Is recommended to replace the firmware repetier marlin with repetier-firmware of u8g completely rewritten u8g support libraries for 12864, high efficiency, speed is much faster than the marlin
Posted by yg12344
Tried it repetier-firmware, surprise, the efficiency is very high, not entirely perfect optimization can also support 12864, looked at the code and found repetier completely rewritten u8g support libraries for 12864, efficiency Leverage drops, it is recommended that you use repetier speed much faster than the marlin
Wow,
can you post some real example, video or comparisons?
Here almost everyone uses Marlikimbra, try this, instead
[marlinkimbra.it]
Enrico
