Marlin Error using RUMBA controller
Posted by alisonbelow
April 06, 2016 04:59PM
Running into problems with Marlin (first time user).
When I compile, I get these errors stemming from the language.h file (see below code).
In file included from sketch\Marlin.h:42:0,
                 from sketch\Marlin_main.cpp:35:
sketch\Marlin_main.cpp: In function 'void gcode_M115()':
language.h:102: error: expected ')' before 'DEFAULT_SOURCE_URL'
   #define SOURCE_CODE_URL DEFAULT_SOURCE_URL
sketch\Marlin_main.cpp:4541:3: note: in expansion of macro 'SERIAL_PROTOCOLPGM'
   SERIAL_PROTOCOLPGM(MSG_M115_REPORT);
sketch\language.h:146:112: note: in expansion of macro 'SOURCE_CODE_URL'
 #define MSG_M115_REPORT                     "FIRMWARE_NAME:Marlin " DETAILED_BUILD_VERSION " SOURCE_CODE_URL:" SOURCE_CODE_URL " PROTOCOL_VERSION:" PROTOCOL_VERSION " MACHINE_TYPE:" MACHINE_NAME " EXTRUDER_COUNT:" STRINGIFY(EXTRUDERS) " UUID:" MACHINE_UUID "\n"
sketch\Marlin_main.cpp:4541:22: note: in expansion of macro 'MSG_M115_REPORT'
exit status 1
I am uncertain why as I did not write anything in the language.h file that would cause these errors. Is it a bug in the Marlin firmware? Thank you!
Re: Marlin Error using RUMBA controller
May 03, 2016 05:24PM
Hey,
I am having the same issue and was wondering if you found a way to fix it. I am building a delta style printer and need to get it finished.
Thanks,
Eclispe
