Re: Fa)(a! project diy avanced 3d printer November 04, 2014 04:32AM |
Bobthefighter96
volevo ciedere se andava bene fare gli angolari in plexiglass visto che ho molti scarti.
Altrimenti vanno bene in compensato?
Si.. anche in plexy... va bene.. anche in compensato.. sperimentate.. io (povero) li ho provati in mdf.
Scusate ma mi servono questi magneti
Inoltre ragazzi non trovo questi magneti su supermagnete.it 30 magnets 50 x 5 x 3 mm, NdFeB, N35
Sapete dove posso acquistarli? Grazie
Re: Fa)(a! project diy avanced 3d printer November 07, 2014 08:17AM |
Re: Fa)(a! project diy avanced 3d printer November 07, 2014 09:45AM |
Re: Fa)(a! project diy avanced 3d printer November 07, 2014 01:36PM |
Re: Fa)(a! project diy avanced 3d printer November 07, 2014 02:42PM |
Re: Fa)(a! project diy avanced 3d printer November 07, 2014 04:20PM |
Re: Fa)(a! project diy avanced 3d printer November 08, 2014 12:51AM |
esatto, non e' proprio VinavilQuote
bilanciamist
forse intendeva la polvere di legno bruciata che rimane sui pezzi dopo il taglio laser e che sporca alla grande.
Re: Fa)(a! project diy avanced 3d printer November 08, 2014 06:06AM |
Re: Fa)(a! project diy avanced 3d printer November 10, 2014 03:33PM |
Re: Fa)(a! project diy avanced 3d printer November 10, 2014 04:06PM |
Re: Fa)(a! project diy avanced 3d printer November 11, 2014 08:30AM |
Re: Fa)(a! project diy avanced 3d printer November 11, 2014 11:49AM |
Re: Fa)(a! project diy avanced 3d printer November 14, 2014 05:50AM |
Re: Fa)(a! project diy avanced 3d printer November 14, 2014 08:36AM |
Re: Fa)(a! project diy avanced 3d printer November 14, 2014 08:50AM |
Re: Fa)(a! project diy avanced 3d printer November 14, 2014 01:31PM |
Re: Fa)(a! project diy avanced 3d printer November 14, 2014 01:49PM |
Re: Fa)(a! project diy avanced 3d printer November 14, 2014 01:57PM |
Re: Fa)(a! project diy avanced 3d printer November 14, 2014 02:58PM |
Re: Fa)(a! project diy avanced 3d printer November 14, 2014 08:36PM |
Re: Fa)(a! project diy avanced 3d printer November 15, 2014 08:22AM |
testunz
pensavonlo avesse incollato.. toh eccolo qua
[www.thingiverse.com]
per bobthefighter..hai ragione a chiedere aiuto...nella falla il motore della z va alla y e viceversa le y in parallelo al posto della z.. idem per gli endstop logicamente. è una configurazione diversa da altre stampanti che usano la ramps
Re: Fa)(a! project diy avanced 3d printer November 15, 2014 04:51PM |
Re: Fa)(a! firmware Cura versione 1 November 15, 2014 10:26PM |
Re: Fa)(a! project diy avanced 3d printer November 16, 2014 05:47AM |
Bobthefighter96
Ragazzi secondo voi questi t-nuts entrano nel mio profilato [www.adafruit.com]
Grazie mille
Bobthefighter96
Ragazzi scusate mi serve assolutamente trovare un sito che venda i magneti magnets 50 x 5 x 3 mm, NdFeB, N35 perchè non li trovo assolutamente grazie in anticipo
Re: Fa)(a! project diy avanced 3d printer November 16, 2014 03:54PM |
Re: Fa)(a! project diy avanced 3d printer November 17, 2014 02:53PM |
Re: Fa)(a! firmware Cura versione 1 November 17, 2014 02:59PM |
suggestionicreative
Dove trovo in Github il firmware per Cura o meglio quale dei files nella cartella firmware è quello giusto.
Non ttrovo file .hex ma tanti file .h, quale è quello giusto?
Volevo anche segnalare che scaricando lo zip risulta essere corrotto ed alcuni files non si estraggono
Re: Fa)(a! project diy avanced 3d printer November 18, 2014 06:31AM |
Re: Fa)(a! project diy avanced 3d printer November 18, 2014 10:13AM |
suggestionicreative
Su Cura mi vengono errori come questo con vari numeri di linea e le stampe non vengono bene
L'hot end si sposta sull'asse y sfalsando tutta la stampa come se l'oggetto si fosse spostato
Error:No Line Number with checksum, Last Line: 21
Edited 2 time(s). Last edit at 11/18/2014 12:53PM by suggestionicreative.
Re: Fa)(a! firmware Cura versione 1 November 18, 2014 10:18AM |
ninjamcrew
suggestionicreative
non mi e' chiarissima la tua richiesta : il firmware non e' legato a Cura ma e' quella parte di sw che fa funzionare la stampante e riceve i dati da un programma di slicing che genera il g-code ( che puo' essere Cura oppure altri )
Nel GitHub trovi i sorgenti del firmware che devono essere trasformati in .hex tramite l'IDE di arduino ( e magari riconfigurati adattando il software al tuo hardware )
Inoltre lo zip che estrai non ha problemi perche' e' creato in tempo reale. puo' essere che hai avuto un problema di download. Riscaricalo e dovrebbe risolversi
Non so se ti ho chiarito le idee oppure te le ho ulteriormente confuse
Ciao
