Re: MarlinKimbra + Nextion HMI TFT August 07, 2016 11:13AM |
Re: MarlinKimbra + Nextion HMI TFT August 07, 2016 11:17AM |
SAND)X
Salve ragazzi, ho un paio di problemi:
problema 1: volevo fare prima un test ma l' IDE non riesce a compilare fonendo il seguente errore
Nextion_Test:4: error: 'NexText' does not name a type NexText Text = NexText(0, 1, "t0"); ^ C:\Users\SAND\Desktop\Nextion_Test\Nextion_Test.ino: In function 'void setup()': Nextion_Test:8: error: 'nexInit' was not declared in this scope NextionON = nexInit(); ^ C:\Users\SAND\Desktop\Nextion_Test\Nextion_Test.ino: In function 'void loop()': Nextion_Test:13: error: 'Text' was not declared in this scope Text.setText("Nextion CONNECTED"); ^ Più di una libreria trovata per "Nextion.h" Usata: C:\Users\SAND\Documents\Arduino\libraries\NeoNextion Non usata: C:\Program Files (x86)\Arduino\libraries\nextion exit status 1 'NexText' does not name a type
Problema 2: non riuscendo a fare il tst ho creato il fw con il configuratore, caricato sulla board e caricato il file tft nel display. Una volta alimentato il tutto, mi accorgo che nelle schermate mancano diversi pezzi e non mi fa vedere ne hot-end ne heatd-bed ne le ventole, insomma a parte i bei disegnini tutto qello che serve non c'e'.
Come posso risolvere?
P.S. Uso una ultratronics lite
Grazie fin da subito per qualsiasi aiuto.
Re: MarlinKimbra + Nextion HMI TFT August 07, 2016 01:22PM |
Re: MarlinKimbra + Nextion HMI TFT August 08, 2016 06:20PM |
Re: MarlinKimbra + Nextion HMI TFT August 09, 2016 02:13AM |
Re: MarlinKimbra + Nextion HMI TFT August 09, 2016 03:33AM |
Re: MarlinKimbra + Nextion HMI TFT August 09, 2016 08:13AM |
Re: MarlinKimbra + Nextion HMI TFT August 09, 2016 08:28AM |
Re: MarlinKimbra + Nextion HMI TFT August 09, 2016 08:34AM |
Re: MarlinKimbra + Nextion HMI TFT August 09, 2016 10:09AM |
Re: MarlinKimbra + Nextion HMI TFT August 09, 2016 10:12AM |
Re: MarlinKimbra + Nextion HMI TFT August 09, 2016 11:56AM |
Re: MarlinKimbra + Nextion HMI TFT August 09, 2016 02:18PM |
Re: MarlinKimbra + Nextion HMI TFT August 09, 2016 03:34PM |
Mr.Goblin
Dopo che hai acceso la stampante prova a premere il tasto di reset della scheda.
Se ancora ti si blocca alla prima schermata allora il problema è di dialogo con Arduino.
Controlla se hai collegato correttamene i fili RX e TX.
L'RX del display deve essere collegato al TX della scheda e L'RX della scheda al TX del display.
Re: MarlinKimbra + Nextion HMI TFT August 09, 2016 05:26PM |
Mr.Goblin
Risalve a tutti. Come precedentemente detto ho lavorato anche ad una possibile grafica con flat Tiles.
In allegato trovate una immagine della schermata info........fatemi sapere!
Grazie.
Re: MarlinKimbra + Nextion HMI TFT August 10, 2016 03:27AM |
Mr.Goblin
Grazie.
Re: MarlinKimbra + Nextion HMI TFT August 10, 2016 04:18AM |
Re: MarlinKimbra + Nextion HMI TFT August 10, 2016 06:45PM |
Re: MarlinKimbra + Nextion HMI TFT August 11, 2016 06:58AM |
Re: MarlinKimbra + Nextion HMI TFT August 11, 2016 07:38AM |
Re: MarlinKimbra + Nextion HMI TFT August 11, 2016 10:40AM |
Re: MarlinKimbra + Nextion HMI TFT August 11, 2016 11:36AM |
Re: MarlinKimbra + Nextion HMI TFT August 11, 2016 01:07PM |
Re: MarlinKimbra + Nextion HMI TFT August 11, 2016 01:11PM |
Re: MarlinKimbra + Nextion HMI TFT August 11, 2016 02:44PM |
Re: MarlinKimbra + Nextion HMI TFT August 11, 2016 04:44PM |
Re: MarlinKimbra + Nextion HMI TFT August 11, 2016 05:35PM |
Re: MarlinKimbra + Nextion HMI TFT August 13, 2016 08:37AM |
Posso dirti che su entrambi i display sia il 4,3 che il 5 nell' area del grafico non appare nulla, per il resto sembra funzionare tutto regolarmente.Quote
Mr.Goblin
.... Come ho detto prima sono momentaneamente impossibilitato a stampare quindi non so assolutamente cosa succeda nell'area dedicata al grafico del percorso di stampa.
Grazie e buon lavoro.
Se a qualcuno serve qui sotto trovate il lavoro di Mr.Goblin adattato per il nextion 5"Quote
Mr.Goblin
Eureka!!....(doppia pacca sulla spalla)spinning smiley sticking its tongue out
In allegato trovate tutto quanto potevo fare io........ulteriori implementazioni spettano a chi di competenza!
Tolta quella cineseria inguardabile di tastiera gcode (mi meraviglio che non abbiano usato i chicchi di riso come tasti) e adattata al nuovo layout.
Nella nuova tastiera ho eliminato i tasti non codificati che stavano solo li a far bella figura.
Per implementazioni future ho lasciato anche i tasti superflui (si fa sempre in tempo a toglierli!!) ma ne ho aumentato le dimensioni.
Vi garantisco che con il mio ditone extralarge non ho avuto nessun problema a digitare mentre prima ci riuscivano solo i pigmei gialli.
Detto questo vi auguro buon divertimento e mi raccomando........
FATEMI SAPERE!!
Re: MarlinKimbra + Nextion HMI TFT August 13, 2016 12:05PM |
Re: MarlinKimbra + Nextion HMI TFT August 13, 2016 04:00PM |
