated. Port: D2 Input = 0 17:40:54.585 : populated. populated. Port: D1 Input = 1 17:40:54.585 : populated. populated. Port: D0 Input = 1 17:40:54.585 : populated. populated. Port: A0 Input = 0 17:40:54.585 : populated. populated. Port: A1 LCD_PINS_D4 Output = 0 17:40:54.585 : populated. populated. Port: A2 E0_ENABLE_PIN protected 17:40:54.585 : populated. populated. Port: A3 LCD_PINS_D5 Output = 0 17:40:54.907 : populated. populated. Port: A4 E0_STEP_PIN protected 17:40:54.907 : populated. populated. Port: A5 LCD_PINS_D6 Output = 0 17:40:54.907 : populated. populated. Port: A6 E0_DIR_PIN protected 17:40:54.908 : populated. populated. Port: A7 LCD_PINS_D7 Output = 0 17:40:54.908 : populated. populated. Port: C7 Input = 1 17:40:54.908 : populated. populated. Port: C6 BTN_EN1 Input = 1 17:40:54.918 : populated. populated. Port: C5 Input = 0 17:40:54.919 : populated. populated. Port: C4 BTN_EN2 Input = 1 17:40:54.919 : populated. populated. Port: C3 Input = 0 17:40:54.919 : populated. populated. Port: C2 BTN_ENC Input = 1 17:40:54.919 : populated. populated. Port: C1 Input = 0 17:40:54.923 : populated. populated. Port: C0 BEEPER_PIN Output = 0 17:40:54.923 : populated. populated. Port: D7 X_ENABLE_PIN protected 17:40:54.923 : populated. populated. Port: G2 Input = 0 17:40:54.924 : populated. populated. Port: G1 Z_CS_PIN Input = 0 17:40:54.924 : populated. populated. Port: G0 KILL_PIN Input = 1 17:40:54.924 : populated. populated. Port: L7 E0_CS_PIN Input = 0 17:40:54.924 : populated. populated. Port: L6 Input = 0 17:40:54.924 : populated. populated. Port: L5 Input = 0 TIMER5C leRunout WGM: 1 COM5C: 0 CS: 3 TCCR5A: 1 TCCR5B: 3 TIMSK5: 0 17:40:54.925 : populated. populated. Port: L4 Input = 0 TIMER5B leRunout WGM: 1 COM5B: 0 CS: 3 TCCR5A: 1 TCCR5B: 3 TIMSK5: 0 17:40:54.925 : populated. populated. Port: L3 Z_STEP_PIN protected 17:40:54.925 : populated. populated. Port: L2 Input = 0 17:40:54.925 : populated. populated. Port: L1 Z_DIR_PIN protected 17:40:54.925 : populated. populated. Port: L0 SD_DETECT_PIN Input = 1 17:40:54.926 : . Y_CS_PIN Input = 1 17:40:54.926 : populated. populated. Port: B3 MISO_PIN Input = 0 17:40:54.926 : populated. populated. Port: B2 MOSI_PIN Output = 1 17:40:54.926 : populated. populated. Port: B1 SCK_PIN populated. 17:40:54.926 : populated. populated. Port: B0 SDSS Output = 1 17:40:54.927 : . X_CS_PIN Output = 1 17:40:54.927 : populated. populated. Port: F0 X_STEP_PIN protected 17:40:54.927 : populated. populated. Port: F1 X_DIR_PIN protected 17:40:54.927 : populated. populated. Port: F2 Y_ENABLE_PIN protected 17:40:54.927 : populated. populated. Port: F3 Input = 0 17:40:54.928 : populated. populated. Port: F4 Input = 0 17:40:54.928 : populated. populated. Port: F5 Input = 0 17:40:54.928 : populated. populated. Port: F6 Y_STEP_PIN protected 17:40:54.928 : populated. populated. Port: F7 Y_DIR_PIN protected 17:40:54.928 : populated. populated. Port: K0 Z_ENABLE_PIN protected 17:40:54.928 : populated. populated. Port: K1 Input = 0 17:40:54.963 : populated. populated. Port: K2 Input = 0 17:40:54.963 : populated. populated. Port: K3 Input = 0 17:40:54.963 : populated. populated. Port: K4 MAX6675_SS_PIN Output = 1 17:40:54.963 : populated. populated. Port: K5 Input = 1 17:40:54.964 : populated. populated. Port: K6 Input = 1 17:40:54.964 : populated. populated. Port: K7 Input = 1
Re: Mk4duo 4.3.9 problema motori e software di gestione May 20, 2019 03:43PM |
Re: Mk4duo 4.3.9 problema motori e software di gestione May 21, 2019 02:14AM |
Re: Mk4duo 4.3.9 problema motori e software di gestione May 21, 2019 12:14PM |
Re: Mk4duo 4.3.9 problema motori e software di gestione May 21, 2019 01:16PM |
Re: Mk4duo 4.3.9 problema motori e software di gestione May 21, 2019 02:26PM |
Re: Mk4duo 4.3.9 problema motori e software di gestione May 26, 2019 06:20AM |
#define X_MAX_POS 200 #define X_MIN_POS 0 #define Y_MAX_POS 200 #define Y_MIN_POS 0 #define Z_MAX_POS 160 #define Z_MIN_POS 0 #define E_MIN_POS 0
Re: Mk4duo 4.3.9 problema motori e software di gestione May 26, 2019 08:23AM |
Re: Mk4duo 4.3.9 problema motori e software di gestione May 27, 2019 05:49AM |
#define Z_PROBE_END_SCRIPT "G1 Z10 F8000\nG1 X10 Y10\nG1 Z0.5mi accorgo ora che...leggendo bene il G-code.... una vota che ha fatto
G1 Z10non fa
\nG1 X10 Y10\nG1 Z0.5se successivamente decido di muovere, sempre da LCD, i vari assi nessun problema DX-SX SU-GIU’ AVANTI-INDIETRO.
Re: Mk4duo 4.3.9 problema motori e software di gestione May 27, 2019 07:47AM |
Re: Mk4duo 4.3.9 problema motori e software di gestione May 28, 2019 01:26AM |
Re: Mk4duo 4.3.9 problema motori e software di gestione May 29, 2019 02:28AM |
