Estrusore multi filamento October 27, 2016 11:54AM |
Re: Estrusore multi filamento November 01, 2016 07:10AM |
Re: Estrusore multi filamento November 01, 2016 09:23AM |
non riesco a decidermi tra le varie soluzioni per un corretto bilanciamento tra volume/precisione/velocità/telaio ecc. ecc. (-_-)"\ |
Re: Estrusore multi filamento November 07, 2016 02:15PM |
altrimenti mi rimane il prototipo senz'anima
Re: Estrusore multi filamento November 07, 2016 02:37PM |
Re: Estrusore multi filamento November 07, 2016 02:56PM |
Re: Estrusore multi filamento November 07, 2016 03:15PM |
Stessa idea
Grande, spero la realizzi prima di me
Io sto ancora chiedendo per l'elettronica, in un altro post XD
(scherzo)
Più interagisco con questa comunità, più mi piace. |
Re: Estrusore multi filamento November 07, 2016 03:38PM |
*********************** Multiextruder NPr2 ****************************
* Setting for color meccanism NPr2 by NicolaP (www.3dmakerlab.it) *
* Find angle setting by g-Code "M997 Cxxx" *
* Uncomment NPR2 to enable this feature *
* You also need to set E_MIN_PIN in Configuration_pins.h *
//#define NPR2
#define COLOR_STEP {0, 10, 20, 30} // CARTER ANGLE
#define COLOR_SLOWRATE 170 // MICROSECOND delay for carter motor routine (Carter Motor Feedrate: upper value-slow feedrate)
#define COLOR_HOMERATE 4 // FEEDRATE for carter home
#define MOTOR_ANGLE 1.8 // Nema angle for single step
#define DRIVER_MICROSTEP 4 // Microstep moltiplicator driver (set jumper MS1-2-3) off-on-off 1/4 microstepping.
#define CARTER_MOLTIPLICATOR 14.22 // CARTER MOLTIPLICATOR (gear ratio 13/31-10/31)
Re: Estrusore multi filamento November 08, 2016 06:06AM |
