Arduino IDE exit status 1 August 03, 2020 06:51AM |
C:\Users\PIETRO~1\AppData\Local\Temp\arduino_build_599450\sketch\src\platform\HAL_AVR\HAL.cpp:98:15: error: conflicting declaration of 'char __bss_end' with 'C' linkage extern char __bss_end; ^~~~~~~~~ In file included from c:\users\pietro~1\appdata\local\temp\arduino_build_599450\sketch\Configuration_Feature.h:2:0, from c:\users\pietro~1\appdata\local\temp\arduino_build_599450\sketch\mk4duo.h:86, from C:\Users\PIETRO~1\AppData\Local\Temp\arduino_build_599450\sketch\src\platform\HAL_AVR\HAL.cpp:58: C:\Users\Pietro Cesarano\Documents\Arduino\libraries\SdFat-master\src/FreeStack.h:35:13: note: previous declaration with 'C++' linkage extern char __bss_end; ^~~~~~~~~ C:\Users\PIETRO~1\AppData\Local\Temp\arduino_build_599450\sketch\src\platform\HAL_AVR\HAL.cpp:100:16: error: conflicting declaration 'void* __brkval' extern void* __brkval; ^~~~~~~~ In file included from c:\users\pietro~1\appdata\local\temp\arduino_build_599450\sketch\Configuration_Feature.h:2:0, from c:\users\pietro~1\appdata\local\temp\arduino_build_599450\sketch\mk4duo.h:86, from C:\Users\PIETRO~1\AppData\Local\Temp\arduino_build_599450\sketch\src\platform\HAL_AVR\HAL.cpp:58: C:\Users\Pietro Cesarano\Documents\Arduino\libraries\SdFat-master\src/FreeStack.h:33:14: note: previous declaration as 'char* __brkval' extern char *__brkval; ^~~~~~~~ Più di una libreria trovata per "U8glib.h" Usata: C:\Users\Pietro Cesarano\Documents\Arduino\libraries\U8glib Non usata: C:\Users\Pietro Cesarano\Documents\Arduino\libraries\U8glib_Arduino-master Uso la libreria U8glib alla versione 1.18 nella cartella: C:\Users\Pietro Cesarano\Documents\Arduino\libraries\U8glib Uso la libreria SPI alla versione 1.0 nella cartella: C:\Users\Pietro Cesarano\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.3\libraries\SPI Uso la libreria SdFat-master alla versione 1.1.4 nella cartella: C:\Users\Pietro Cesarano\Documents\Arduino\libraries\SdFat-master Uso la libreria Wire alla versione 1.0 nella cartella: C:\Users\Pietro Cesarano\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.3\libraries\Wire exit status 1 Errore durante la compilazione per la scheda Arduino Mega or Mega 2560.
Re: Arduino IDE exit status 1 August 04, 2020 03:01PM |
Re: Arduino IDE exit status 1 August 04, 2020 03:55PM |
onekk
Allora se non specifichi:
La versione di MK4Duo intendi compilare
La versione dell'IDE di arduino che stai usando
Il tipo di scheda per cui stai comnpilando
Se hai usato il configuratore online ti basta allegare il file configuration_overall.h
Con questi aiuti magari l'autore di MK4Duo riuscirà a darti qualche dritta.
Si nota però che hai un conflitto con due versioni installate di ug8lib, probabilmente non c'entra nulla con quell'errore, però controlla come mai hai due versioni di ug8lib .
Saluti
Carlo D.
Re: Arduino IDE exit status 1 August 06, 2020 01:04PM |
