Complete KIT RepRap Prusa i3
Made in Czech Republic. Free shipping inside European union. Safe Paypal payment.
Photos in attachment below.
Price: 450€
Place order trough email - luky.lizal at gmail.com
This kit contains everything you need to complete your 3D printer Prusa i3 (single plate version with surface treated, tapped aluminum frame).
All supplied components are a high quality products. Over 50 printers has been already built with this kit. Satisfied customer is our priority.
You will find here GT2 timing belts, aluminum frames (elox, tapped), aluminum heated platform Heatbed MK2, high torque NEMA 17 stepper motors (pre-crimped with 4pin connectors),mechanical end-stops and reliable easy to use RAMPS 1.4 control board, which is capable of additional upgrades(dual extruder, lcd panel). Plastic parts are made of ABS, which offers better mechanical features than PLA do. Hot-end is pre-assembled. It is J-Head design with 0.4mm nozzle diameter. Extruder is based on i3ext by sgrber.
On the internet, there is a number of tutorials about building and setting up your Prusa i3. I recommend for example this YouTube video (https://www.youtube.com/watch?v=cWUkTEl3bZE). Another tutorial in PDF is available here (http://abella.net/dev/manual-r13.pdf). As you buy this kit, you will also receive some photos of details, so you will know how some parts were intended to be installed. You will also get configured Marlin firmware, so no calibration is needed.
Software toolchain is open source, which means it is available for free. In order to use your 3D printer, you are going to need the software described below:
Firmware - Marlin
Host software - Repetier Host
Slicing software - Slic3r
Arduino software - Arduino verze 023
(*I am not author of any of these)
Feel free to ask me anything you want.
There is some space for consultation of issues during assembly your 3D printer (mail correspondation).
Item list:
Pre-assembeld J-head 0.4mm nozzle, 3mm filament
aluminum frame - eloxed, tapped
Heat Bed Aluminum Dual Power (12V/24V) MK2a
thermistor EPCOS 100k
Ramps 1.4 Reprapdiscount kit (4*pololu, 1*Ramps 1.4, 1*Arduino mega)
flexible coupling (silicon)
white ABS parts Prusa i3 singleplate
white ABS parts i3ext
NEMA17 4pin crimped
belts and pulleys GT2
MK7 hobbed pulley
USB cable
switching power supply 12V 30A 360W
linear motion bearing LM8UU
bearing 625zz
bearing 624zz
bearing 608zz
zip ties
glass sheet 2mm 200*200mm
springs (extruder)
threaded rods M10, M8, M5, M3
smooth rods 8mm průměr
hardware (nuts, bolts, washers etc.)
coiled tubing
Please note:
1. This is a complete unassembled kit of Prusa i3. All parts are based on the design of Josef Prusa.
2. This set is an open hardware building kit. For further information see [reprap.org]. We don't take any responsibilities for printer completion. We only provide all parts needed.
4. Licence: Prusa i3 Frame Kit – GPL [reprap.org]
5. Please buy this product only if you understand what are you buying. Process of assembling requires certain technical handiness and patience.
6. Buyer is responsible for taxation and customs.
