nuovi piatti super aderenti?????? November 12, 2015 09:01AM |
Re: nuovi piatti super aderenti?????? November 15, 2015 10:43AM |
Re: nuovi piatti super aderenti?????? November 19, 2015 10:56AM |
Re: nuovi piatti super aderenti?????? November 19, 2015 03:26PM |
Re: nuovi piatti super aderenti?????? November 19, 2015 03:59PM |
Re: nuovi piatti super aderenti?????? November 20, 2015 02:46AM |
Re: nuovi piatti super aderenti?????? November 20, 2015 04:58AM |
Moderator Registered: 11 years ago Posts: 1,865 |
Re: nuovi piatti super aderenti?????? November 20, 2015 10:33AM |
Re: nuovi piatti super aderenti?????? November 20, 2015 11:07AM |
Well I did the first ABS test this evening. As I suspected, after about layer 6 one corner began to lift. By layer 7, it was really lifting and made the print unusable and I was unable to continue. The print was a small 50mm calibration cube at 230°C and no heat bed. I also made sure I had complete contact with the bed on all for corners - leveled bed.
So, at this point I cannot suggest the Fleks3d plate for ABS. However, I will try a couple more tests.
Re: nuovi piatti super aderenti?????? November 20, 2015 11:25AM |
Re: nuovi piatti super aderenti?????? November 20, 2015 12:40PM |
Re: nuovi piatti super aderenti?????? November 25, 2015 03:14AM |
Re: nuovi piatti super aderenti?????? November 28, 2015 07:56AM |
Re: nuovi piatti super aderenti?????? November 28, 2015 11:20AM |
Re: nuovi piatti super aderenti?????? November 28, 2015 11:59AM |
Re: nuovi piatti super aderenti?????? November 28, 2015 01:39PM |
Re: nuovi piatti super aderenti?????? November 28, 2015 02:06PM |
Re: nuovi piatti super aderenti?????? November 28, 2015 02:23PM |
Re: nuovi piatti super aderenti?????? November 29, 2015 05:07AM |
maralb
il problema della lacca e, che quando la spruzzi vai a sporcare tutta la macchina.
almeno Io, con la mia Delta devo ogni tanto portarla al Lavaggio
Re: nuovi piatti super aderenti?????? January 20, 2018 12:03PM |
