Firmware kimbra ad hoc November 29, 2015 03:54AM |
Re: Firmware kimbra ad hoc November 29, 2015 08:43AM |
/**************************************************************************************** * 99 * Custom board ****************************************************************************************/ #if MB(99) #define KNOWN_BOARD 1 #define ORIG_X_STEP_PIN 2 #define ORIG_X_DIR_PIN 3 #define ORIG_X_ENABLE_PIN -1 #define X_STOP_PIN 16 #define ORIG_Y_STEP_PIN 5 #define ORIG_Y_DIR_PIN 6 #define ORIG_Y_ENABLE_PIN -1 #define Y_STOP_PIN 67 #define ORIG_Z_STEP_PIN 62 #define ORIG_Z_DIR_PIN 63 #define ORIG_Z_ENABLE_PIN -1 #define Z_STOP_PIN 59 #define ORIG_E0_STEP_PIN 65 #define ORIG_E0_DIR_PIN 66 #define ORIG_E0_ENABLE_PIN -1 #define SDPOWER -1 #define SDSS 53 #define LED_PIN -1 #define ORIG_FAN_PIN -1 #define PS_ON_PIN 9 #define KILL_PIN -1 #define ORIG_HEATER_0_PIN 13 #define ORIG_HEATER_1_PIN -1 #define ORIG_HEATER_2_PIN -1 #define ORIG_TEMP_0_PIN 6 // MUST USE ANALOG INPUT NUMBERING NOT DIGITAL OUTPUT NUMBERING!!!!!!!!! #define ORIG_TEMP_1_PIN -1 // MUST USE ANALOG INPUT NUMBERING NOT DIGITAL OUTPUT NUMBERING!!!!!!!!! #define ORIG_TEMP_2_PIN -1 // MUST USE ANALOG INPUT NUMBERING NOT DIGITAL OUTPUT NUMBERING!!!!!!!!! #define ORIG_HEATER_BED_PIN 4 #define ORIG_TEMP_BED_PIN 10 #endif // 99 /****************************************************************************************/
Re: Firmware kimbra ad hoc November 29, 2015 02:38PM |
Re: Firmware kimbra ad hoc January 19, 2016 04:43PM |
Re: Firmware kimbra ad hoc January 19, 2016 05:24PM |
Re: Firmware kimbra ad hoc January 19, 2016 06:57PM |
Perchè per quello che ho capito a te serve un piatto di dimensioni standard..a leggere dalle macchine che hai comprato, quindi anche una prusa andrebbe benissimo..e prendere una cosa già fatta di qualità? Tipo ultimaker e zortax? Non voglio che abbandoni il progetto, perchè sarei il primo a seguire quotidianamente gli sviluppi, anche solo per prendere spunto da alcune idee, che sicuramente potresti apportare al mondo delle stampanti 3d, venendo da quello delle "sorelle" cnc..è solo che non vorrei che poi tu ti arenassi in scelte davvero troppo dispendiose, quando avresti le stesse cose già belle che pronte e collaudate, senza troppo sbattimenti
Non leggerla assolutamente come una predica, perchè non lo è affatto, anzi, ti prego continua nel progetto che sono davvero super curioso di vedere quello che ne potrebbe venire fuori
Re: Firmware kimbra ad hoc January 24, 2016 03:20AM |
Re: Firmware kimbra ad hoc January 28, 2016 03:48AM |
