prima installazione mk4duo su i3 pro w April 25, 2020 06:16PM |
Re: prima installazione mk4duo su i3 pro w April 25, 2020 06:56PM |
Re: prima installazione mk4duo su i3 pro w April 26, 2020 05:52AM |
Re: prima installazione mk4duo su i3 pro w April 26, 2020 10:33AM |
Arduino:1.8.12 (Linux), Scheda:"Arduino/Genuino Mega or Mega 2560, ATmega2560 (Mega 2560)"
In file included from sketch/src/commands/../../src/platform/platform.h:35:0,
from sketch/src/commands/../../MK4duo.h:116,
from sketch/src/commands/commands.cpp:29:
sketch/src/commands/gcode/host/m408.h: In function 'void gcode_M408()':
sketch/src/commands/gcode/host/m408.h:146:37: error: 'i' was not declared in this scope
SERIAL_MV("{\"number\":", i + 1);
sketch/src/commands/../../src/platform/common/communication/communication.h:96:91: note: in definition of macro 'SERIAL_OUT'
if (Com::serial_port_index == -1 || Com::serial_port_index == 0) (void)MKSERIAL1.WHAT(V); \
sketch/src/commands/../../src/platform/common/communication/communication.h:122:61: note: in expansion of macro 'SERIAL_VAL'
#define SERIAL_MV(msg,val,V...) do{ SERIAL_MSG(msg); SERIAL_VAL(val, ##V); }while(0)
sketch/src/commands/gcode/host/m408.h:146:11: note: in expansion of macro 'SERIAL_MV'
sketch/src/commands/../../src/platform/common/communication/communication.h:97:91: note: in definition of macro 'SERIAL_OUT'
if (Com::serial_port_index == -1 || Com::serial_port_index == 1) (void)MKSERIAL2.WHAT(V); \
In file included from sketch/src/commands/gcode/gcode.h:150:0,
from sketch/src/commands/commands.cpp:30:
sketch/src/commands/gcode/host/m408.h:153:24: error: 'i' was not declared in this scope
if (driver.e[i]) {
sketch/src/commands/gcode/host/m408.h:176:57: error: 'class ToolManager' has no member named 'flow_percentage'
SERIAL_VAL(mechanics.position.e * toolManager.flow_percentage[e]);
sketch/src/commands/gcode/host/m408.h:176:11: note: in expansion of macro 'SERIAL_VAL'
sketch/src/commands/gcode/host/m408.h:274:32: error: 'e' was not declared in this scope
SERIAL_VAL(extruders[e]->data.max_feedrate_mm_s);
sketch/src/commands/gcode/host/m408.h:274:11: note: in expansion of macro 'SERIAL_VAL'
sketch/src/commands/gcode/host/m408.h:277:9: error: break statement not within loop or switch
break;
sketch/src/commands/gcode/host/m408.h: At global scope:
sketch/src/commands/../../src/platform/common/communication/communication.h:95:33: error: expected unqualified-id before 'do'
#define SERIAL_OUT(WHAT,V...) do{ \
sketch/src/commands/../../src/platform/common/communication/communication.h:109:39: note: in expansion of macro 'SERIAL_OUT'
#define SERIAL_CHR(c) SERIAL_OUT(write, c)
sketch/src/commands/gcode/host/m408.h:279:5: note: in expansion of macro 'SERIAL_CHR'
SERIAL_CHR('}');
sketch/src/commands/../../src/platform/common/communication/communication.h:98:4: error: expected unqualified-id before 'while'
}while(0)
SERIAL_CHR('}');
sketch/src/commands/../../src/platform/common/communication/communication.h:110:39: note: in expansion of macro 'SERIAL_CHR'
#define SERIAL_EOL() SERIAL_CHR('\n')
sketch/src/commands/gcode/host/m408.h:280:5: note: in expansion of macro 'SERIAL_EOL'
SERIAL_EOL();
}while(0)
SERIAL_EOL();
sketch/src/commands/gcode/host/m408.h:281:3: error: expected declaration before '}' token
exit status 1
Errore durante la compilazione per la scheda Arduino/Genuino Mega or Mega 2560.
Questo report potrebbe essere più ricco di informazioni abilitando l'opzione
Re: prima installazione mk4duo su i3 pro w April 26, 2020 12:33PM |
Re: prima installazione mk4duo su i3 pro w April 26, 2020 12:50PM |
Re: prima installazione mk4duo su i3 pro w April 26, 2020 04:15PM |
Re: prima installazione mk4duo su i3 pro w April 26, 2020 04:41PM |
Re: prima installazione mk4duo su i3 pro w April 26, 2020 04:44PM |
Re: prima installazione mk4duo su i3 pro w April 26, 2020 06:20PM |
Re: prima installazione mk4duo su i3 pro w April 27, 2020 09:33AM |
Re: prima installazione mk4duo su i3 pro w April 27, 2020 11:37AM |
Re: prima installazione mk4duo su i3 pro w April 27, 2020 12:29PM |
Re: prima installazione mk4duo su i3 pro w April 27, 2020 01:53PM |
#define ULTIPANEL and #define NEWPANEL //enable this if you have a click-encoder panel Also change the value on define MOTHERBOARD to 33 in "pins.h" go to section for RAMPS configuration (search for MOTHERBOARD == 33) //STOP / KILL button #define KILL_PIN 41 //[RAMPS14-SMART-ADAPTER] //lcd pins #define LCD_PINS_RS 16 //[RAMPS14-SMART-ADAPTER] #define LCD_PINS_ENABLE 17 //[RAMPS14-SMART-ADAPTER] #define LCD_PINS_D4 23 //[RAMPS14-SMART-ADAPTER] #define LCD_PINS_D5 25 //[RAMPS14-SMART-ADAPTER] #define LCD_PINS_D6 27 //[RAMPS14-SMART-ADAPTER] #define LCD_PINS_D7 29 //[RAMPS14-SMART-ADAPTER] //encoder pins #define BTN_EN1 31 //[RAMPS14-SMART-ADAPTER] #define BTN_EN2 33 //[RAMPS14-SMART-ADAPTER] #define BTN_ENC 35 //[RAMPS14-SMART-ADAPTER] //beeper #define BEEPER 37 //[RAMPS14-SMART-ADAPTER] / 37 = enabled; -1 = dissabled / (if you don't like the beep sound ;-) //SD card detect pin #define SDCARDDETECT 49 //[RAMPS14-SMART-ADAPTER]
/************************* * Configuration_LCD * *************************/ #define LCD_LANGUAGE it #define LCD_LANGUAGE_1 NO_LANGUAGE #define LCD_LANGUAGE_2 NO_LANGUAGE #define LCD_LANGUAGE_3 NO_LANGUAGE #define LCD_LANGUAGE_4 NO_LANGUAGE #define LCD_CHARSET_HD44780 JAPANESE #define LCD_INFO_SCREEN_STYLE 0 //#define REPRAP_DISCOUNT_SMART_CONTROLLER //#define ULTIMAKERCONTROLLER //#define ULTIPANEL //#define PANEL_ONE //#define G3D_PANEL //#define RIGIDBOT_PANEL //#define MAKEBOARD_MINI_2_LINE_DISPLAY_1602 //#define ZONESTAR_LCD // Requires ADC_KEYPAD_PIN to be assigned to an analog pin. //#define ULTRA_LCD //#define RA_CONTROL_PANEL //#define LCD_SAINSMART_I2C_1602 //#define LCD_SAINSMART_I2C_2004 //#define LCM1602 //#define LCD_I2C_PANELOLU2 //#define LCD_I2C_VIKI //#define RADDS_DISPLAY //#define SAV_3DLCD #define REPRAP_DISCOUNT_FULL_GRAPHIC_SMART_CONTROLLER // Questo è il mio display //#define REPRAPWORLD_GRAPHICAL_LCD //#define VIKI2 //#define miniVIKI //#define MINIPANEL //#define MAKRPANEL
#define NEWPANELnelle definizioni in Configuration_Overall.h
Re: prima installazione mk4duo su i3 pro w April 27, 2020 03:43PM |
//#define ULTIPANEL
//#define PANEL_ONE
//#define G3D_PANEL
//#define ULTRA_LCD
//#define LCM1602
//#define SAV_3DLCD
//#define REPRAP_DISCOUNT_FULL_GRAPHIC_SMART_CONTROLLER
//#define VIKI2
//#define miniVIKI
//#define MINIPANEL
//#define MAKRPANEL
//#define ELB_FULL_GRAPHIC_CONTROLLER
//#define BQ_LCD_SMART_CONTROLLER
//#define WANHAO_D6_OLED
//#define CARTESIO_UI
//#define LCD_FOR_MELZI
//#define U8GLIB_SSD1306
//#define SAV_3DGLCD
//#define U8GLIB_SH1106
//#define ULTI_CONTROLLER
//#define OLED_PANEL_TINYBOY2
//#define MKS_MINI_12864
//#define FYSETC_MINI_12864
//#define CR10_STOCKDISPLAY
//#define ANET_FULL_GRAPHICS_LCD // Anet 128x64 full graphics lcd with rotary encoder as used on Anet A6
//#define MKS_12864OLED // Uses the SH1106 controller (default)
//#define MKS_12864OLED_SSD1306 // Uses the SSD1306 controller
//#define AZSMZ_12864
//#define SILVER_GATE_GLCD_CONTROLLER
//#define NEXTION
#define NEXTION_SERIAL 1
#define NEXTION_BAUDRATE 57600
#define NEXTION_MAX_MESSAGE_LENGTH 30
//#define NEXTION_GFX
#define NEXTION_FIRMWARE_FILE "mk4duo.tft"
#define SHOW_BOOTSCREEN
#define BOOTSCREEN_TIMEOUT 2500
#define BOOTSCREEN_MKLOGO_HIGH // Show a hight MK4duo logo on the Boot Screen (disable it saving 399 bytes of flash)
//#define BOOTSCREEN_MKLOGO_ANIMATED // Animated MK4duo logo. Costs ~3260 (or ~940) bytes of PROGMEM.
//#define SHOW_CUSTOM_BOOTSCREEN
//#define CUSTOM_STATUS_SCREEN_IMAGE
#define XYZ_HOLLOW_FRAME
#define MENU_HOLLOW_FRAME
//#define USE_BIG_EDIT_FONT
//#define USE_SMALL_INFOFONT
//#define DOGM_SPI_DELAY_US 5
//#define OVERLAY_GFX_REVERSE
//#define STATUS_HOTEND_NUMBERLESS // Use plain hotend icons instead of numbered ones (with 2+ hotends)
#define STATUS_HOTEND_INVERTED // Show solid nozzle bitmaps when heating (Requires STATUS_HOTEND_ANIM)
#define STATUS_HOTEND_ANIM // Use a second bitmap to indicate hotend heating
#define STATUS_BED_ANIM // Use a second bitmap to indicate bed heating
#define STATUS_CHAMBER_ANIM // Use a second bitmap to indicate chamber heating
//#define STATUS_ALT_BED_BITMAP // Use the alternative bed bitmap
//#define STATUS_ALT_FAN_BITMAP // Use the alternative fan bitmap
//#define STATUS_FAN_FRAMES 3 // :[0,1,2,3,4] Number of fan animation frames
//#define STATUS_HEAT_PERCENT // Show heating in a progress bar
//#define GAME_BRICKOUT
//#define GAME_INVADERS
//#define GAME_SNAKE
//#define NO_LCD_MENUS
//#define SLIM_LCD_MENUS
//#define ST7920_DELAY_1 DELAY_NS(0)
//#define ST7920_DELAY_2 DELAY_NS(0)
//#define ST7920_DELAY_3 DELAY_NS(64)
#define ENCODER_PULSES_PER_STEP 5
#define ENCODER_STEPS_PER_MENU_ITEM 1
//#define LCD_SCREEN_ROT_90 // Rotate screen orientation for graphics display by 90 degree clockwise
//#define LCD_SCREEN_ROT_180 // Rotate screen orientation for graphics display by 180 degree clockwise
//#define LCD_SCREEN_ROT_270 // Rotate screen orientation for graphics display by 270 degree clockwise
//#define INVERT_CLICK_BUTTON // Option for invert encoder button logic
//#define INVERT_BACK_BUTTON // Option for invert back button logic if avaible
#define REVERSE_ENCODER_DIRECTION
#define REVERSE_MENU_DIRECTION
//#define REVERSE_SELECT_DIRECTION
#define ENCODER_RATE_MULTIPLIER // If defined, certain menu edit operations automatically multiply the steps when the encoder is moved quickly
#define ENCODER_10X_STEPS_PER_SEC 75 // If the encoder steps per sec exceeds this value, multiply steps moved x10 to quickly advance the value
#define ENCODER_100X_STEPS_PER_SEC 160 // If the encoder steps per sec exceeds this value, multiply steps moved x100 to really quickly advance the value
#define ULTIPANEL_FEEDMULTIPLY
#define SPEAKER
//#define LCD_FEEDBACK_FREQUENCY_DURATION_MS 2
//#define LCD_FEEDBACK_FREQUENCY_HZ 5000
#define LCD_ALLIGATOR_VOLTAGE_LEVEL 1
#define LCD_INFO_MENU
//#define STATUS_MESSAGE_SCROLLING
//#define LCD_DECIMAL_SMALL_XY
//#define LCD_TIMEOUT_TO_STATUS 15000
//#define LED_CONTROL_MENU
//#define LED_COLOR_PRESETS // Enable the Preset Color menu option
//#define LED_USER_PRESET_STARTUP // Have the printer display the user preset color on startup
#define LED_USER_PRESET_RED 255 // User defined RED value
#define LED_USER_PRESET_GREEN 255 // User defined GREEN value
#define LED_USER_PRESET_BLUE 255 // User defined BLUE value
#define LED_USER_PRESET_WHITE 255 // User defined WHITE value
#define LED_USER_PRESET_BRIGHTNESS 255 // User defined intensity
//#define LCD_PROGRESS_BAR
#define PROGRESS_BAR_BAR_TIME 5000U
#define PROGRESS_BAR_MSG_TIME 1500U
#define PROGRESS_MSG_EXPIRE 0
//#define PROGRESS_MSG_ONCE
//#define LCD_PROGRESS_BAR_TEST
//#define CUSTOM_USER_MENUS
#define USER_SCRIPT_DONE "M117 User Script Done"
#define USER_DESC_1 "Home & ABL"
#define USER_GCODE_1 "G28\nG29"
//#define USER_DESC_2 "Preheat for " PREHEAT_1_LABEL
//#define USER_GCODE_2 "M140 S" STRINGIFY(PREHEAT_1_TEMP_BED) "\nM104 S" STRINGIFY(PREHEAT_1_TEMP_HOTEND)
//#define USER_DESC_3 "Preheat for " PREHEAT_2_LABEL
//#define USER_GCODE_3 "M140 S" STRINGIFY(PREHEAT_2_TEMP_BED) "\nM104 S" STRINGIFY(PREHEAT_2_TEMP_HOTEND)
//#define USER_DESC_4 "Preheat for " PREHEAT_3_LABEL
//#define USER_GCODE_4 "M140 S" STRINGIFY(PREHEAT_3_TEMP_BED) "\nM104 S" STRINGIFY(PREHEAT_3_TEMP_HOTEND)
//#define USER_DESC_5 "Heat Bed/Home/Level"
//#define USER_GCODE_5 "M140 S" STRINGIFY(PREHEAT_2_TEMP_BED) "\nG28\nG29"
//#define USER_DESC_6 "Home & Info"
//#define USER_GCODE_6 "G28\nM503"
* MK4duo Firmware for 3D Printer, Laser and CNC
* Based on Marlin, Sprinter and grbl
* Copyright (c) 2011 Camiel Gubbels / Erik van der Zalm
* Copyright (c) 2019 Alberto Cotronei @MagoKimbra
* This program is free software: you can redistribute it and/or modify
* it under the terms of the GNU General Public License as published by
* the Free Software Foundation, either version 3 of the License, or
* (at your option) any later version.
* This program is distributed in the hope that it will be useful,
* but WITHOUT ANY WARRANTY; without even the implied warranty of
* MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the
* GNU General Public License for more details.
* You should have received a copy of the GNU General Public License
* along with this program. If not, see [url]http://www.gnu.org/licenses/[/url].
#pragma once
* Configuration_Pins.h
* This configuration file contains all Pins.
//=================================== BASIC ==================================
// X axis pins
#define X_STEP_PIN ORIG_X_STEP_PIN
#define X_DIR_PIN ORIG_X_DIR_PIN
#define X_ENABLE_PIN ORIG_X_ENABLE_PIN
#define X_CS_PIN ORIG_X_CS_PIN
// X2 axis pins
#if ENABLED(DUAL_X_CARRIAGE) || ENABLED(X_TWO_STEPPER_DRIVERS)
#define X2_STEP_PIN ORIG_E1_STEP_PIN
#define X2_DIR_PIN ORIG_E1_DIR_PIN
#define X2_ENABLE_PIN ORIG_E1_ENABLE_PIN
#define X2_CS_PIN ORIG_E1_CS_PIN
#endif
// Y axis pins
#define Y_STEP_PIN ORIG_Y_STEP_PIN
#define Y_DIR_PIN ORIG_Y_DIR_PIN
#define Y_ENABLE_PIN ORIG_Y_ENABLE_PIN
#define Y_CS_PIN ORIG_Y_CS_PIN
// Y2 axis pins
#if ENABLED(Y_TWO_STEPPER_DRIVERS)
#define Y2_STEP_PIN ORIG_E1_STEP_PIN
#define Y2_DIR_PIN ORIG_E1_DIR_PIN
#define Y2_ENABLE_PIN ORIG_E1_ENABLE_PIN
#define Y2_CS_PIN ORIG_E1_CS_PIN
#endif
// Z axis pins
#define Z_STEP_PIN ORIG_Z_STEP_PIN
#define Z_DIR_PIN ORIG_Z_DIR_PIN
#define Z_ENABLE_PIN ORIG_Z_ENABLE_PIN
#define Z_CS_PIN ORIG_Z_CS_PIN
// Z2 axis pins
#if (ENABLED(Z_TWO_STEPPER_DRIVERS) || ENABLED(Z_THREE_STEPPER_DRIVERS))
#define Z2_STEP_PIN ORIG_E1_STEP_PIN
#define Z2_DIR_PIN ORIG_E1_DIR_PIN
#define Z2_ENABLE_PIN ORIG_E1_ENABLE_PIN
#define Z2_CS_PIN ORIG_E1_CS_PIN
#endif
// Z3 axis pins
#if ENABLED(Z_THREE_STEPPER_DRIVERS)
#define Z3_STEP_PIN ORIG_E2_STEP_PIN
#define Z3_DIR_PIN ORIG_E2_DIR_PIN
#define Z3_ENABLE_PIN ORIG_E2_ENABLE_PIN
#define Z3_CS_PIN ORIG_E2_CS_PIN
#endif
// E0 axis pins
#define E0_STEP_PIN ORIG_E0_STEP_PIN
#define E0_DIR_PIN ORIG_E0_DIR_PIN
#define E0_ENABLE_PIN ORIG_E0_ENABLE_PIN
#define E0_CS_PIN ORIG_E0_CS_PIN
#define SOL0_PIN ORIG_SOL0_PIN
// E1 axis pins
#define E1_STEP_PIN ORIG_E1_STEP_PIN
#define E1_DIR_PIN ORIG_E1_DIR_PIN
#define E1_ENABLE_PIN ORIG_E1_ENABLE_PIN
#define E1_CS_PIN ORIG_E1_CS_PIN
#define SOL1_PIN ORIG_SOL1_PIN
// E2 axis pins
#define E2_STEP_PIN ORIG_E2_STEP_PIN
#define E2_DIR_PIN ORIG_E2_DIR_PIN
#define E2_ENABLE_PIN ORIG_E2_ENABLE_PIN
#define E2_CS_PIN ORIG_E2_CS_PIN
#define SOL2_PIN ORIG_SOL2_PIN
// E3 axis pins
#define E3_STEP_PIN ORIG_E3_STEP_PIN
#define E3_DIR_PIN ORIG_E3_DIR_PIN
#define E3_ENABLE_PIN ORIG_E3_ENABLE_PIN
#define E3_CS_PIN ORIG_E3_CS_PIN
#define SOL3_PIN ORIG_SOL3_PIN
// E4 axis pins
#define E4_STEP_PIN ORIG_E4_STEP_PIN
#define E4_DIR_PIN ORIG_E4_DIR_PIN
#define E4_ENABLE_PIN ORIG_E4_ENABLE_PIN
#define E4_CS_PIN ORIG_E4_CS_PIN
#define SOL4_PIN ORIG_SOL4_PIN
// E5 axis pins
#define E5_STEP_PIN ORIG_E5_STEP_PIN
#define E5_DIR_PIN ORIG_E5_DIR_PIN
#define E5_ENABLE_PIN ORIG_E5_ENABLE_PIN
#define E5_CS_PIN ORIG_E5_CS_PIN
#define SOL5_PIN ORIG_SOL5_PIN
// ENDSTOP pins
#define X_MIN_PIN ORIG_X_MIN_PIN
#define X_MAX_PIN ORIG_X_MAX_PIN
#define Y_MIN_PIN ORIG_Y_MIN_PIN
#define Y_MAX_PIN ORIG_Y_MAX_PIN
#define Z_MIN_PIN ORIG_Z_MIN_PIN
#define Z_MAX_PIN ORIG_Z_MAX_PIN
#define X2_MIN_PIN NoPin
#define Y2_MIN_PIN NoPin
#define Z2_MIN_PIN NoPin
#define Z3_MIN_PIN NoPin
#define X2_MAX_PIN NoPin
#define Y2_MAX_PIN NoPin
#define Z2_MAX_PIN NoPin
#define Z3_MAX_PIN NoPin
#define Z_PROBE_PIN NoPin
// HEATERS pins
#define HEATER_HE0_PIN ORIG_HEATER_HE0_PIN
#define HEATER_HE1_PIN ORIG_HEATER_HE1_PIN
#define HEATER_HE2_PIN ORIG_HEATER_HE2_PIN
#define HEATER_HE3_PIN ORIG_HEATER_HE3_PIN
#define HEATER_HE4_PIN ORIG_HEATER_HE4_PIN
#define HEATER_HE5_PIN ORIG_HEATER_HE5_PIN
#define HEATER_BED0_PIN ORIG_HEATER_BED0_PIN
#define HEATER_BED1_PIN ORIG_HEATER_BED1_PIN
#define HEATER_BED2_PIN ORIG_HEATER_BED2_PIN
#define HEATER_BED3_PIN ORIG_HEATER_BED3_PIN
#define HEATER_CHAMBER0_PIN NoPin
#define HEATER_CHAMBER1_PIN NoPin
#define HEATER_CHAMBER2_PIN NoPin
#define HEATER_CHAMBER3_PIN NoPin
#define HEATER_COOLER_PIN NoPin
// TEMP pins
#define TEMP_HE0_PIN ORIG_TEMP_HE0_PIN
#define TEMP_HE1_PIN ORIG_TEMP_HE1_PIN
#define TEMP_HE2_PIN ORIG_TEMP_HE2_PIN
#define TEMP_HE3_PIN ORIG_TEMP_HE3_PIN
#define TEMP_HE4_PIN ORIG_TEMP_HE4_PIN
#define TEMP_HE5_PIN ORIG_TEMP_HE5_PIN
#define TEMP_BED0_PIN ORIG_TEMP_BED0_PIN
#define TEMP_BED1_PIN ORIG_TEMP_BED1_PIN
#define TEMP_BED2_PIN ORIG_TEMP_BED2_PIN
#define TEMP_BED3_PIN ORIG_TEMP_BED3_PIN
#define TEMP_CHAMBER0_PIN NoPin
#define TEMP_CHAMBER1_PIN NoPin
#define TEMP_CHAMBER2_PIN NoPin
#define TEMP_CHAMBER3_PIN NoPin
#define TEMP_COOLER_PIN NoPin
// FAN pins
#define FAN0_PIN ORIG_FAN0_PIN
#define FAN1_PIN ORIG_FAN1_PIN
#define FAN2_PIN ORIG_FAN2_PIN
#define FAN3_PIN ORIG_FAN3_PIN
#define FAN4_PIN ORIG_FAN4_PIN
#define FAN5_PIN ORIG_FAN5_PIN
// PS ON pin
#define PS_ON_PIN ORIG_PS_ON_PIN
// BEEPER pin
#define BEEPER_PIN ORIG_BEEPER_PIN
//================================= FEATURE ==================================
#if ENABLED(TACHOMETRIC)
#define TACHO0_PIN NoPin
#define TACHO1_PIN NoPin
#define TACHO2_PIN NoPin
#define TACHO3_PIN NoPin
#define TACHO4_PIN NoPin
#define TACHO5_PIN NoPin
#endif
#if ENABLED(MKR4)
#define E0E1_CHOICE_PIN -1
#define E0E2_CHOICE_PIN -1
#define E1E3_CHOICE_PIN -1
#elif ENABLED(MKR6) || ENABLED(MKR12)
#define EX1_CHOICE_PIN -1
#define EX2_CHOICE_PIN -1
#endif
#if ENABLED(PRUSA_MMU2)
#define MMU2_RST_PIN -1
#endif
#if ENABLED(LASER)
#define LASER_PWR_PIN ORIG_LASER_PWR_PIN
#define LASER_PWM_PIN ORIG_LASER_PWM_PIN
#if ENABLED(LASER_PERIPHERALS)
#define LASER_PERIPHERALS_PIN NoPin
#define LASER_PERIPHERALS_STATUS_PIN NoPin
#endif
#endif
#if ENABLED(CNCROUTER)
#define CNCROUTER_PIN NoPin
#endif
#if ENABLED(FILAMENT_RUNOUT_SENSOR)
#define FIL_RUNOUT_0_PIN NoPin
#define FIL_RUNOUT_1_PIN NoPin
#define FIL_RUNOUT_2_PIN NoPin
#define FIL_RUNOUT_3_PIN NoPin
#define FIL_RUNOUT_4_PIN NoPin
#define FIL_RUNOUT_5_PIN NoPin
#define FIL_RUNOUT_DAV_PIN NoPin
#endif
#if ENABLED(FILAMENT_WIDTH_SENSOR)
#define FILWIDTH_PIN NoPin
#endif
#if ENABLED(FLOWMETER_SENSOR)
#define FLOWMETER_PIN
#endif
#if ENABLED(POWER_CONSUMPTION)
#define POWER_CONSUMPTION_PIN NoPin
#endif
#if ENABLED(PHOTO_GCODE)
#define PHOTOGRAPH_PIN NoPin
#define CHDK_PIN NoPin
#endif
#if ENABLED(CASE_LIGHT)
#define CASE_LIGHT_PIN NoPin
#endif
#if ENABLED(DOOR_OPEN_FEATURE)
#define DOOR_OPEN_PIN NoPin
#endif
#if ENABLED(POWER_CHECK)
#define POWER_CHECK_PIN NoPin
#endif
#if ENABLED(PROBE_SLED)
#define SLED_PIN NoPin
#endif
#if ENABLED(PROBE_SMART_EFFECTOR)
#define SMART_EFFECTOR_PIN NoPin
#endif
#if ENABLED(RGB_LED) || ENABLED(RGBW_LED)
#define RGB_LED_R_PIN NoPin
#define RGB_LED_G_PIN NoPin
#define RGB_LED_B_PIN NoPin
#define RGB_LED_W_PIN NoPin
#endif
#if ENABLED(NEOPIXEL_LED)
#define NEOPIXEL_PIN NoPin
#endif
#if ENABLED(DHT_SENSOR)
#define DHT_DATA_PIN NoPin
#endif
#if HAS_TRINAMIC && ENABLED(TMC_USE_SW_SPI)
#define TMC_SW_MOSI 51
#define TMC_SW_MISO 50
#define TMC_SW_SCK 52
#endif
//============================= LCD and SD support ============================
// @section lcd
* LCD LANGUAGE
* Select the language to display on the LCD. These languages are available:
* en, an, bg, ca, cn, cz, cz_utf8, de, el, el-gr, es, es_utf8, eu, fi, fr, fr_utf8,
* gl, hr, it, kana, kana_utf8, nl, pl, pt, pt_utf8, pt-br, pt-br_utf8, ru, sk_utf8,
* tr, uk, zh_CN, zh_TW, test
* :{ 'en':'English', 'an':'Aragonese', 'bg':'Bulgarian', 'ca':'Catalan', 'cn':'Chinese', 'cz':'Czech', 'cz_utf8':'Czech (UTF8)', 'de':'German', 'el':'Greek', 'el-gr':'Greek (Greece)', 'es':'Spanish', 'es_utf8':'Spanish (UTF8)', 'eu':'Basque-Euskera', 'fi':'Finnish', 'fr':'French', 'fr_utf8':'French (UTF8)', 'gl':'Galician', 'hr':'Croatian', 'it':'Italian', 'kana':'Japanese', 'kana_utf8':'Japanese (UTF8)', 'nl':'Dutch', 'pl':'Polish', 'pt':'Portuguese', 'pt-br':'Portuguese (Brazilian)', 'pt-br_utf8':'Portuguese (Brazilian UTF8)', 'pt_utf8':'Portuguese (UTF8)', 'ru':'Russian', 'sk_utf8':'Slovak (UTF8)', 'tr':'Turkish', 'uk':'Ukrainian', 'zh_CN':'Chinese (Simplified)', 'zh_TW':'Chinese (Taiwan)', test':'TEST' }
* LCD Character Set
* Note: This option is NOT applicable to Graphical Displays.
* All character-based LCDs provide ASCII plus one of these
* language extensions:
* - JAPANESE ... the most common
* - WESTERN ... with more accented characters
* - CYRILLIC ... for the Russian language
* To determine the language extension installed on your controller:
* - Compile and upload with LCD_LANGUAGE set to 'test'
* - Click the controller to view the LCD menu
* - The LCD will display Japanese, Western, or Cyrillic text
* See [url]http://marlinfw.org/docs/development/lcd_language.html[/url]
* :['JAPANESE', 'WESTERN', 'CYRILLIC']
#define DISPLAY_CHARSET_HD44780 JAPANESE
* LCD TYPE
* Enable ULTRA_LCD for a 16x2, 16x4, 20x2, or 20x4 character-based LCD.
* Enable DOGLCD for a 128x64 (ST7565R) Full Graphical Display.
* (These options will be enabled automatically for most displays.)
* IMPORTANT: The U8glib library is required for Full Graphic Display!
* [url]https://github.com/olikraus/U8glib_Arduino[/url]
//#define ULTRA_LCD // Character based
//#define DOGLCD // Full graphics display
* SD CARD
* SD Card support is disabled by default. If your controller has an SD slot,
* you must uncomment the following option or it won't work.
#define SDSUPPORT
* SD CARD: SPI SPEED
* Enable one of the following items for a slower SPI transfer speed.
* This may be required to resolve "volume init" errors.
//#define SPI_SPEED SPI_HALF_SPEED
//#define SPI_SPEED SPI_QUARTER_SPEED
//#define SPI_SPEED SPI_EIGHTH_SPEED
* SD CARD: ENABLE CRC
* Use CRC checks and retries on the SD communication.
//#define SD_CHECK_AND_RETRY
* LCD Menu Items
* Disable all menus and only display the Status Screen, or
* just remove some extraneous menu items to recover space.
// ENCODER SETTINGS
// This option overrides the default number of encoder pulses needed to
// produce one step. Should be increased for high-resolution encoders.
//#define ENCODER_PULSES_PER_STEP 4
// Use this option to override the number of step signals required to
// move between next/prev menu items.
//#define ENCODER_STEPS_PER_MENU_ITEM 1
* Encoder Direction Options
* Test your encoder's behavior first with both options disabled.
* Reversed Value Edit and Menu Nav? Enable REVERSE_ENCODER_DIRECTION.
* Reversed Menu Navigation only? Enable REVERSE_MENU_DIRECTION.
* Reversed Value Editing only? Enable BOTH options.
// This option reverses the encoder direction everywhere.
// Set this option if CLOCKWISE causes values to DECREASE
//#define REVERSE_ENCODER_DIRECTION
// This option reverses the encoder direction for navigating LCD menus.
// If CLOCKWISE normally moves DOWN this makes it go UP.
// If CLOCKWISE normally moves UP this makes it go DOWN.
//#define REVERSE_MENU_DIRECTION
// Individual Axis Homing
// Add individual axis homing items (Home X, Home Y, and Home Z) to the LCD menu.
//#define INDIVIDUAL_AXIS_HOMING_MENU
// SPEAKER/BUZZER
// If you have a speaker that can produce tones, enable it here.
// By default Marlin assumes you have a buzzer with a fixed frequency.
//#define SPEAKER
// The duration and frequency for the UI feedback sound.
// Set these to 0 to disable audio feedback in the LCD menus.
// Note: Test audio output with the G-Code:
// M300 S P
// CONTROLLER TYPE: Standard
// Marlin supports a wide variety of controllers.
// Enable one of the following options to specify your controller.
// ULTIMAKER Controller.
// ULTIPANEL as seen on Thingiverse.
//#define ULTIPANEL
// PanelOne from T3P3 (via RAMPS 1.4 AUX2/AUX3)
// [url]http://reprap.org/wiki/PanelOne[/url]
//#define PANEL_ONE
// MaKr3d Makr-Panel with graphic controller and SD support.
// [url]http://reprap.org/wiki/MaKr3d_MaKrPanel[/url]
//#define MAKRPANEL
// ReprapWorld Graphical LCD
// [url]https://reprapworld.com/?products_details&products_id/1218[/url]
// Activate one of these if you have a Panucatt Devices
// Viki 2.0 or mini Viki with Graphic LCD
// [url]http://panucatt.com[/url]
//#define VIKI2
//#define miniVIKI
// Adafruit ST7565 Full Graphic Controller.
// [url]https://github.com/eboston/Adafruit-ST7565-Full-Graphic-Controller/[/url]
// RepRapDiscount Smart Controller.
// [url]http://reprap.org/wiki/RepRapDiscount_Smart_Controller[/url]
// Note: Usually sold with a white PCB.
// GADGETS3D G3D LCD/SD Controller
// [url]http://reprap.org/wiki/RAMPS_1.3/1.4_GADGETS3D_Shield_with_Panel[/url]
// Note: Usually sold with a blue PCB.
//#define G3D_PANEL
// RepRapDiscount FULL GRAPHIC Smart Controller
// [url]http://reprap.org/wiki/RepRapDiscount_Full_Graphic_Smart_Controller[/url]
// MakerLab Mini Panel with graphic
// controller and SD support - [url]http://reprap.org/wiki/Mini_panel[/url]
//#define MINIPANEL
// RepRapWorld REPRAPWORLD_KEYPAD v1.1
// [url]http://reprapworld.com/?products_details&products_id=202&cPath=1591_1626[/url]
// REPRAPWORLD_KEYPAD_MOVE_STEP sets how much should the robot move when a key
// is pressed, a value of 10.0 means 10mm per click.
//#define REPRAPWORLD_KEYPAD
//#define REPRAPWORLD_KEYPAD_MOVE_STEP 1.0
// RigidBot Panel V1.0
// [url]http://www.inventapart.com/[/url]
// BQ LCD Smart Controller shipped by
// default with the BQ Hephestos 2 and Witbox 2.
// Cartesio UI
// [url]http://mauk.cc/webshop/cartesio-shop/electronics/user-interface[/url]
// ANET and Tronxy Controller supported displays.
// This LCD is known to be susceptible to electrical interference
// which scrambles the display. Pressing any button clears it up.
// This is a LCD2004 display with 5 analog buttons.
// A clone of the RepRapDiscount full graphics display but with
// different pins/wiring (see pins_ANET_10.h).
// LCD for Melzi Card with Graphical LCD
// LCD for Malyan M200 printers.
// This requires SDSUPPORT to be enabled
//#define MALYAN_LCD
// CONTROLLER TYPE: I2C
// Note: These controllers require the installation of Arduino's LiquidCrystal_I2C
// library. For more info: [url]https://github.com/kiyoshigawa/LiquidCrystal_I2C[/url]
// Elefu RA Board Control Panel
// [url]http://www.elefu.com/index.php?route=product/product&product_id=53[/url]
// Sainsmart (YwRobot) LCD Displays
// These require F.Malpartida's LiquidCrystal_I2C library
// [url]https://bitbucket.org/fmalpartida/new-liquidcrystal/wiki/Home[/url]
// Generic LCM1602 LCD adapter
//#define LCM1602
// PANELOLU2 LCD with status LEDs,
// separate encoder and click inputs.
// Note: This controller requires Arduino's LiquidTWI2 library v1.2.3 or later.
// For more info: [url]https://github.com/lincomatic/LiquidTWI2[/url]
// Note: The PANELOLU2 encoder click input can either be directly connected to
// a pin (if BTN_ENC defined to != -1) or read through I2C (when BTN_ENC == -1).
// Panucatt VIKI LCD with status LEDs,
// integrated click & L/R/U/D buttons, separate encoder inputs.
// SSD1306 OLED full graphics generic display
// SAV OLEd LCD module support using either SSD1306 or SH1106 based LCD modules
#if ENABLED(SAV_3DGLCD)
#endif
// Original Ulticontroller from Ultimaker 2 printer with SSD1309 I2C display and encoder
// [url]https://github.com/Ultimaker/Ultimaker2/tree/master/1249_Ulticontroller_Board_(x1[/url])
// CONTROLLER TYPE: Shift register panels
// 2 wire Non-latching LCD SR from [url]https://goo.gl/aJJ4sH[/url]
// LCD configuration: [url]http://reprap.org/wiki/SAV_3D_LCD[/url]
//#define SAV_3DLCD
// TinyBoy2 128x64 OLED / Encoder Panel
// Makeboard 3D Printer Parts 3D Printer Mini Display 1602 Mini Controller
// [url]https://www.aliexpress.com/item/Micromake-Makeboard-3D-Printer-Parts-3D-Printer-Mini-Display-1602-Mini-Controller-Compatible-with-Ramps-1/32765887917.html[/url]
// MKS MINI12864 with graphic controller and SD support
// [url]http://reprap.org/wiki/MKS_MINI_12864[/url]
// Factory display for Creality CR-10
// [url]https://www.aliexpress.com/item/Universal-LCD-12864-3D-Printer-Display-Screen-With-Encoder-For-CR-10-CR-7-Model/32833148327.html[/url]
// This is RAMPS-compatible using a single 10-pin connector.
// (For CR-10 owners who want to replace the Melzi Creality board but retain the display)
// MKS OLED 1.3" 128 × 64 FULL GRAPHICS CONTROLLER
// [url]http://reprap.org/wiki/MKS_12864OLED[/url]
// Tiny, but very sharp OLED display
// Silvergate GLCD controller
// [url]http://github.com/android444/Silvergate[/url]
Re: prima installazione mk4duo su i3 pro w April 27, 2020 03:47PM |
