Re: extruder July 12, 2015 02:00PM |
Re: extruder July 13, 2015 08:32AM |
Re: extruder July 13, 2015 08:48AM |
Re: extruder July 13, 2015 10:46AM |
Re: extruder July 13, 2015 02:33PM |
Re: extruder July 13, 2015 04:02PM |
Re: extruder July 14, 2015 05:06AM |
Re: extruder July 14, 2015 09:52AM |
Re: extruder July 14, 2015 10:16AM |
Re: extruder July 15, 2015 05:25AM |
Re: extruder July 16, 2015 11:51AM |
Re: extruder July 16, 2015 02:20PM |
Re: extruder July 16, 2015 03:05PM |
Re: extruder July 20, 2015 02:00AM |
alexella
8825
Si, printez de 3h cu noul setup, am ajuns la inaltimea de 80mm si inca nu mi-au aparut fenomenul de skip (care pana acuma la celalalt driver mi-ar fi aparut deja).
Mentionez ca in afara de schimbarea driver-ului, am pus si un radiator.
4988 n-avea radiator, e posibil si asta sa fi fost cauza...
spor la testat
Re: extruder July 20, 2015 04:47AM |
Re: extruder July 20, 2015 05:18AM |
Si cum ar trebui sa setez 8825-ul pentru smartrap-ul meu, 1/16 sau 1/32 ?Quote
ldanut
Ca si pinout sunt perfect compatibile cu diferenta ca 8825 vine cu semireglabilul in partea opusa fata de 4988. Iar jumperii pentru microstepping sunt un pic diferiti. 1/16 are toti jumperii setati la 4988 iar la 8825 trebuie doar cel din mijloc daca nu ma insel. Daca-i setezi pe toti 8825 este in modul 1/32 microstepping.
Re: extruder July 20, 2015 03:47PM |
Re: extruder July 21, 2015 04:27AM |
Re: extruder July 22, 2015 04:08PM |
Re: extruder July 23, 2015 02:36AM |
Re: extruder July 23, 2015 01:18PM |
Re: extruder July 24, 2015 03:03PM |
Re: extruder July 26, 2015 12:18PM |
alexella
1. nu e zgomotos, e "miorlaitor". Dar la mine abia se aude, fiind ingropat de sunetul motoarelor x/y si de cele 3 coolere
2. aaaa....nope. Jur pe rosu. Tocmai am schimbat 4988 cu 8852 si n-am schimbat nimic la motor. Si..chiar de-ar fi sa pui panglica invers, mare scula. O inversezi asa sau din soft.
3. se incalzeste mai tare. Da, evident... pentru ca daca pastrezi aceeasi configuratie de jumperi ca la 4988, o sa ai dublu microsteps la 8852 (am aflat asta pe pielea mea :-) ). Lasand gluma: daca pui un mic radiator si un ventilator sa sufle in ramps, tooootul va fi bineeeeee
hev fan
Re: extruder August 03, 2015 01:24PM |
Moderator Registered: 13 years ago Posts: 1,352 |
Re: extruder August 03, 2015 04:48PM |
Re: extruder August 11, 2015 05:00PM |
Re: extruder August 12, 2015 03:21AM |
Re: extruder August 12, 2015 07:17AM |
Re: extruder August 12, 2015 07:37AM |
N-ar fi rau daca ai mai buchisi un pic la piesa fixa a extrudorului astfel incat sa-i poti pune un surub pentru reglarea presiunii arcului.Quote
ldanut
Intinde un pic mai tare arcul de la extrudor. A mai avut cineva aceasta problema si a rezolvat-o distantand doua spire de la arc sa apese mai cu putere. Trebuie sa caut niste arcuri mai lungi sau sa scurtez cursa la cele existente.
