Re: Fa)(a! project diy avanced 3d printer September 03, 2014 05:56AM |
Re: Fa)(a! project diy avanced 3d printer September 03, 2014 06:01AM |
Moderator Registered: 13 years ago Posts: 1,865 |
Re: Fa)(a! project diy avanced 3d printer September 03, 2014 06:19AM |
Re: Fa)(a! project diy avanced 3d printer September 05, 2014 03:07AM |
Re: Fa)(a! project diy avanced 3d printer September 09, 2014 06:51PM |
Re: Fa)(a! project diy avanced 3d printer September 12, 2014 03:54PM |
Re: Fa)(a! project diy avanced 3d printer September 15, 2014 04:50AM |
Re: Fa)(a! project diy avanced 3d printer September 15, 2014 09:11AM |
Re: Fa)(a! project diy avanced 3d printer September 17, 2014 12:50PM |
Re: Fa)(a! project diy avanced 3d printer September 18, 2014 08:49AM |
Re: Fa)(a! project diy avanced 3d printer September 19, 2014 04:49AM |
Re: Fa)(a! project diy avanced 3d printer September 19, 2014 05:03AM |
Re: Fa)(a! project diy avanced 3d printer September 19, 2014 08:02AM |
repoman
...non ho ancora capito in che modo funziona il sistema a magneti ....... dove vanno messi..qualcuno per favore sarebbe cosi' gentile da spiegarmelo meglio?Grazie mille.
Re: Fa)(a! project diy avanced 3d printer September 19, 2014 11:07AM |
Re: Fa)(a! project diy avanced 3d printer September 19, 2014 12:20PM |
Re: Fa)(a! project diy avanced 3d printer September 19, 2014 04:02PM |
Re: Fa)(a! project diy avanced 3d printer September 19, 2014 04:06PM |
repoman
piu' o meno ci sto' arrivando,grazie..prima non avevo letto tutto..e se si usasse questo :[www.supermagnete.it] invece dei magneti sciolti?
piuttosto il top credo sia una barra lunga quanto il profilato senza fare il treno di magneti...ma non so quanto costi e se sia di facile reperibilità|
Re: Fa)(a! project diy avanced 3d printer September 20, 2014 03:26AM |
Re: Fa)(a! project diy avanced 3d printer September 20, 2014 06:14AM |
Re: Fa)(a! project diy avanced 3d printer September 20, 2014 01:15PM |
Re: Fa)(a! project diy avanced 3d printer September 24, 2014 01:10PM |
Re: Fa)(a! project diy avanced 3d printer September 25, 2014 02:17PM |
repoman
quindi alla fine della fiera ne userai 120 di magneti per tutto?
Re: Fa)(a! project diy avanced 3d printer September 28, 2014 11:11AM |
Re: Fa)(a! project diy avanced 3d printer September 29, 2014 07:16PM |
Re: Fa)(a! project diy avanced 3d printer September 30, 2014 06:07AM |
Vuoi dire che Tu hai usato la cinghia tutta intera?Quote
silvio tassinari
cmq come hai fatto ha far passare la
cinghia da parte a parte senza aver messo la barra con sopra il motore della X ? la cinghia deve passare tra i cuscinetti e la puleggia sul blocco
della X
Re: Fa)(a! project diy avanced 3d printer September 30, 2014 07:53PM |
Re: Fa)(a! project diy avanced 3d printer October 01, 2014 12:00PM |
Re: Fa)(a! project diy avanced 3d printer October 01, 2014 01:36PM |
Re: Fa)(a! project diy avanced 3d printer October 01, 2014 01:47PM |
Re: Fa)(a! project diy avanced 3d printer October 01, 2014 01:59PM |
silvio tassinari
la prima che ho montato ho fatto come te... poi ho trovato questo metodo a mio avviso migliore e più elaborato.... o sfinato la cinghia con il taglierino e ho incollato con l' attak una fascetta piccola.. cosi riesci a indirizzarla nei buchi e a fare le curve ..poi se hai delle pinze piccole tipo chimico...o quelle che si usano per i comonenti elettronici...lo fai passare in 5 min.... si poi ti serve una vite per serrare la parte di abs con t-nunt e vite a testa bombata da 12mm ..se non ricordo male...( le t nuts dentro la barra con la cighia riesco a metterle solo con le pinze e mi raccomando non graffiare la barra "è la guida", poi una volta girate le porto fino al punto desiderato con il cacciavite o la pinza) per il serraggio conviene portare tutto lasse in battuta.
Bobthefighter96
Ragazzi ho ancora qualche dubbio sugli acquisti, dove mi consigliate di acquistare l'eletronica (ramps e arduino) e non ho capito bene che cosa sono le nuts ( sono dei bulloni particolari?) ( dove posso acquistarli) grazie.
