Re: Delta printer, claca de sfaturi si idei October 21, 2014 07:48AM |
Re: Delta printer, claca de sfaturi si idei October 21, 2014 12:44PM |
Re: Delta printer, claca de sfaturi si idei October 22, 2014 08:39AM |
Re: Delta printer, claca de sfaturi si idei October 22, 2014 05:35PM |
Re: Delta printer, claca de sfaturi si idei October 23, 2014 03:11AM |
Re: Delta printer, claca de sfaturi si idei October 23, 2014 11:49AM |
Re: Delta printer, claca de sfaturi si idei October 23, 2014 12:32PM |
Re: Delta printer, claca de sfaturi si idei October 24, 2014 03:54PM |
Moderator Registered: 13 years ago Posts: 1,352 |
Re: Delta printer, claca de sfaturi si idei October 26, 2014 03:38PM |
Re: Delta printer, claca de sfaturi si idei October 27, 2014 05:27PM |
Re: Delta printer, claca de sfaturi si idei October 29, 2014 01:49AM |
alexella
Indiscutabil, o ecranare ar izola fara dubiu cablurile stepperelor de eventuale surse de paraziti externi.
Impletitul ar elimina sau macar reduce influentele de ordin inductiv.
Re: Delta printer, claca de sfaturi si idei October 29, 2014 02:01AM |
Re: Delta printer, claca de sfaturi si idei October 29, 2014 12:42PM |
Re: Delta printer, claca de sfaturi si idei October 29, 2014 05:07PM |
Re: Delta printer, claca de sfaturi si idei November 01, 2014 04:39AM |
Re: Delta printer, claca de sfaturi si idei November 01, 2014 12:40PM |
Re: Delta printer, claca de sfaturi si idei November 01, 2014 03:37PM |
Re: Delta printer, claca de sfaturi si idei November 03, 2014 08:25AM |
Re: Delta printer, claca de sfaturi si idei November 04, 2014 02:25PM |
Re: Delta printer, claca de sfaturi si idei November 23, 2014 02:50AM |
Re: Delta printer, claca de sfaturi si idei November 23, 2014 02:54AM |
Re: Delta printer, claca de sfaturi si idei November 24, 2014 01:23PM |
Re: Delta printer, claca de sfaturi si idei November 25, 2014 08:22AM |
Re: Delta printer, claca de sfaturi si idei December 04, 2014 04:25PM |
Re: Delta printer, claca de sfaturi si idei December 12, 2014 02:28PM |
SENDING:G30 A Starting Auto Calibration.. Z-Tower Endstop Offsets -33.6000 X:0.00 Y:0.00 Z:0.00 -33.4250 -34.3000 Tower Position Adjust -34.1375 A:0.00 B:0.00 C:0.00 -33.9625 -35.2500 I:0.00 J:0.00 K:0.00 -34.2500 Delta Radius: 147.1000 X-Tower Y-Tower Diag Rod: 255.1500 Iteration: 1 Adjusting Z-Height to: 322.14 mm..
SENDING:M666 L Current Delta geometry values: X (Endstop Adj): 0.00 Y (Endstop Adj): 0.00 Z (Endstop Adj): 0.00 P (Z-Probe Offset): X0.00 Y25.00 Z-65.00 A (Tower A Position Correction): 0.00 B (Tower B Position Correction): 0.00 C (Tower C Position Correction): 0.00 I (Tower A Radius Correction): 0.00 J (Tower B Radius Correction): 0.00 K (Tower C Radius Correction): 0.00 R (Delta Radius): 147.10 D (Diagonal Rod Length): 255.15 H (Z-Height): 290.00
SENDING:G30 Z-Tower Endstop Offsets -3.3375 X:0.00 Y:0.00 Z:0.00 -3.1875 -4.0750 Tower Position Adjust -3.8625 A:0.00 B:0.00 C:0.00 -3.7125 -5.0625 I:0.00 J:0.00 K:0.00 -4.2250 Delta Radius: 147.1000 X-Tower Y-Tower Diag Rod: 255.1500
Re: Delta printer, claca de sfaturi si idei December 12, 2014 06:33PM |
Adjusting Endstops.. Z-Tower Endstop Offsets 0.0125 X:-1.01 Y:-3.00 Z:-1.07 0.0375 0.1000 Tower Position Adjust 0.0500 A:0.05 B:0.07 C:-0.12 0.0000 0.0875 I:-0.37 J:-0.50 K:0.00 0.0500 Delta Radius: 144.5375 X-Tower Y-Tower Diag Rod: 250.1500 Auto Calibration Complete Issue M500 Command to save calibration settings to EPROM (if enabled)
Re: Delta printer, claca de sfaturi si idei December 13, 2014 12:38PM |
X-Tower Y-Tower Diag Rod: 243.1500 Iteration: 12 Adjusting Endstops.. Z-Tower Endstop Offsets 0.0250 X:-1.02 Y:-3.71 Z:-0.82 0.0375 -0.0375 Tower Position Adjust 0.0000 A:0.65 B:-0.24 C:-0.41 0.0375 -0.0250 I:0.00 J:0.25 K:-0.44 0.0000 Delta Radius: 142.1000 X-Tower Y-Tower Diag Rod: 243.1500 Auto Calibration Complete Issue M500 Command to save calibration settings to EPROM (if enabled) >>>M500 SENDING:M500 >>>M501 SENDING:M501
X-Tower Y-Tower Diag Rod: 285.6500 TowerB Radius error - adjusting Adjusting Delta Radius (151.10 -> 151.23) Adjusting Diag Rod Length (285.65 -> 286.15) Z-Tower Endstop Offsets -53.0000 X:-1.29 Y:-2.55 Z:-0.26 -53.0000 -53.0000 Tower Position Adjust -53.0000 A:-5.53 B:0.59 C:4.94 -53.0000 -53.0000 I:1.91 J:-46.00 K:1.64 -53.0000 Delta Radius: 151.2250 X-Tower Y-Tower Diag Rod: 286.1500 start echo: External Reset
Re: Delta printer, claca de sfaturi si idei December 14, 2014 05:11AM |
Iteration: 6 Endstops: OK Adjusting Delta Geometry.. Z-Tower Endstop Offsets 0.0125 X:-1.27 Y:-3.60 Z:-1.74 -0.0000 0.0250 Tower Position Adjust -0.0125 A:0.11 B:0.07 C:-0.18 -0.0000 -0.0000 I:-0.37 J:-0.50 K:-0.25 -0.0125 Delta Radius: 144.5375 X-Tower Y-Tower Diag Rod: 249.1500 Auto Calibration Complete Issue M500 Command to save calibration settings to EPROM (if enabled)
Re: Delta printer, claca de sfaturi si idei December 20, 2014 08:09AM |
Re: Delta printer, claca de sfaturi si idei December 20, 2014 04:39PM |
