Imprimanta 3D Smartrap
Posted by ldanut
Re: Imprimanta 3D Smartrap
February 02, 2015 07:24AM
You will get this:
February 02, 2015 07:30AM
Looks amazing. Let me know when it's posted
February 02, 2015 07:31AM
It will be posted today.
February 02, 2015 02:08PM
Did you manage to post it?
February 03, 2015 04:01AM
Yes it is sent. You will get it in about 7-10 days.
February 09, 2015 02:01PM
Great, just got it! Looks amazing! Just trying to work out how you connect the filment tube to the hotend?
February 09, 2015 04:48PM
As per original smartrap design. Take a M4 nut and screw it into the PTFE tube and than snap the tube to the hot end plastic part.
Check last two pictures from post : [build3dparts.com]
February 19, 2015 02:18PM
I went to attach the filament and i couldn't see where it attachments. Looks like im missing a bit
open | download - image1.JPG (37.5 KB)
February 19, 2015 02:56PM
Oh ... i sent you wrong plastic part. That was ment for bowden configuration. I will send the correct one again. I'm really sorry for that. Do you have where to print it if I send you the STL ?
February 19, 2015 02:57PM
No worries, i have a spare smiling smiley
February 19, 2015 02:58PM
From where? smiling smiley
February 19, 2015 03:00PM
I have a partner in UK that can print it for you quickly.
February 19, 2015 03:02PM
Ah isnt the file online? i have a printer but its currently broken
February 19, 2015 03:05PM
Yes you have everything here [build3dparts.com]
February 19, 2015 03:17PM
I might add your probe in the future
February 19, 2015 03:22PM
sorry too many sleepless nights ... i ment you can get the stls from here: [www.thingiverse.com]
Edited 1 time(s). Last edit at 02/19/2015 03:22PM by ldanut.
February 20, 2015 06:05AM
So should I send you the new part or you can print it?
February 20, 2015 06:09AM
No its fine thanks, i already had a replacement
February 20, 2015 06:12AM
Thanks for understanding.
February 20, 2015 08:11AM
I will refund 5 euro the price of that printed part.
February 21, 2015 11:27AM
Hi, what size nozzle do i have?
February 21, 2015 11:28AM
0.4mm
February 21, 2015 12:03PM
Thanks, what do i need to do to make the 3 point leveling system work in terms of changing the firmware?
February 21, 2015 12:06PM
What firmware are you using? Smartfriends firmware from github has this implemented by using G29 after G28.
To activate it you need to uncomment from Configuratio.h the line:
#define ENABLE_AUTO_BED_LEVELING
February 21, 2015 12:15PM
GREAT thanks. Is there a way of extracting my firmware from the mega board?
February 21, 2015 12:19PM
I think its possible but you can’t alter it. You need to use special software and hardware to do that. Its not trivial.
Arduino IDE comes with avrdude, so you can use this. Find the file "avrdude" inside the package, go to the terminal and change directory there. Then use a command looking like this:
./avrdude -C ./avrdude.conf -c avrisp -b 38400 -i 10 -p m644p -P /dev/tty.usbserial- -F -U flash:r:factory_gen6.hex:i
Search more on internet about the details. The above command is just a guideline about what you need to find.
February 21, 2015 12:21PM
Thanks smiling smiley Ah thats too hard. I just didnt want change some setting. Just printing my first part. I have some feed issues though sad smiley
February 21, 2015 12:38PM
Do you know what the default extruder feed rate is ?
February 21, 2015 01:03PM
Feed rate for a correct calibrated extruder should be 100%. Did you calibrate extruder right? Usually you should varry the feed rate with 2-3% depending if its oveextruding or under extruding.
February 21, 2015 01:04PM
Remind me how you calibrate the extruder winking smiley
