Estrusore multi filamento October 27, 2016 11:54AM |
Re: Estrusore multi filamento November 01, 2016 07:10AM |
Re: Estrusore multi filamento November 01, 2016 09:23AM |
Re: Estrusore multi filamento November 07, 2016 02:15PM |
Re: Estrusore multi filamento November 07, 2016 02:37PM |
Re: Estrusore multi filamento November 07, 2016 02:56PM |
Re: Estrusore multi filamento November 07, 2016 03:15PM |
Re: Estrusore multi filamento November 07, 2016 03:38PM |
/*********************************************************************** *********************** Multiextruder NPr2 **************************** *********************************************************************** * * * Setting for color meccanism NPr2 by NicolaP (www.3dmakerlab.it) * * Find angle setting by g-Code "M997 Cxxx" * * * * Uncomment NPR2 to enable this feature * * You also need to set E_MIN_PIN in Configuration_pins.h * * * ***********************************************************************/ //#define NPR2 #define COLOR_STEP {0, 10, 20, 30} // CARTER ANGLE #define COLOR_SLOWRATE 170 // MICROSECOND delay for carter motor routine (Carter Motor Feedrate: upper value-slow feedrate) #define COLOR_HOMERATE 4 // FEEDRATE for carter home #define MOTOR_ANGLE 1.8 // Nema angle for single step #define DRIVER_MICROSTEP 4 // Microstep moltiplicator driver (set jumper MS1-2-3) off-on-off 1/4 microstepping. #define CARTER_MOLTIPLICATOR 14.22 // CARTER MOLTIPLICATOR (gear ratio 13/31-10/31) /***********************************************************************/
Re: Estrusore multi filamento November 08, 2016 06:06AM |
